How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Sludge and Facebook's infinite wisdom
by RDY4WAR. 03/24/19 02:05 PM
Gear lube 75W90 Synthetic GM# 88900401
by rcbob. 03/24/19 01:47 PM
Rislone Rebates
by Nickdfresh. 03/24/19 01:42 PM
IndyCar Classic at COTA
by bdcardinal. 03/24/19 12:29 PM
STP 500 at Martinsville
by bdcardinal. 03/24/19 12:27 PM
Source For Microfiber Towels
by Wrenchturner44. 03/24/19 12:26 PM
Jcountry, CMichael, dude59, Petrolhead, stp
67608 Registered Users
112 registered members (A1O, 2015_PSD, Aichiguy, AdditiveOCD, 53' Stude, 15 invisible), 2,142 guests, and 65 spiders.
Topics286,352
Posts4,906,952
Members67,608
Most Online2,967
Mar 10th, 2019
A/C inop in max setting #4706722
03/25/18 06:56 PM
03/25/18 06:56 PM
San Antonio, Texas
sasilverbullet Offline OP
San Antonio, Texas
2002 Chevy 1500 Express Conversion van. A/C works fine except when you select the highest setting on the blower switch, quits blowing. Does this in either A/C or Max A/C setting.
Anyone have any ideas of what to replace/check?
03 Porsche 911 Liqui Moly Leichtlauf High Tech 5w-40 & Mahle filter
14 Honda Accord 4dr EX-L 4cyl-M1 0W-20 & WIX XP
02 Chevy 5.7L van-GTX HM 10W-40 & WIX filter
Re: A/C inop in max setting [Re: sasilverbullet] #4706727
03/25/18 07:04 PM
03/25/18 07:04 PM
Florida
artificialist Offline
Florida
Sometimes the highest speed is on a different electrical circuit than the lower speeds. Diagnosing that circuit is key, and you probably should have a service manual. In any case, check all fuses and relays related to the air conditioner and you might be able to solve the problem.
This is also why in some situations, lower fan speeds don't work, but maximum speed does work.
2010 Lancer Ralliart Sportback
Re: A/C inop in max setting [Re: sasilverbullet] #4706730
03/25/18 07:05 PM
03/25/18 07:05 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Aren't these blowers often controlled by a set of resistors? Id suspect that the max speed is no resistor, or a minimal one. Regardless, I'd start there.
If it's PWM, then I think all the circuit hardware is used all the time, so then it would have to be a control issue Id think.
Re: A/C inop in max setting [Re: sasilverbullet] #4706749
03/25/18 07:18 PM
03/25/18 07:18 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
See if there is a blower fan relay. If so its probably bad. The relays have a low and a single full/high speed setting. They are known to go bad on a single side so it either works at full only or the lower settings only.
yup
Re: A/C inop in max setting [Re: sasilverbullet] #4706751
03/25/18 07:22 PM
03/25/18 07:22 PM
Phoenix
dishdude Online content
dishdude  Online Content
Phoenix
Wow, that's weird. Usually the resistor goes bad killing the slower speeds - my guess is the switch. Does it do it in modes other than A/C?
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: A/C inop in max setting [Re: sasilverbullet] #4706761
03/25/18 07:36 PM
03/25/18 07:36 PM
Chicago, IL
Brybo86 Offline
Brybo86  Offline
Chicago, IL
Odd, sometimes the max is the same temp/blend door setting and fan speed but just forces recirc mode..?
08 Honda Accord EX-L 2.4L M1 EP 0w20 153k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 199k
95 Yamaha Jog
Re: A/C inop in max setting [Re: sasilverbullet] #4706763
03/25/18 07:38 PM
03/25/18 07:38 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Check the BLOWER fuse in the underhood fuse block.
Unplug the Blower Resistor assembly harness & Check for melted plastic/overheated Terminals.
Blower on high/Key on...Check for 12 VDC on the Orange & Red wires at the blower resistor assembly connector.
*If you find melted Terminals....Replace the Resistor assembly & Connector along with the Blower Motor as it's probably drawing more continuous current than the connection at the resistor can support. Check Ground# G103 for cleanliness/tightness.
*If everything checks out good.....Replace the Resistor assembly, The High Blower Relay is built into the assembly.
2001 Chevy Camaro L92/4L80E
Re: A/C inop in max setting [Re: Jimzz] #4706817
03/25/18 08:14 PM
03/25/18 08:14 PM
ME
eljefino Online content
eljefino  Online Content
ME
This. A GM thing.
Re: A/C inop in max setting [Re: clinebarger] #4706841
03/25/18 08:33 PM
03/25/18 08:33 PM
San Antonio, Texas
San Antonio, Texas
Thanks for the exact instructions!
Would you happen to know a link to a manual?
Re: A/C inop in max setting [Re: JHZR2] #4706877
03/25/18 08:57 PM
03/25/18 08:57 PM
MIchigan
Warstud Online content
Warstud  Online Content
MIchigan
Yep...Sounds like a bad Blower Motor Resistor.
Re: A/C inop in max setting [Re: sasilverbullet] #4706932
03/25/18 09:34 PM
03/25/18 09:34 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
I used to subcontract to a subcontractor that worked on nothing but EMT vehicles when your van was new, I know the circuits by heart. The FSM's for your van can still be found in print.
Re: A/C inop in max setting [Re: sasilverbullet] #4707016
03/25/18 10:43 PM
03/25/18 10:43 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Common blower resister problem. Replace the plug that plugs into it too.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: A/C inop in max setting [Re: sasilverbullet] #4707025
03/25/18 10:47 PM
03/25/18 10:47 PM
Seattle
Superflop Offline
Superflop  Offline
Seattle
Under the hood on the Passenger side on top of the heater housing to the left of the blower motor is where the resister screws in(its rectangular). pull the plug to it and to the motor, check for melt. Most likely need a new resistor.
2002 saab 9-5 2.3t wagon
2014 dodge grand caravan
Re: A/C inop in max setting [Re: sasilverbullet] #4707029
03/25/18 10:49 PM
03/25/18 10:49 PM
Winnipeg MB CA
Number_35 Offline
Number_35  Offline
Winnipeg MB CA
Just AC, or when calling for heat as well?
Re: A/C inop in max setting [Re: sasilverbullet] #4707384
03/26/18 10:42 AM
03/26/18 10:42 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
Have you checked with specific chevy forum?
If there is a common issue, they usually have better experience on the solutions from members.
Nothing against this forum but it is a variety of different brand of vehicle owners which is not necessarily just Chevy or GM.
  • 2017 Toyota Sienna
