The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
What's in Maxima oil?
by Truckedup. 03/23/19 06:29 PM
2015 Acura TLX 3.5L V6
by blackdiamond. 03/23/19 06:20 PM
Group 3 oil with best heat stability?
by LSXHitman. 03/23/19 05:24 PM
FixItDad28, RandomJoe, Sciascia, sosp197, peppercorn
67597 Registered Users
28 registered members (928, dishdude, Blkstanger, Brad_C, carlprop, 1 invisible), 698 guests, and 59 spiders.
Topics286,320
Posts4,906,413
Members67,597
Most Online2,967
Mar 10th, 2019
06 Mustang with the 2 piece spark plugs ugggg #4702947
03/22/18 09:55 AM
03/22/18 09:55 AM
Phoenix AZ
gmh101357 Offline OP
Phoenix AZ
I hate the Motorcraft 2 piece plugs....then somebody told me to use Brisk plugs one piece unit. The Brisk plugs are 40 bucks more than Fords
but are they worth the extra money do they last longer than 30k miles?
Re: 06 Mustang with the 2 piece spark plugs ugggg [Re: gmh101357] #4702954
03/22/18 10:00 AM
03/22/18 10:00 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
No, just use a little never seize and don't wrench the arse off them. Ford had a TSB about using it on these plugs.
http://www.aa1car.com/library/ford_tsb_08-7-6.pdf
Re: 06 Mustang with the 2 piece spark plugs ugggg [Re: gmh101357] #4703011
03/22/18 10:39 AM
03/22/18 10:39 AM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
The latest update Motorcraft plugs are 1 piece, SP-547.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 06 Mustang with the 2 piece spark plugs ugggg [Re: gmh101357] #4703021
03/22/18 10:45 AM
03/22/18 10:45 AM
TN USA
Crispysea Offline
Crispysea  Offline
TN USA
Autolite makes a one-piece plug, too. HT15, I think.
Re: 06 Mustang with the 2 piece spark plugs ugggg [Re: bdcardinal] #4703026
03/22/18 10:51 AM
03/22/18 10:51 AM
Trav Offline
Trav  Offline
bd whats the retail on those? Are they a platinum?
Edit: Is the never seize still recommended?
Re: 06 Mustang with the 2 piece spark plugs ugggg [Re: Trav] #4703138
03/22/18 12:25 PM
03/22/18 12:25 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Good Grief!
I started to count the special tools and chemicals but I rapidly ran out of fingers.
To remove spark plugs?!
Hilarious.(if you don't have to do it, of course.)
Re: 06 Mustang with the 2 piece spark plugs ugggg [Re: Trav] #4703169
03/22/18 12:50 PM
03/22/18 12:50 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
MSRP is $17.42. The box says "Finewire Platnium." They still recommend following the TSB for removal and installation.
Re: 06 Mustang with the 2 piece spark plugs ugggg [Re: gmh101357] #4703239
03/22/18 01:44 PM
03/22/18 01:44 PM
MN
14Accent Offline
14Accent  Offline
MN
Best way to get those plugs out in one piece is to drive the [censored] out of it to get them hot, then pull the coil and hit the plugs with an impact.
Scariest thing I've done on a vehicle, it goes against everything we're taught about plugs, but that was right from a Ford tech's mouth and by God does it work. Not every time, but almost.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: 06 Mustang with the 2 piece spark plugs ugggg [Re: gmh101357] #4703241
03/22/18 01:48 PM
03/22/18 01:48 PM
Displaced Texan in Mexico City
Gimpy1 Offline
Gimpy1  Offline
Ford has always had issues with spark plugs. Remember when they had a TSB about plugs shooting out of their Triton V8's. How hard can it be? Pretty soon you'll have to pull the motor and heads to change plugs.
Re: 06 Mustang with the 2 piece spark plugs ugggg [Re: bdcardinal] #4703246
03/22/18 01:57 PM
03/22/18 01:57 PM
The Garden State
Whimsey Offline
Whimsey  Offline
The Garden State
Ouch! That's painful. Are these the same weird plugs with the solid U ground and 2 piece that can break upon removal? I'm grateful all 3 of my Ford vehicles have "normal" spark plugs. Even if 2 of them need sooner spark plug changes at least they are 4 cylinders and easy to do. Plus the Motorcraft spark plugs are very reasonable.
Whimsey
Re: 06 Mustang with the 2 piece spark plugs ugggg [Re: bdcardinal] #4703382
03/22/18 03:53 PM
03/22/18 03:53 PM
Trav Offline
Trav  Offline
One piece platinum plugs with never seize, got it. Thanks db
Re: 06 Mustang with the 2 piece spark plugs ugggg [Re: gmh101357] #4703383
03/22/18 03:53 PM
03/22/18 03:53 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Whimsey, yes they are.
Re: 06 Mustang with the 2 piece spark plugs ugggg [Re: gmh101357] #4703468
03/22/18 05:00 PM
03/22/18 05:00 PM
USA
slacktide_bitog Offline
USA
Bosch now makes iridium plugs for that engine. They are made in Germany. Iridium is usually good for 100k. Part number 96322
Re: 06 Mustang with the 2 piece spark plugs ugggg [Re: slacktide_bitog] #4703526
03/22/18 05:52 PM
03/22/18 05:52 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
The problem with leaving the plugs in for that long is carbon build-up on the interference fit portion of the spark plug. That is what causes them to break upon removal.
Re: 06 Mustang with the 2 piece spark plugs ugggg [Re: bdcardinal] #4703693
03/22/18 08:59 PM
03/22/18 08:59 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Which is the reason for the antiseize on the barrel of the plug.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
