Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
107 registered members (1WildPig, 53' Stude, 380SLbenz, 2003f7, 16HC, 1978elcamino, 12 invisible), 2,055 guests, and 104 spiders.
Topics286,197
Posts4,904,040
Members67,576
Most Online2,967
Mar 10th, 2019
A/C question #4710740
03/29/18 05:21 PM
03/29/18 05:21 PM
Clermont, Fl
007 Offline OP
007  Offline OP
Clermont, Fl
I recently had my A/C in my 1986 Buick T Type converted to R134 from R12.. Before the swap I was running cool but not cold. After the swap I was told I may be leaking from my compressor as it showed signs of oil leakage. Long story short I now have NO cold air and a guage check indicates NO Freon in the system. Is this possible or have I been had? I was told I might need a new compressor but the sudden change is kind of dramatic.
Re: A/C question [Re: 007] #4710764
03/29/18 05:56 PM
03/29/18 05:56 PM
California
Billbert Offline
Billbert  Offline
California
R134a has a much smaller molecular size than R12. Extremely small leaks with R12 can become much larger leaks when the system is converted to R134a. It just happens occasionally, with no great way to predict the outcome of the conversion.
If you think you can, or if you think you can't, You are probably right.
Auto Instructor / ASE Master Tech
Re: A/C question [Re: 007] #4710775
03/29/18 06:11 PM
03/29/18 06:11 PM
USA
mk378 Offline
mk378  Offline
USA
Leaky parts never get better with time.
Re: A/C question [Re: 007] #4710782
03/29/18 06:19 PM
03/29/18 06:19 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Whoever did the conversion really should have fixed any leaks, or at the very least given you a proper estimate, before giving the vehicle back to you.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: A/C question [Re: 007] #4710789
03/29/18 06:26 PM
03/29/18 06:26 PM
DFW
DBMaster Offline
DBMaster  Offline
DFW
And, R134a usually runs at higher pressures than R-12. So, if you did have a leak - indicated by oily residue - the new refrigerant definitely would leak out faster than the R-12. I had an 89 Honda converted to Freeze 12 eight years ago. It's basically about 80% R134a with another gas blended in that is able to carry the mineral oil through the system. My output temperatures were about three degrees higher than with R-12 and A/C performance while the car was stopped was somewhat reduced. I'd rather stick with R-12 or HC refrigerants.
Re: A/C question [Re: 007] #4710791
03/29/18 06:27 PM
03/29/18 06:27 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
If it has that round R4 compressor they all leak.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: A/C question [Re: Chris142] #4710829
03/29/18 07:19 PM
03/29/18 07:19 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Agreed.... one of GM's not-so-better ideas......
Re: A/C question [Re: 007] #4710848
03/29/18 07:54 PM
03/29/18 07:54 PM
Clermont, Fl
007 Offline OP
007  Offline OP
Clermont, Fl
Would using Freon with stop leak work?
Re: A/C question [Re: 007] #4710852
03/29/18 07:57 PM
03/29/18 07:57 PM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Yeah it'll clog everything up nicely.
"Zed's dead baby, Zed's dead."
Re: A/C question [Re: rooflessVW] #4710872
03/29/18 08:18 PM
03/29/18 08:18 PM
Chris142 Offline
Chris142  Offline
ya it will.dont put a rebuilt compressor on it either. New only.
Re: A/C question [Re: 007] #4710927
03/29/18 09:06 PM
03/29/18 09:06 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
134a conversion fittings can cause leaks all by themselves.....On a car like yours, I would restore the system & charge it with R-12.
2001 Chevy Camaro L92/4L80E
Re: A/C question [Re: 007] #4710943
03/29/18 09:17 PM
03/29/18 09:17 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
How complete was the retrofit. A good job can work well, but if certain things are overlooked or not done, leaks and other issues can be prevalent.
R12 has dropped in price. You may have been much better off leaving it.
Re: A/C question [Re: 007] #4711091
03/30/18 01:24 AM
03/30/18 01:24 AM
Canada
Lolvoguy Offline
Lolvoguy  Offline
Canada
I never knew r12 was still available. I thought it was phased out years ago
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: A/C question [Re: Lolvoguy] #4711461
03/30/18 11:45 AM
03/30/18 11:45 AM
Chris142 Offline
Chris142  Offline
we still have 60 lbs of it. Is getting harder to find. I often buy it at yard sales.
Re: A/C question [Re: bdcardinal] #4711701
03/30/18 04:27 PM
03/30/18 04:27 PM
Clermont, Fl
007 Offline OP
007  Offline OP
Clermont, Fl
I agree. Mechanic stated the system held vacuum for some time before they added 134 otherwise he would have not added any Freon with a leak. Car is going back Monday to see what the dye says. I also asked to be compensated for my $122 spent on hot air in the final repair to which he agreed. Will see what happens!
