I've got a Harbor Freight 21 gallon compressor. It does not like starting up in cooler weather, I usually have to cycle the start/stop lever back and fourth a couple seconds at a time to keep the reset from popping. After several cycles, things loosen up and away it goes. It will start on its own without throwing the reset.
Are there different oils I could consider to get things moving better when cold? Right now, I just have SuperTech 30W ND in it. Or is this just something I'm going to have to resign myself to during winter? I understand it's not the best compressor, but it works for what i need. Unless it's cold.....
