'98 Mercedes E300TD Rotella T5 10W-30 5k miles
by KenO
06/19/18 04:35 PM
Premium guard oil filters
by Jaha24k
06/19/18 04:09 PM
76 super motor oil- synthetic blend 5w-30
by Jaha24k
06/19/18 04:07 PM
Who makes the Mopar 5038041AA filter?
by Quattro Pete
06/19/18 03:55 PM
Ruger Mini-14, yay or nay?
by 28oz
06/19/18 03:51 PM
USPS long long delivery to BlackStone Labs
by Pajero
06/19/18 02:58 PM
House A.c. vent leaking water
by motor_oil_madman
06/19/18 02:55 PM
"synthetic" gear oil and LS additive?
by nthach
06/19/18 01:54 PM
Supertech wix ST8 5514 miles
by jakewells
06/19/18 01:38 PM
Review - Sonax Spray and Seal.
by PimTac
06/19/18 01:36 PM
Lets Get a True Group 4 Sticky going!
by KMJ1992
06/19/18 12:17 PM
Rotella 10W40
by jakewells
06/19/18 10:43 AM
Extend WiFi Range at the Laptop?
by clarkflower
06/19/18 10:40 AM
Silicone containing waxes
by mjoekingz28
06/19/18 09:44 AM
Matrix totaled
by circuitsmith
06/19/18 08:32 AM
Door rust problems
by Dave Sherman
06/19/18 07:51 AM
2016 Honda Civic problems
by dbias
06/19/18 07:39 AM
Royal purple 75-140 in a subaru rear
by 91camarosRS
06/19/18 07:32 AM
OCI. With short trips. Nissan 4 liter
by Gawardawg
06/19/18 06:52 AM
Approach Watching on the Beach @ St Maarten ...
by LoneRanger
06/19/18 06:41 AM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
99 registered (28oz, 46Harry, 2oldtommy, 330indy, 87sammy, 9 invisible), 1571 Guests and 42 Spiders online.
65265 Members
67 Forums
285605 Topics
Page 1 of 2 1 2 >
#4686437 - 03/06/18 03:24 PM Corolla Verso 2004 1zz-fe - Best oil
Pre Offline
Loc: Norway
Hi,
I have a Corolla Verso 2005 1.8 VVT-i (1zz-fe). The car is using about one liter of oil per 1000 km driven. I have also tried seafoam in the crankcase for 180 km, and fed it thru the vacuum line and added to the gas. It did not help with the oil consumption. I have also raised the oil level to 10mm above the max on the dipstick.
Probably the engine is affected by the oil eating problems common for this engine. I suspect that the valve rings are stuck and therefore it is eating oil. Today I checked the PCV-valve, it made rattle sounds when I shaked it. But it was greasy from oil, so I have ordered a new one from the local Toyota dealer which will be here in two days.
Im also thinking about trying Auto-RX Plus with Castrol GTX Ultraclean 10w-40 for 4000 km and see if it helps.
Per now the car has been using Castrol Magnatec ACEA A5/ API SN (Fully synthetic) 5w-30 which is the recommended oil from Toyota. I have read in forums that using dino/semi synth and thicker oil than the recommended weight will clog up the piston oil ways, and deposit gunk in the motor and valve rings. So Im a bit skeptical to da a cleaning with Castrol GTX Ultraclean 10w-40 and Auto-RX Plus.
Does anyone have experience with this problem? And what oil does the 1zz-fe like (to not eat).
If anyone is interested the car's VIN is: NMTER16R90R013994
Milage: 126.000 km
Production date is mid 2004 in Turkey plant.
Edited by Pre (03/06/18 03:25 PM)
#4686445 - 03/06/18 03:36 PM Re: Corolla Verso 2004 1zz-fe - Best oil [Re: Pre]
pbm Offline
Loc: New York
I have a 2008 Corolla with that same engine and 110K miles....it seems to like 5w30 best and burns no oil in 5 to 6K of usage. I would try a MM or Seafoam soaking of the pistons (thru the spark plug holes) to see if it loosens up the rings.
'Journalism is Dead'
#4686457 - 03/06/18 03:47 PM Re: Corolla Verso 2004 1zz-fe - Best oil [Re: Pre]
Bud_One Offline
Loc: Spring,Texas
I had the 1ZZFE in my old 2003 Pontiac Vibe .
I had good results by using just SN rated 10W-30 oils.
Especially Chevron Supreme 10W-30 .
Didn't consume nearly as much as it did on 5W-30 oils, especially Mobil 1 , it drank that stuff like it was going out of style.
Don't know if you have access to Texaco/Havoline/Chevron oils.
Changing out the pcv valve might help as well.
Edited by Bud_One (03/06/18 03:50 PM)
16 Civic-M1 EP 0W-20, TG7317
14 Civic-M1 EP 0W-20, XG7317
05 Chevy 2500HD-QSUD 10W-30, XG3675
97 Accord Wagon-Havoline Conv 5W-30, PH3593A
#4686486 - 03/06/18 04:12 PM Re: Corolla Verso 2004 1zz-fe - Best oil [Re: pbm]
GlazeB Offline
Loc: Virginia
+1
5w30 works great in those motors!
2006 Toyota Corolla 270k
2005 Toyota Tacoma 137k
2008 Honda Pilot 101k
1978 Jeep Cj7
#4686493 - 03/06/18 04:20 PM Re: Corolla Verso 2004 1zz-fe - Best oil [Re: Pre]
Trav Offline
Loc: MA, Mittelfranken.de
The L4 is a perfect candidate for a piston soak. Get some GM 88861803 Upper Engine and Fuel Injector Cleaner from a GM dealer.
Do this before changing the oil, pull the plugs and make sure all pistons are down a little.
Put 4oz down each hole and screw the plugs in lightly then leave it overnight.
Disable the fuel and ignition (pull fuses), remove the plugs and crank the engine a few turns to push any remaining out of the plug holes.
Put it all back together and change the oil. Start it up let it warm then run it hard for a few min.
#4686532 - 03/06/18 05:12 PM Re: Corolla Verso 2004 1zz-fe - Best oil [Re: Trav]
Pre Offline
Loc: Norway
Thanks for the tip, can i use anything other than the GM cleaner? I'm in Norway and here there is not a lot of GM dealers. Also, how do i know if all the pistons are down a little?
#4686534 - 03/06/18 05:14 PM Re: Corolla Verso 2004 1zz-fe - Best oil [Re: Bud_One]
Pre Offline
Loc: Norway
Thank you! I dont have access to those oils but i will try a European brand 10w-30 smile
#4686553 - 03/06/18 05:36 PM Re: Corolla Verso 2004 1zz-fe - Best oil [Re: Pre]
Bullwinkle007 Offline
Loc: California
Castrol euro 0/40
#4686555 - 03/06/18 05:39 PM Re: Corolla Verso 2004 1zz-fe - Best oil [Re: Bullwinkle007]
Pre Offline
Loc: Norway
Can't find any oil with that name. Is it the same as Castrol Edge?
#4686597 - 03/06/18 06:22 PM Re: Corolla Verso 2004 1zz-fe - Best oil [Re: Pre]
SilverFusion2010 Offline
Loc: Crawfordville FL
Kerosene, marvel mystery oil, seafoam, breakfree clp, berrymans b12 chemtool.
Id use the berrymans or something like it
You can find the pistons with a small wooden dowel, or welding rod, even a screwdriver inserted into the spark plug hole.
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
#4686625 - 03/06/18 06:38 PM Re: Corolla Verso 2004 1zz-fe - Best oil [Re: Pre]
JohnnyJohnson Offline
Loc: Wet side WA
My 2004 Toyota Corolla started using oil after my OIC at 112K had never used oil before. It used a cup in the first 400 miles on QSUD 5w-30. I checked the PCV and it was pretty grimy. I didn't bother cleaning it because it had 30K on it. I swapped it out and the oil consumption stopped. It used a total of a little less than a half quart in 5030 miles. I just completed another OIC and used Valvoline 5W-30 Full Synthetic with Maxlife I'm approaching 1K on that oil change now with almost no oil consumption. Car now has 118258 miles on it. Seems to really like the Maxlife.
Edited by JohnnyJohnson (03/06/18 06:38 PM)
2004 Toyota Corolla 121598
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74016
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4686682 - 03/06/18 07:12 PM Re: Corolla Verso 2004 1zz-fe - Best oil [Re: Pre]
Trav Offline
No Opel dealers?
#4687209 - 03/07/18 08:43 AM Re: Corolla Verso 2004 1zz-fe - Best oil [Re: Trav]
Pre Offline
Loc: Norway
Opel in europe is now owned by the PSA group, but that happend recently. Will have a try at the Opel dealer 😊
#4687242 - 03/07/18 09:09 AM Re: Corolla Verso 2004 1zz-fe - Best oil [Re: JohnnyJohnson]
Pre Offline
Loc: Norway
Great! I will get the new pcv valve tomorrow. Hope it fixes it, i will also try Valvoline max life, but i can only find 5w-40 where i live. Will it be okay or should i find something else with 5w-40?
#4687308 - 03/07/18 09:58 AM Re: Corolla Verso 2004 1zz-fe - Best oil [Re: Pre]
Loc: Wet side WA
Check your local Walmart on line for a $35 order they will ship direct to your house.
It's $21.47 here online.
2006 Duramax 74016
Page 1 of 2 1 2 >
