Alternator, Battery Problem ?
by MasterSolenoid - 10/18/19 12:50 PM
Vaccum Oil Extractor
by ad244 - 10/18/19 11:50 AM
Mercedes C240 Engine Temperature
by NICAT - 10/18/19 11:20 AM
oil pressure went to 0 on the cummins
by motor_oil_madman - 10/18/19 11:01 AM
Renault at the edge of the abyss.
by PimTac - 10/18/19 10:39 AM
Power Washing
by buster - 10/18/19 10:02 AM
Contaminated fuel from fuel stations
by bonjo - 10/18/19 09:54 AM
TBN graph - is this a good way to look at OCI?
by TiGeo - 10/18/19 08:49 AM
$4 get peppercorns and a free grinder
by JLawrence08648 - 10/18/19 08:18 AM
Poll: Where do you purchase motor oil ?
by kstanf150 - 10/18/19 07:28 AM
Advantage of ethanol free fuel?
by mrdctaylor - 10/18/19 07:17 AM
2004 Cummins 480 CE Marine Engines
by jmichels - 10/18/19 06:29 AM
Deleted vs Non-Deleted UOA
by oakaro68 - 10/18/19 05:30 AM
3.2 V6 Cayenne oil help
by Abax25 - 10/18/19 04:16 AM
Can cops sit in the median with no lights on at night time?
by motor_oil_madman - 10/18/19 12:24 AM
2012-2014 Lexus GS350 AWD Reliability?
by GZRider - 10/17/19 10:28 PM
Switch to High Mileage Oil or No?
by Blake1107 - 10/17/19 10:21 PM
Tequila009, JCunningham, TomStackhouse, Drinksprite, jmichels
69595 Registered Users
109 registered members (andreigbs, Audios, AlienBug, askani79705, 2010Civic, 16 invisible), 2,239 guests, and 23 spiders.
Topics296,141
Posts5,092,042
Members69,595
Most Online3,532
Jul 30th, 2019
1950 Allis Chalmers #4693560 03/13/18 03:08 PM
W
wewsnu Offline OP
W
Hello!
I just acquired an old WD tractor ("gasoline"/"distilate"/"tractor fuel"), and was wondering what BITOG would recommend running in place of the SAE 30 that the factory called for in the engine of this old tractor. I know most folks are split between 10W-30 and a 15W-40 but I was hoping to hear that a 5W or 0W would be advised, mainly because I have a few gallons laying around. What are your thoughts? This will never see field work, just a parade, fair, or tractor show here and there.
Thanks for your replies!
Re: 1950 Allis Chalmers [Re: wewsnu] #4693576 03/13/18 03:21 PM
old1 Online Content
Online Content
I used to have an old WD also. I think I used 10w30, but I would see no reason that a 0 or 5 w30 or 40 wouldn't be just fine. Especially for the type of use that it will see.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 15/40 Delo
1929 ford model A No filters, and 15/40 oil
Re: 1950 Allis Chalmers [Re: wewsnu] #4693604 03/13/18 03:55 PM
CR94 Offline
If it's in good shape, 30 or 10W-30.
My father had a slightly older Allis Chalmers. I don't know the model designation. Replaced by a '52 Ferguson TO-30 or 35.
2011 Toyota Prius now at 104K
Re: 1950 Allis Chalmers [Re: CR94] #4693779 03/13/18 06:36 PM
Z
zrxkawboy Offline
Z
I agree. I would not use a 5W30...just personal preference.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: 1950 Allis Chalmers [Re: wewsnu] #4693807 03/13/18 06:58 PM
SubieRubyRoo Offline
And why wouldn’t you use a 5W30? They are both 30 weights, the only thing likely measurably different may be the NOACK number and the viscosity at 100*F.
I say use it if you’ve got it. If you picked up any of the Delo XLE on clearance at WM, use that. smile
Re: 1950 Allis Chalmers [Re: wewsnu] #4693810 03/13/18 07:00 PM
Carbon12 Offline
I would avoid any xW30, ILSAC, resource conserving, passenger car motor oils in general. SAE 30 is good, but 10w30 and 15w40 HDEO (diesel rated) oils are ideal (even in an old gasser). The reason being is these have a higher HTHS and are a little more in line with straight weight oils that would have been available back then. My 1952 Farmall Super C has 10w30 Rotella T conventional in it now, and if I were to work it hard in warm weather I would use 15w40.
Re: 1950 Allis Chalmers [Re: Carbon12] #4696171 03/15/18 10:05 PM
Z
zeng Offline
Z
+1
No way I would use/recommend a (highly) unshear-stable 0/5W30 ILSAC oil in place of monograde 30 engine oil , in any applications whether new or old equipments.
Re: 1950 Allis Chalmers [Re: wewsnu] #4778064 06/05/18 11:06 AM
J
jeepman3071 Online Content
Online Content
J
If it's just being used in parades I don't see any issue with a 5w30, just monitor the oil level closely in-case it increases consumption or leaks.
2013 Jeep Grand Cherokee TrailHawk 5.7L (146k) - PPHM 5w30, Wix 57899
2009 BMW 328i N51 (50k) - Castrol Edge Euro 0w40, MANN HU816X
Re: 1950 Allis Chalmers [Re: wewsnu] #4790944 06/19/18 11:05 AM
P
philipsearcy Offline
P
I have been using 5w-40 in my 1950 Ford 8N for the past 15+ years. Philip.
'03 Mercury Sable, '04 F250SD 5.4, '08 Honda Fit 1.5, '13 Honda Pilot, '50 Ford 8N tractor, '09 Kubota L3940 Tractor, '13 Kubota GR2120 Tractor
Re: 1950 Allis Chalmers [Re: Carbon12] #5136138 06/16/19 09:19 PM
SteveG4 Offline
+2
Somewhere between Alaska and Wisconsin...
2006 Silverado LT Crew Cab 4WD & 2013 Equinox AWD
Re: 1950 Allis Chalmers [Re: SubieRubyRoo] #5150339 07/03/19 11:37 AM
F
Fawteen Offline
F
If you don't know the history of the engine, then I'd be reluctant to use anything other than heavier weight oils. Rotella 15W40 always performs well in some of the older engines. You'll also want to be aware of the potential for leaks when using lighter, detergent oils; especially if the engine hasn't been overhauled since the 1960s or 1970s. with lighter detergent oils it's possible that some of the seals that aren't leaking now will soon start leaking like a sieve.
Originally Posted by SubieRubyRoo
And why wouldn�t you use a 5W30? They are both 30 weights, the only thing likely measurably different may be the NOACK number and the viscosity at 100*F.
I say use it if you�ve got it. If you picked up any of the Delo XLE on clearance at WM, use that. smile
Apparently you don't have a clue about vintage engines, especially tractor engines. For example, do you know that some of the WD engines use rope, felt, wick, and burlap seals that don't handle 5WXX or 0WXX oils well? And some of the original breather materials don't tolerate detergent oils? I didn't think so.
2014 Silverado
2014 Equinox
1972 Olds 442 Convertible
1918 Model T
Re: 1950 Allis Chalmers [Re: Fawteen] #5150664 07/03/19 06:16 PM
L
Linctex Offline
L
That is where my mind immediately went, also ... "rope style" rear main seal
However, these stand up to 30W and 15w-40 "farm tractor" oils just fine as long as they are relatively clean (or new)
Caked with gunk they get stiff over the years - and won't seal with thinner oils
Re: 1950 Allis Chalmers [Re: Carbon12] #5183829 08/10/19 07:07 PM
SteveG4 Offline
+3! Shell T4 15W40 would do well in it.
Or for that matter, how about Delo 400 SAE 30 Motor Oil? It's available on Amazon for reasonable cost and is rated for gas and diesel engines.
Re: 1950 Allis Chalmers [Re: wewsnu] #5191390 08/19/19 03:36 PM
A
A_Harman Offline
A
Valvoline VR1 10w30.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
