1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
30 registered members (citationxeleven, billt460, anndel, DirtyOilGuy, Cornershop, 3 invisible), 928 guests, and 31 spiders.
Topics296,903
Posts4,961,304
Members66,997
Most Online2,688
Jan 19th, 2019
2011 Tundra Oil Filter Torque #4714487
04/02/18 06:45 PM
04/02/18 06:45 PM
Southern VA
klt1986 Offline OP
klt1986  Offline OP
Southern VA
Changed the oil in my Tundra today and for whatever reason, I just realized I over torqued the cartridge filter housing. From everything I've read the housing is supposed to be torqued to 20 lb-ft. I looked at the oil drain plug torque and went to 30 lb-ft. Should I:
a:) Not worry about it and fix it in 6 months when I change again
b:) Try loosening the housing and torque to spec, or;
c:) Remove the cartridge housing, replace the o-ring and torque to proper spec?
Thanks for the advice in advance.
Wife: 08 Honda CR-V 4WD, M1 5W-20
Me: 11 Toyota Tundra DC 4WD 5.7L, PP 5W-30
Me Work: 06 Ford Explorer 4WD 4.0L, Pennzoil 5W-30
Son: 14 Toyota Corolla S, M1 AFE 0W-20
Re: 2011 Tundra Oil Filter Torque [Re: klt1986] #4714497
04/02/18 06:50 PM
04/02/18 06:50 PM
Nebraska
BJD78 Offline
BJD78  Offline
Nebraska
I use my German Torque wrench: "Guten tite" but not too tight.
2010 Forester:122K
2009 Sonata :189K
2010 Tucson:55K
OCI 5K using the cheapest dino oil I can buy,usually NAPA or TSC Travelers oil.
Re: 2011 Tundra Oil Filter Torque [Re: klt1986] #4714505
04/02/18 07:00 PM
04/02/18 07:00 PM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
As it heat cycles, the filter housing will only get tighter - keep that in mind when you have to change it next.
1998 Honda Accord EX 2.3L Auto (Sold) 214k mi
2009 Scion tC Manual (Daily Driver) 165k mi
Re: 2011 Tundra Oil Filter Torque [Re: Charlie2015] #4714519
04/02/18 07:19 PM
04/02/18 07:19 PM
Southern VA
klt1986 Offline OP
klt1986  Offline OP
Southern VA
Yeah that is what I was thinking. I'm just wondering if I can get by with loosening and then torquing again?
Re: 2011 Tundra Oil Filter Torque [Re: Charlie2015] #4714533
04/02/18 07:32 PM
04/02/18 07:32 PM
New Jersey
Ursatdx Offline
Ursatdx  Offline
New Jersey
Just asking.
Why would heat cycles tighten a filter housing and not loosen?
Thanks.
Re: 2011 Tundra Oil Filter Torque [Re: klt1986] #4714543
04/02/18 07:40 PM
04/02/18 07:40 PM
US
JLTD Offline
JLTD  Offline
US
I've read on a couple of posts folks have used the gaskets up to 3x on a Toyota housing, so loosening and retorquing properly would be my call.
Isn't there a mark or a metal tab on the side of the housing?
I'm a thickie; assimilate
But 20s have their place
Using AMSOILâ„¢
Hers: 2008 Jeep Liberty 138k, SS 5w30/Amsoil
His: 2015 4Runner 45k, OE 5w30/Wix
Re: 2011 Tundra Oil Filter Torque [Re: klt1986] #4714586
04/02/18 08:32 PM
04/02/18 08:32 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
I woudn't do anything. Just wait until your next oil change and eat your Wheaties beforehand.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: 2011 Tundra Oil Filter Torque [Re: klt1986] #4714619
04/02/18 09:15 PM
04/02/18 09:15 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Same here - loosen and re-torque properly would be my call.
Re: 2011 Tundra Oil Filter Torque [Re: klt1986] #4714657
04/02/18 10:07 PM
04/02/18 10:07 PM
New England
pda1122 Offline
pda1122  Offline
New England
I just remember: 30, 20, 10.
30 ft/lbs drain plug
20 ft/lbs filter housing
10 ft/lbs filter housing cap
Most drain plugs are around 30 ft/lbs
My vote is to not worry about it. When your filter cap is torqued to 1000 ft/lbs because your gorilla dad helped you and you have to use all your force with a 24” breaker bar and vice and start damaging the plastic housing, that’s when it’s time to worry. I could’ve left it but I couldn’t sleep with that small oring on there for a third oil change
'13 Toyota Tundra 5.7-Idemitsu
'08 Hyundai Elantra-Mobil 1
'96 Ranger R72 90hpJohnson
'03 Ski Doo REV 600 H.O.
�01 Kawasaki KDX 220r
Re: 2011 Tundra Oil Filter Torque [Re: klt1986] #4714676
04/02/18 10:40 PM
04/02/18 10:40 PM
Oregon
Plundy Offline
Plundy  Offline
Oregon
I can only say the way I do it by "hand" torquing. Turn it by hand until it feels firm but not totally compressed. Then check for leaks for the next few days just in case. This always worked for me. Biggest problem I've known, people leaving the old seal behind then trying to screw the new filter on top of the old seal. Same goes for drain plug, I hand tighten it until it feels just right: Never leaked or stripped on me. But you need to clean the seat around teh drain hole as well around the drain plug to make sure there's no grit interference.
Re: 2011 Tundra Oil Filter Torque [Re: klt1986] #4714700
04/02/18 11:42 PM
04/02/18 11:42 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
In years past I have had to drive a long screwdriver through the spin on filter on my late Aunt's car . To get the filter off . Also tried a BIG pair of channel locks , but could not really do much but crush it .
First time I changed oil on our 2006 Buick Lacrosse , I could not locate a 6 point 13mm box end wrench . After rounding it off with a 12 point , I ended up trying my largest vice grips & pounding on the handle . Three times . I installed a new drain plug & bought a 13mm Craftsman combination wrench .
Wyr
God bless
Re: 2011 Tundra Oil Filter Torque [Re: klt1986] #4714800
04/03/18 05:45 AM
04/03/18 05:45 AM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
Loosen and re-torque so you will sleep better. ed
CX5 Touring 2.5L :-)
Re: 2011 Tundra Oil Filter Torque [Re: Eddie] #4714807
04/03/18 06:06 AM
04/03/18 06:06 AM
Southern VA
klt1986 Offline OP
klt1986  Offline OP
Southern VA
You hit the nail on the head. I think that is my plan. I have another filter and o-rings on hand just in case it develops a leak.
Re: 2011 Tundra Oil Filter Torque [Re: klt1986] #4714867
04/03/18 07:09 AM
04/03/18 07:09 AM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
30 pound/feet ain't that bad. The filter cap wrench with the slots for the filter canister is a great buy.
If you re-torque the canister, please post your results.
You should be fine.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: 2011 Tundra Oil Filter Torque [Re: klt1986] #4714905
04/03/18 07:45 AM
04/03/18 07:45 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
If it isn't leaking wait till next OC to address. New O-ring at that point.
It wont get tighter. Folks are thinking of spin on rubber base gasket that adhere to the machined aluminum or CI filter boss.
My spin on filters have been found LOOSE at 5k miles and I give them a final tug with a strap/band wrench.
2019 VW Jetta S,6M OCI#0 62mi-Castrol Edge Prof VW508+OE Filter; '17 Subaru Crosstrek CVT OC#5 37K mi-SOA/Idemitsu 0w20 + SOA Filter
