The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
What's in Maxima oil?
by Truckedup. 03/23/19 06:29 PM
2015 Acura TLX 3.5L V6
by blackdiamond. 03/23/19 06:20 PM
Group 3 oil with best heat stability?
by LSXHitman. 03/23/19 05:24 PM
FixItDad28, RandomJoe, Sciascia, sosp197, peppercorn
67597 Registered Users
28 registered members (928, dishdude, Blkstanger, Brad_C, carlprop, 1 invisible), 698 guests, and 59 spiders.
Topics286,320
Posts4,906,413
Members67,597
Most Online2,967
Mar 10th, 2019
Snowblower issue. . . MTD w/ 5HP Tecumseh Sno-King #4705638
03/24/18 06:29 PM
03/24/18 06:29 PM
Cumberland County, Pennsylvani...
Robster Offline OP
Robster  Offline OP
I've had this blower for about 15 years (since new) and it's always worked well until this year. It starts hard (it used to start on first pull), after starting it runs OK until you put a load on it and then it bogs down easily (very little snow will make it almost quit). After it warms up, it pops sometimes, like maybe it's running lean.
I've tried some fuel system cleaners, running new non-ethanol fuel etc. with no improvement. I'm thinking the carb needs to be removed and cleaned, which I'll do this spring. Is there anything else I should be checking? NOTE: this blower doesn't see heavy use--about 4-5 times per season on average, so it doesn't have much time on it.
Also, I've put a new plug in it. It doesn't run better with choke on after warm up.
2017 RAM 1500 Big Horn 5.7L:PP 5w-20
2019 Hyundai Santa Fe Ultimate AWD 2.4L:Valvoline AFS 5w-30 / Fram XG9688
2013 Victory Cross Country:Amsoil 20w-40
Re: Snowblower issue. . . MTD w/ 5HP Tecumseh Sno-King [Re: Robster] #4705649
03/24/18 06:36 PM
03/24/18 06:36 PM
NJ
JLawrence08648 Offline
NJ
Probably carb, cleaning it right, in a carb dunk tank, then in a ultrasonic cleaner.
Re: Snowblower issue. . . MTD w/ 5HP Tecumseh Sno-King [Re: Robster] #4705666
03/24/18 06:46 PM
03/24/18 06:46 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
If it has the little spring loaded button on the bottom of the carb bowl, turn off the fuel and drain the carb noting how long it takes to drain fully. Remove the fuel line from the tank and fill the carb with straight Chemtool,
Remove the plug wire or ground it and pull the engine through a couple of times with the choke on then let it sit a day or so. Reconnect the line but leave the fuel turned off.
Drain approx half the bowl out (half the time you noted) and turn the fuel on and try it.
If no joy remove and properly clean.
Re: Snowblower issue. . . MTD w/ 5HP Tecumseh Sno-King [Re: Robster] #4705743
03/24/18 07:59 PM
03/24/18 07:59 PM
USA
NHGUY Offline
NHGUY  Offline
USA
Old Tecumsehs had a spring loaded needle valve at the bottom of the bowl.This was a mixture screw.All the vibration those Tecumsehs dish out loosen that screw constantly.The bogging sounds like a governor problem,like a spring issue.
Re: Snowblower issue. . . MTD w/ 5HP Tecumseh Sno-King [Re: Robster] #4705810
03/24/18 08:42 PM
03/24/18 08:42 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Buy a new carb on eBay for $13. Swap it on using a YouTube video as a guide. Done.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Snowblower issue. . . MTD w/ 5HP Tecumseh Sno-King [Re: Robster] #4705838
03/24/18 09:08 PM
03/24/18 09:08 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Water in the float bowl? Do what Trav suggested.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Snowblower issue. . . MTD w/ 5HP Tecumseh Sno-King [Re: Robster] #4706065
03/25/18 07:56 AM
03/25/18 07:56 AM
Watertown, New York
cronk Offline
cronk  Offline
Watertown, New York
I'd throw an ebay carb on it like suggested. That is more than likely the problem.
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: Snowblower issue. . . MTD w/ 5HP Tecumseh Sno-King [Re: Robster] #4706336
03/25/18 12:45 PM
03/25/18 12:45 PM
The Garden State
Whimsey Offline
Whimsey  Offline
The Garden State
I assume the Sno-King engine is a flat head engine with the spark plug on top. After you replace the carb and if that doesn't work you might have a typical issue with Tecumseh flat head engines where the exhaust valve seat recesses causing the exhaust valve to not close completely. This usually causes similar problems to yours. Is your exhaust port running hot and or glowing red while running? This could be a sign of a not closing exhaust valve. On flat head engines the exhaust valve stem needs to be ground down to compensate for the recessed exhaust valve seat. I'm not sure but maybe you can buy exhaust valves with different valve stem lengths.
Whimsey
Re: Snowblower issue. . . MTD w/ 5HP Tecumseh Sno-King [Re: Robster] #4707158
03/26/18 06:47 AM
03/26/18 06:47 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
It was a couple of winters of struggling with balky Sno Kings that led me to mounting a 99$ HF predator onto my 40 something Ariens. If it doesnt start after 3 pulls, then I forgot to turn the gas on. 4th season so far and it performs perfectly grin2
Thick oil is better grin2
Re: Snowblower issue. . . MTD w/ 5HP Tecumseh Sno-King [Re: Robster] #4708134
03/27/18 05:48 AM
03/27/18 05:48 AM
Robster Offline OP
Robster  Offline OP
Thanks for the replies guys! I have some troubleshooting to do now!
