AZjeff
$50 Site Donor 2023
Originally Posted By: zorobabel
Actually the main reason I'm considering 205/70 is to improve ride quality. I may be wrong, but the taller sidewall and increased load rating would allow for reduced PSI.
The second reason would be for increased pothole forgiveness.
3rd reason is to minimize (in my mind again) the vibrations caused by the current rims, which don't turn true (probably from potholes).
Bumping up 5% on the aspect ratio is barely going oversize, as noted only 3%. I usually do this on trucks and SUVs when it's time for new tires for 2 reasons: a bit bigger tire looks better IMO, and I've found that the 3% almost exactly matches how far the speedo is off from the factory and end up right on. The Toyota and Silverado both read close to 3% high.
Your first 2 reasons are sound, the 3rd is a WAG. You won't hurt a thing and a 97 likely isn't going to have sensors that don't like it.
