Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
The best in personal defense (Humor)
by StevieC. 01/15/19 11:10 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
98 registered members (240_Ed, AandPDan, 97f150, advocate, anndel, 2015_PSD, 11 invisible), 2,269 guests, and 30 spiders.
Topics296,643
Posts4,956,486
Members66,950
Most Online2,577
Jan 14th, 2019
2005 Buick Lacrosse Insturment Cluster Problems #4714452
04/02/18 06:21 PM
04/02/18 06:21 PM
Texas
WyrTwister Offline OP
Texas
A cousin of mine recently purchased a used Buick . The instrument cluster has problems , along with the remote key fob .
None of the functions of the 2 key fobs work .
Odometer & the display that shows trip , gas milage , etc. work all the time or most of the time . They woke up for a short time when codes were reset ( I am told ) .
Does this sound like an insturment cluster problem or Body Control Module problem or something else ?
Thanks , :-)
Wyr
God bless
Re: 2005 Buick Lacrosse Insturment Cluster Problems [Re: WyrTwister] #4714458
04/02/18 06:27 PM
04/02/18 06:27 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Did you check the batteries in the key fobs? If they are good they may not be programmed to the car.
You are talking about the display on the IC going out, correct? Its the IC itself is bad.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: 2005 Buick Lacrosse Insturment Cluster Problems [Re: WyrTwister] #4714466
04/02/18 06:34 PM
04/02/18 06:34 PM
Texas
Texas
The battery's have been replaced .
Cousin says speedo works . The MPG , trip , battery voltage , odometer , etc. do not work . I think he said the tach & gas gauge work .
Thanks , :-)
Wyr
God bless
Re: 2005 Buick Lacrosse Insturment Cluster Problems [Re: WyrTwister] #4714561
04/02/18 07:58 PM
04/02/18 07:58 PM
Mississippi
TheLawnRanger Offline
Mississippi
I had a 2005 Impala that had the instrument cluster go out. Is your cousin's Buick from that era? I could have went to a salvage yard to buy the cluster but had other problems with the car as well. I got rid of the car instead. It was a lemon. There were many complaints about the instrument cluster during that time on the internet with people wanting a recall. It didn't happen. I said that I would never own another Impala. However, a few years later I got an offer I couldn't refuse and that Impala has lasted for many years.
'99 Cavalier 5w 30 SuperTech conventional
'11 Impala 5w 30 Magnatec full synthetic
'12 Colorado 5w 30 Magnatec full synthetic
*regular Wix oil filters for all
Re: 2005 Buick Lacrosse Insturment Cluster Problems [Re: WyrTwister] #4714576
04/02/18 08:17 PM
04/02/18 08:17 PM
Wishin' I was in Wi
mjk Offline
mjk  Offline
Wishin' I was in Wi
GM cluster rebuilding is a cottage industry. Do an Ebay search.... or a CL search. They are all over the place. Most in my area (MN) charge about $100.00 for a full rebuild.
And yes, my 01 Tahoe will need to get done this year.
Re: 2005 Buick Lacrosse Insturment Cluster Problems [Re: WyrTwister] #4714582
04/02/18 08:29 PM
04/02/18 08:29 PM
n.c.
gman2304 Offline
gman2304  Offline
n.c.
I had that problem with my 2005 Chevy truck. A local speedometer shop replaced all the stepper motors in the instrument cluster and it has worked like new for over a year. I removed the cluster and took it to them and they repaired it in one day. IIRC it was about $200.
Re: 2005 Buick Lacrosse Insturment Cluster Problems [Re: TheLawnRanger] #4714677
04/02/18 10:41 PM
04/02/18 10:41 PM
Texas
Texas
2005 Buick Lacrosse
Wyr
God bless
Re: 2005 Buick Lacrosse Insturment Cluster Problems [Re: WyrTwister] #4714786
04/03/18 05:20 AM
04/03/18 05:20 AM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
Sounds like one module not talking to another
The part where everything lights up when codes are reset makes me think that, and a ground perhaps flaking out intermittently
The remotes need fresh batteries and independent testing to make sure it's not two separate problems, or a coincidence
A more sophisticated scan tool (think Tech 2 or MDI) would be nice, can scan and address all individual modules
IIRC with my Bonneville, there's an app in the Play Store that can do the same with an ELM327 type device
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: 2005 Buick Lacrosse Insturment Cluster Problems [Re: WyrTwister] #4714825
04/03/18 06:33 AM
04/03/18 06:33 AM
USA
mk378 Offline
mk378  Offline
USA
Parts stores usually have a tester that shows if the key fob is emitting a signal when the button is pressed. If it does not the battery and/or the fob is dead. If you do have a signal you likely need to reprogram the car to match the fob, or the receiver in the car is bad.
Re: 2005 Buick Lacrosse Insturment Cluster Problems [Re: gman2304] #4714872
04/03/18 07:14 AM
04/03/18 07:14 AM
E. Tennessee
WhizkidTN Offline
WhizkidTN  Offline
E. Tennessee
My dad just had to do this recently with his 2003 Chevy Silverado 1500. The speedo was acting crazy. Cost by a local garage was $300.
His: '12 Kia Optima SX - 2.0L GDI Twin-Scroll Turbo [Tuned] (77K)
>EDGE 0W-40, Fram XG9688
Her's: '14 Nissan Rogue SL AWD - 2.5L NA (77K)
>EDGE 0W-20, Fram XG6607
Re: 2005 Buick Lacrosse Insturment Cluster Problems [Re: WyrTwister] #4714874
04/03/18 07:16 AM
04/03/18 07:16 AM
E. Tennessee
WhizkidTN Offline
WhizkidTN  Offline
E. Tennessee
Thanks , :-)
My dad also has this same car and a couple of years ago had to have the entire dash module replaced for the same reason. It seems to be a known problem. I can't remember the exact cost but I think it was like $600 at the dealer.
