Pennzoil Platinum 5w30 vs 10w30
by Snagglefoot
06/24/18 09:09 AM
LM MoS2. Honest, if not appropriately tested?
by wemay
06/24/18 09:03 AM
Brisket flat on charcoal
by 04SE
06/24/18 08:45 AM
Weird Oil level question
by audia6
06/24/18 08:27 AM
DNA test and opening a can of worms
by WhyMe
06/24/18 08:11 AM
Ghetto testing a wheel speed sensor
by Nayov
06/24/18 06:23 AM
dash cam
by DAC2018
06/24/18 05:08 AM
WoO driver Jason Johnson injured
by bdcardinal
06/24/18 01:08 AM
Plastic burning smell when WOT
by Jaha24k
06/24/18 12:57 AM
Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
06/24/18 12:00 AM
Ruger LCP .380
by PW01
06/23/18 11:24 PM
Launching boat with stick shift
by troutfisher
06/23/18 11:22 PM
Free oil
by Spitter
06/23/18 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
06/23/18 10:04 PM
RC cars
by red7404
06/23/18 09:36 PM
Any Good 4K Movies ?
by Warstud
06/23/18 09:06 PM
Gray on Oil Dipstick?
by chinee
06/23/18 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
06/23/18 08:15 PM
Parking wars show.
by Chris142
06/23/18 08:15 PM
set for years
by 93cruiser
06/23/18 08:07 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
85 registered (04SE, 87sammy, 2015_PSD, 2004tdigls, 14ecocruze, 8 invisible), 1324 Guests and 46 Spiders online.
65303 Members
67 Forums
285897 Topics
Page 1 of 2 1 2 >
#4686033 - 03/06/18 08:58 AM Toyota Red vs Pink
Gebo Offline
Loc: VA
Ok, I know you can top off pink with red but you can't top off red with pink. Red is concentrated and pink is 50:50. Pink is not just red diluted with distilled water. I think Toyota switched over to the pink around 2002.
My feeling is that the red is better than the pink and that the pink was formulated to satisfy some kind of EPA requirement or for Toyota to make more money. Note, I said "my feeling." I have read on Toyota forums where some are switching from the pink to the red in their newer models. 2 Toyota mechanics said that's what they do. They say the red is the bomb.
Does anyone know if I could be prolonging the life of my car's coolant system by switching from pink to red? Does anyone know the chemical makeup difference between the Toyota Red and Toyota Pink other than one is concentrated and one is diluted?
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
#4686085 - 03/06/18 10:03 AM Re: Toyota Red vs Pink [Re: Gebo]
Reddy45 Offline
Loc: USA
Pink is only sold as ready to use right? (50:50 mix)
#4686087 - 03/06/18 10:04 AM Re: Toyota Red vs Pink [Re: Gebo]
ARB1977 Offline
Loc: North Texas
If you dilute red it turns pink. If it calls for red use red or vise versa.
2015 Tacoma 4.0L 60K (as of 02/23/18)
Amsoil SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Factory filter
#4686111 - 03/06/18 10:34 AM Re: Toyota Red vs Pink [Re: Gebo]
CR94 Offline
Loc: Western S.C. since 1996
Pink lasts longer before needing to be replaced, according to Toyota.
2011 Toyota Prius now at 88K
#4686123 - 03/06/18 10:46 AM Re: Toyota Red vs Pink [Re: Reddy45]
Sayjac Offline
Loc: The Old North State
Correct. Same as the other majority OEM Asian PHOATS, eg. Honda Type2, Nissan Long Life blue and others. One aftermarket exception is Pep Boys OEM Brand Concentrate available in four tints.
Unlike the Toyota Red which is only recommended for 2years/~30k miles, the SLL pink is ~5 years/50k miles interval on subsequent to factory service. That's similar to the other current OEM Asian AFs.
As for topic, as search of bitog would indicate been discussed at length several times. Toyota says the pink is backward compatible with the red however to get the longer service interval a complete exchange should be done. I'm not much on feelings and hearsay, seen no evidence Red better for radiator/system life. Otoh, if one just prefers to use the shorter service interval red, use it. These parts it's pricey now.
Personally been using Peak Global Lifetime concentrate in an 01 Tacoma with original radiator for several years, working fine.
#4686147 - 03/06/18 11:05 AM Re: Toyota Red vs Pink [Re: Gebo]
Gebo Offline
Loc: VA
Mods, please close and remove this post. I want to repost with a more clear question.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
#4686200 - 03/06/18 11:49 AM Re: Toyota Red vs Pink [Re: Gebo]
Kamele0N Online   sick
Loc: Slovenia
I am not fan of pink coolants...since I can read that Toyotas have WP leak because of them (topic from yesterday here on BITOG)...plus vw had recalls in 90's because of head gasket leaks because of pink G12...
So to answer your question...I am switching my Toyota to blue/green G11 in Spring...and I am planning to change it on every 2-3yrs...1kz-te engine has very sensitive cooling system though.(the end result could be that you have cracked engine head)
And be adviced (at least here in EU) you can have 4different pink antifreezes... G12 G12+ G12++ and G13... And some of them can not be mixed...
Edited by Kamele0N (03/06/18 12:05 PM)
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD various 10w40
#4686206 - 03/06/18 11:54 AM Re: Toyota Red vs Pink [Re: Gebo]
Loc: Slovenia
Plus that words as "longlife" "sealed for life"or "lifefill" doesnt exist in my vocabulary smile
#4686235 - 03/06/18 12:16 PM Re: Toyota Red vs Pink [Re: Sayjac]
Sayjac Offline
I thought the 'weep hole' anecdote(s) might get posted as regards Toyota SLL Pink use so saved this previously posted information courtesy of member King Cake on the topic. This is what Toyota has to say on the matter.
#4686286 - 03/06/18 01:01 PM Re: Toyota Red vs Pink [Re: Gebo]
nthach Offline
Loc: California
The chemistry is different - SLLC pink uses sebacate as the organic acid. Zerex's Asian formula uses benzoate as the organic acid and it does meet Toyota's pHOAT requirements.
I'm now thinking the red LLC formula doesn't have an organic acid - just phosphate, molybdate, nitrate and an azole for solder protection. I'll have to dig through Google Patents for CCI to see if there was a patent filed. I was under the thought LLC red has benzoate as the organic acid but the Japanese back in the 1980s when Toyota first used a non-silicated coolant didn't jump on the hybrid OAT bandwagon like Germans did with BASF's Glysantin formulas. Except G-05, G-48 and now G-40 are SiHOAT formulas using benzoate or 2-EHA as the organic acid.
Toyota didn't add the below line in the owner's manual until 2004 with the 2nd gen Prius and the refreshed LS430 before it was made standard on all their production lines:
Quote:
"Toyota Super Long Life Coolant” or similar high quality ethylene glycol based non-silicate, nonamine, non-nitrite and non-borate coolant with long-life hybrid organic acid technology
#4686309 - 03/06/18 01:27 PM Re: Toyota Red vs Pink [Re: Gebo]
Yah-Tah-Hey Offline
Loc: Columbus,Nebraska
The pink OEM is a much better product. Available at Walmart as Valvoline Asian Vehicle Coolant.
#4686439 - 03/06/18 03:26 PM Re: Toyota Red vs Pink [Re: Gebo]
pbm Offline
Loc: New York
I seen 2 new products at Walmart today....Prestone for Toyota's and Prestone for Honda's and Nissan's....they came in 1/2 gallon containers and sold for $6.97....they were 50/50 mixes....
Here's a link I found for these products at AA:
https://shop.advanceautoparts.com/p/pres...mp;gclsrc=aw.ds
https://shop.advanceautoparts.com/p/pres...stone+for+Honda
'Journalism is Dead'
#4686678 - 03/06/18 07:11 PM Re: Toyota Red vs Pink [Re: nthach]
Gebo Offline
Loc: VA
nthach,
This is the type of information I'm looking for. With your knowledge base, did Toyota change internal engine metals in 2002? In other words, why do you think they went from Red to Pink? What is in the post 2002 Toyota engines need the organic acids? Or do they? I'm merely trying to learn...
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
#4686752 - 03/06/18 07:59 PM Re: Toyota Red vs Pink [Re: nthach]
Loc: Slovenia
@nthach...
http://www.glysantin.de/en/products.html
If you click @more under G48(green/blue G11) and G30 (red/pinky G12+?)... You will see that they are the only 2 with Toyota spec.
#4686964 - 03/06/18 10:49 PM Re: Toyota Red vs Pink [Re: Kamele0N]
nthach Offline
Loc: California
Originally Posted By: Kamele0N
@nthach...
Toyota hasn't approved those at all - and G30/G40/G48 aren't at all phosphated HOAT coolants.
However, if you look at the info sheet for Zerex Asian Formula or the label, there's a patent that's referenced. BASF holds that patent and internally at Valvoline/BASF, it's known as G69-91/G70.
http://www.luisa.com.gt/sites/default/files/zerex_asian_vehicle.pdf
https://patents.google.com/patent/US5454967
Page 1 of 2 1 2 >
