RC cars
by red7404
06/23/18 09:36 PM
Any Good 4K Movies ?
by Warstud
06/23/18 09:06 PM
Gray on Oil Dipstick?
by chinee
06/23/18 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
06/23/18 08:15 PM
Parking wars show.
by Chris142
06/23/18 08:15 PM
set for years
by 93cruiser
06/23/18 08:07 PM
Looking to replace 2005 Sienna with SUV
by i6pwr
06/23/18 07:26 PM
Trying to fix chainsaw
by turtlevette
06/23/18 06:48 PM
tire rotation
by marine65
06/23/18 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
New belt squeal cause damage to belt?
by pda1122
06/23/18 05:33 PM
Food Safety - If You Have Children
by Zee09
06/23/18 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
06/23/18 05:02 PM
Chain cleaning and lube
by dadinfo
06/23/18 04:57 PM
Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
06/23/18 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
06/23/18 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
06/23/18 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
06/23/18 04:30 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
108 registered (AITG, 2015_PSD, AP9, ARB1977, 10 invisible), 1463 Guests and 33 Spiders online.
65303 Members
67 Forums
285881 Topics
Page 1 of 2 1 2 >
#4685858 - 03/06/18 02:03 AM 1NZ-FE engine spinning away on a long trip
OneEyeJack Offline
Loc: S California
Just drove from Carlsbad, CA to Phoenix and back for just under 800 miles in my new to me 2006 Scion xB with now 135K miles. For a large part of the trip out in the desert, the speeds were between 70 and 80 mph and that meant up to 4K rpm for a driving time of just over 12 hours round trip.
I'm still getting used to spinning that 1.5L engine that fast but evidently it's doing okay connected to a 5-speed manual transmission. I'm using Red Line 0w-30 engine oil and Red Line MT-90 in the transmission. The oil level was checked several times and the level dropped less than the width of the Full line on the dipstick, maybe 1/32".
The previous owner has service records for 3K OCI's with Castrol GTX conventional 5w-30.
I hope this xB will last as long as my 84 Honda wagon. I'm thinking of putting a piece of tape over the tach lol.
#4685862 - 03/06/18 02:30 AM Re: 1NZ-FE engine spinning away on a long trip [Re: OneEyeJack]
hpb Offline
Loc: Tasmania, Australia
Don't worry about it - small engines rev hard, they're designed to do it smile
MY16 Mitsubishi Outlander 2.2 diesel, 47,000km - Castrol 5w30
2006 Ford Falcon 4.0, 132,000km - Penrite Vantage 15w40, Ryco filter
#4685876 - 03/06/18 03:55 AM Re: 1NZ-FE engine spinning away on a long trip [Re: OneEyeJack]
Olas Offline
Loc: Manchester, England
In development, engines are run at full load and max rpm for hundreds of hours continuously.
Your trip was nothing but gentle exercise and your engine hardly broke sweat.
Cable ties should hold it
#4685888 - 03/06/18 04:22 AM Re: 1NZ-FE engine spinning away on a long trip [Re: OneEyeJack]
Char Baby Offline
Loc: ROCHESTER, NY
Right, everything sounds fine in your description however, the tranny in these cars are limited but, 4K RPM is nothing! If Toyota used a 6 spd manual, you may have been downshifting more often just to make any power in these little engines...anyway!
Edited by Char Baby (03/06/18 04:44 AM)
"Retired"
'06 Mazda 3i 2.0L
'15 Nissan Altima 2.5 SV
#4685909 - 03/06/18 05:51 AM Re: 1NZ-FE engine spinning away on a long trip [Re: OneEyeJack]
Snagglefoot Offline
Loc: Alberta
There’s one way to reduce the RPM and that is to slow down, LOL
#4685973 - 03/06/18 07:46 AM Re: 1NZ-FE engine spinning away on a long trip [Re: OneEyeJack]
pandus13 Offline
Loc: Chicago,IL,USA
NO NO NO NO NO and NO!
You got it all wrong.
You now have an engine that just "open herself" (is XBOX/BOX masculine or feminine?)
Enjoy a more responsive hamster wheelie.
My Yaris, open pretty good after going up and down the Smokies last fall.
And the tach problem it's easy: just look at the road ? :-P (Pictures or it didn't happen)
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
#4685986 - 03/06/18 07:59 AM Re: 1NZ-FE engine spinning away on a long trip [Re: OneEyeJack]
tcp71 Offline
Loc: Alberta
Motorcycle engines of almost the same displacement run much higher at highway speeds. 4K is fine.
#4685997 - 03/06/18 08:09 AM Re: 1NZ-FE engine spinning away on a long trip [Re: OneEyeJack]
kschachn Online   content
Loc: Upper Midwest
I use my ECHO for commuting to work and back, and for a large portion of the trip I'm traveling at the speeds you mention or more. My 1NZ-FE hasn't died yet so I doubt yours will either any time soon.
You have a tachometer? Nice, my ECHO does not (but I do also have the 5-speed).
1994 BMW 530i, 227K
1996 Honda Accord, 262K
1999 Toyota Sienna, 394K
2000 Toyota ECHO, 267K
#4686019 - 03/06/18 08:37 AM Re: 1NZ-FE engine spinning away on a long trip [Re: OneEyeJack]
supton Offline
Loc: NH
I'd proactively replace the engine--you can never be too careful with these sorts of things. I mean, that's a lot of rpm. Ships cross the Atlantic all the time with a max rpm of what, 100rpm? You've overstressed that engine, and I doubt it'll make it down the block now.
2011 Toyota Camry, base, 2.5L/6MT, 162k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 143k, ours
1999 Toyota Camry LE, 2.2L/4AT, 183k, his
#4686095 - 03/06/18 10:17 AM Re: 1NZ-FE engine spinning away on a long trip [Re: OneEyeJack]
Claud Offline
Loc: Margate England
I used to run my 1.05 liter Vauxhall up and down UK main roads back in the 1970's. This might mean a steady 70mph for several hours, which was around 5000 rpm.I used 20w50 of whatever brand was on sale for 3k oci's. It ran up around 1o0k miles without complaint or developing and appetite for oil, and carried on for a few more years more gentle use when I gave it to my sister. Terminal rust ended its life at about 12 years old, not a bad lifespan for a British car built in 1963.
Claud.
#4686126 - 03/06/18 10:48 AM Re: 1NZ-FE engine spinning away on a long trip [Re: OneEyeJack]
Joshua_Skinner Offline
Loc: Portland, Oregon
The math says 3100 RPM at 60, 3617 @ 70 MPH, 3875 @ 75 MPH, and 4133 @ 80 MPH. Engine torque peak is 101 ft/lbs at 4200. HP is 103 at 6000. Seems about right for the vehicle and typical driver who doesn't like to downshift when they really should.
2015 Nissan Frontier S King Cab, 2.5L, 5MT
Pennzoil Platinum 5W-30 in the crankcase. Red Line in the gearboxes.
#4686128 - 03/06/18 10:49 AM Re: 1NZ-FE engine spinning away on a long trip [Re: Claud]
CR94 Offline
Loc: Western S.C. since 1996
Originally Posted By: Claud
I used to run my 1.05 liter Vauxhall up and down UK main roads back in the 1970's. ...
Before circa 1975 or so, it was typical for engines of small furrin cars to spin near 4000 RPM at 60 mph, even with push-rod engines. My 1267cc Subaru, for example.
Edited by CR94 (03/06/18 10:52 AM)
2011 Toyota Prius now at 88K
#4686132 - 03/06/18 10:54 AM Re: 1NZ-FE engine spinning away on a long trip [Re: OneEyeJack]
IndyIan Offline
Loc: Ontario, Canada
The Yaris 5spd is supposed to lower the rpms a bit. You could also go to a taller tire for a 3-4-5% difference, the only real issue is how tall 1st is. My winter tire set results in 4.5% taller gearing vs my summer tires, and 1st in the Focus is fairly tall to begin with so it results in a bit more clutch slip starting on hills for sure.
07 Focus ZXW, 5spd manual, 206km M1 5W30
18 Outback 2.5 CVT 5km FF
#4686144 - 03/06/18 11:02 AM Re: 1NZ-FE engine spinning away on a long trip [Re: CR94]
Claud Offline
My point was this approaching the cars maximum speed, it was probably over 5000 rpm at 70mph.
#4686149 - 03/06/18 11:06 AM Re: 1NZ-FE engine spinning away on a long trip [Re: OneEyeJack]
KrisZ Offline
Loc: Toronto, Canada
No need to worry about high RPM by itself, however proper oil level is more critical.
2015 Dodge Grand Caravan-21k miles.
2006 Mazda 3-155k miles
Page 1 of 2 1 2 >
