Belt Speed and RPM
MolaKule
Staff member
Iowegia - USA
I find that the linear velocity of my main drive belt (grooved drive belt) on my Frontier is 236 in/sec.
The main crankshaft (drive) pulley is 6" in Diameter.
What is the RPM of the engine under these conditions?
Measure the circumference of the pulley. That many inches is one rpm compared to the belt linear distance
Ok, but can you show us your calculations on what the rpm should be?
6 inch pulley times pi = 18.85 inches circumference.
236 in/sec divided by 18.85 inches = 12.52 revolutions per second
12.52 rps times 60 seconds = 751.2 rpm
I thought this was a class room thing and I just gave the start......
This exercise was similar to
https://www.bobistheoilguy.com/forums/ub...ity#Post4707793
With Vt being given in this case, you had to work backwards to find the radians/sec and then convert to RPM.
In this case the RPM was ~ 720 RPM so my Frontier's engine was idling.
exrang06 provided a direct approach and correct answer so he receives the BITOG virtual Coffee Cup.
