It's difficult these days to have a single AF/coolant application chart and be assured it's all correct and authoritative. One of the best charts I've seen recently is on Amazon. Chart there for viewing when one looks up a Zerex product like G-05, or original green.
However, looking at it I noticed for FCA Chrysler/Mopar, it shows DexCool from 2013 on. While FCA uses an OAT AF, it's not truly Dex as it has no 2eha found in Dex. Chrysler says gaskets and orings engineered to be compatible with Dex and DexClone Universals since they are the most commonly available and likely to be used by individuals, quick lubes and shops. I'd probably want to stick with FCA OAT, or PGL at the least, LL OAT no 2eha. Otherwise, the Amazon AF chart looks pretty good to me.
