Originally Posted By: Kamele0N
And dont forget to cure the cause for topping off!
You can have leak somewhere...or! Level between MAX-MIN usually coresponds with how much worn out your brakes are
Yep - I never top off brakes as the level sinks and rises according to how worn the friction is. There is never a need to top off a brake system. If you're constantly losing brake fluid you have a leak somewhere - but you can feel it in the pedal in most cases.
