4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
66 registered members (ad_infinitum, 4WD, 2010Civic, Agnosto, 5 invisible), 1,384 guests, and 70 spiders.
Topics286,042
Posts4,901,391
Members67,551
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Does running oversized tires endager tranny/axles? #4704035
03/23/18 09:30 AM
03/23/18 09:30 AM
Anaheim, CA
zorobabel Offline OP
Anaheim, CA
I've seen it mentioned that running oversized tires (both because of diameter and weight) puts more stress on transmissions, axles...
Is there any truth to that? To me it would be just like driving the car somewhat harder.
With all the raised trucks running around, I imagine the issue would be settled.
I am thinking of running 205/70-R15 instead of 205/65-R15 in the Maxima in the future.
1997 Maxima 197k, Castrol GTX Synblend 5W-30, FL400S
2004 Corolla 197k, VWB + SSS + Rislone cocktail, MGL51516
Re: Does running oversized tires endager tranny/axles? [Re: zorobabel] #4704046
03/23/18 09:38 AM
03/23/18 09:38 AM
Chicago, IL
Brybo86 Offline
Brybo86  Offline
Chicago, IL
If the rubber fits, wear it
I would use those tires without hesitation.
Only issue may be getting a shop to mount them since it isn't the stock size
08 Honda Accord EX-L 2.4L M1 EP 0w20 153k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 199k
95 Yamaha Jog
Re: Does running oversized tires endager tranny/axles? [Re: zorobabel] #4704051
03/23/18 09:43 AM
03/23/18 09:43 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
If they are larger in diameter and on the propulsion axle , the speedometer will probably be off a little .
Wyr
God bless
Re: Does running oversized tires endager tranny/axles? [Re: zorobabel] #4704054
03/23/18 09:45 AM
03/23/18 09:45 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Of course it does. Jeeps are usually good for about a 33 inch tire. When you start going bigger than that, its likely you will break something, especially off road.
If the truck is only used on the road, then huge tires are not likely to break anything, but they do cause extra wear on bearings, brakes, and other suspensions parts, especially if they use a different offset wheel from factory to fit the tires.
On a car, I would stick with the factory size unless you have a good reason not to. I doubt you'll be mounting some wide drag slicks to your Nissan.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Does running oversized tires endager tranny/axles? [Re: zorobabel] #4704059
03/23/18 09:48 AM
03/23/18 09:48 AM
WI
HoosierJeeper Offline
WI
Was that size ever stock on a Maxima? I'd probably run it either way. Not a big difference at all.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Does running oversized tires endager tranny/axles? [Re: zorobabel] #4704062
03/23/18 09:49 AM
03/23/18 09:49 AM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
yes. your new tires are 3% larger (circumference) and will theoretically throw off your speedometer by 3%. it will also (minimally) increase the load on your drivetrain and brakes. i can't imagine that small amount will make a practical difference. You could switch to a 195/70/15 - which is much closer to OE diameter (.2" difference instead of .8")
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Does running oversized tires endager tranny/axles? [Re: zorobabel] #4704073
03/23/18 09:56 AM
03/23/18 09:56 AM
Lakeside, CA
Blkstanger Online content
Blkstanger  Online Content
Lakeside, CA
As a general rule on most cars one size up will be okay. I think in your situation it will be fine.
I went up a size on my Jeep and it actually corrected my Speedometer.
99 Jeep WJ 4.7 197,000 Maxlife 10w30, Fram Ultra.
Re: Does running oversized tires endager tranny/axles? [Re: zorobabel] #4704085
03/23/18 10:03 AM
03/23/18 10:03 AM
California
Vuflanovsky Offline
Vuflanovsky  Offline
California
The rule of thumb used to be ( and I think still is ) that you can generally run up to a 3% increase in diameter without effecting the wheel electronics or overall stability of the car in most vehicles. Speedometers vary in that in some vehicles ( like mine ) a slightly larger tire actually corrects the speedometer...but at 3% I think you might be out of that range if it was applicable.
I would imagine the weight difference in the tires would depend on the tire but in relation to those two sizes would probably be within 1-2 pounds and not much of an issue.
Re: Does running oversized tires endager tranny/axles? [Re: zorobabel] #4704091
03/23/18 10:11 AM
03/23/18 10:11 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
That tire size difference won't stress anything significantly more. Running different wheel offsets can have effects on bearing life and even suspension performance but as long as you are close to the original offset it shouldn't be a problem.
07 Focus ZXW, 5spd manual, 230km M1 5W30
18 Outback 2.5 CVT 22km 0W20
Re: Does running oversized tires endager tranny/axles? [Re: HoosierJeeper] #4704104
03/23/18 10:30 AM
03/23/18 10:30 AM
Anaheim, CA
Anaheim, CA
Thanks for the replies!
I wouldn't be changing the wheels/rims, so offset would stay stock.
Thanks, 205/70-R15 was not an option on this generation. It was either 205/65-R15 or 215/60-R15 and later 215/55-R16.
Thanks, I am aware of the speedometer difference and not worried about it. Around here you don't typically choose your speed of travel, it is chosen by the ones in front of you. And with all the action going on, it is safer to watch the road/cars than the speedo. I would like tires in 195/70-R15 or 195/75-R15, but they are unicorns.
Re: Does running oversized tires endager tranny/axles? [Re: zorobabel] #4704105
03/23/18 10:30 AM
03/23/18 10:30 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Apparently a common cause of problems on the Suzuki Vitara here, which is often fitted with oversize tyres for cosmetic reasons.
Re: Does running oversized tires endager tranny/axles? [Re: zorobabel] #4704115
03/23/18 10:39 AM
03/23/18 10:39 AM
PA
d00df00d Online content
d00df00d  Online Content
PA
I can see the weight having an effect, albeit a minor one.
I can't see how a larger diameter could hurt the hardware. It does have some potential benefits because everything that turns with the wheels will be turning at slower speeds.
What you want to avoid is different diameters on wheels that get power -- e.g. different front diameters with FWD, different rear diameters with RWD, or different diameters anywhere with AWD (unless it's how the car came from the factory). That goes double with a limited-slip or torque-biasing diff.
Beyond that, the only definite problem with a larger diameter wheel is a higher center of mass, which will hurt handling.
Normally I'd advise against a non-stock diameter because it'd mess with ABS and stability control, but your Maxima doesn't have stability control and its ABS isn't that sophisticated AFAIK.
I wouldn't use raised trucks as a point of comparison. They are not trouble-free. The fact that they exist doesn't mean they're a good example to follow.
2008 BMW M3 Sedan 6MT
Re: Does running oversized tires endager tranny/axles? [Re: Ducked] #4704118
03/23/18 10:42 AM
03/23/18 10:42 AM
PA
PA
What are the problems that result?
Re: Does running oversized tires endager tranny/axles? [Re: d00df00d] #4704124
03/23/18 10:47 AM
03/23/18 10:47 AM
Anaheim, CA
Anaheim, CA
Thanks, I am not implying they are trouble free, I just mean the testing base is plentiful. I've seen some that couldn't even keep a straight line, and many have serious tracking issues.
Re: Does running oversized tires endager tranny/axles? [Re: zorobabel] #4704181
03/23/18 12:10 PM
03/23/18 12:10 PM
Margate England
Claud Offline
Claud  Offline
Margate England
It seems a popular trend to stuff the biggest wheels and tires possible into the wheel arches of cars and particularly trucks that will fit. I see little to be gained from this, any advantages from better grip will be largely negated by more unsprung weight. Also ride quality will suffer, and greater loads are put on the suspension and steering components.
But if it's what you want to do, hey!, it's a free country.
Claud.
Page 1 of 3 1 2 3
