Cycling health
by CourierDriver. 09/25/18 06:08 AM
Stupidest thing you've ever done (or not done)
by Speak2Mountain. 09/25/18 06:01 AM
First Time Hyundai Owner - Coolant Confusion
by tony1679. 09/25/18 05:16 AM
European Formula: Supertech and Mobil 1
by Snagglefoot. 09/25/18 02:19 AM
KFE brake pads?
by deoxy4. 09/25/18 01:16 AM
GM Marine Engine wont start
by Gito. 09/24/18 11:59 PM
New TV bad picture some channels part2
by raaizin. 09/24/18 10:46 PM
Another Bad PCM on a Buick 3.8L!
by clinebarger. 09/24/18 10:17 PM
Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
46 registered members (Bailes1992, Anthony, BretK, Brad_C, BigCahuna, alarmguy, 4 invisible), 1,023 guests, and 38 spiders.
Topics290,971
Posts4,853,543
Members66,063
Most Online3,590
Jan 24th, 2017
Good Info On Antifreeze #4681733
03/01/18 08:03 PM
03/01/18 08:03 PM
MIchigan
Warstud Offline OP
Warstud  Offline OP
MIchigan
You should all listen to this video as CRP Automotive's Pentosin Brand Director Mark Malone talks Antifreeze/Coolant
Re: Good Info On Antifreeze [Re: Warstud] #4681901
03/02/18 12:28 AM
03/02/18 12:28 AM
southern mo
ram_man Offline
ram_man  Offline
southern mo
Cool video thank you for sharing
2014 dodge dart GT
1995 Dodge ram 1500
Re: Good Info On Antifreeze [Re: Warstud] #4681922
03/02/18 01:39 AM
03/02/18 01:39 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Excellent. Thanks.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Good Info On Antifreeze [Re: Warstud] #4682022
03/02/18 08:37 AM
03/02/18 08:37 AM
VA
Gebo Offline
Gebo  Offline
VA
Thank You! Very interesting.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 58K
Amsoil in all engines, transmissions and differentials
Re: Good Info On Antifreeze [Re: Warstud] #4682056
03/02/18 09:33 AM
03/02/18 09:33 AM
Lakeside, CA
Blkstanger Offline
Blkstanger  Offline
Lakeside, CA
This video makes me want to go change my "Coolant"
99 Jeep WJ 4.7 190,000 Maxlife 10w30, Fram Ultra.
Re: Good Info On Antifreeze [Re: Warstud] #4682419
03/02/18 04:09 PM
03/02/18 04:09 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
When I was in power generation, I used boiler condensate to mix with anti-freeze.
Re: Good Info On Antifreeze [Re: Warstud] #4682961
03/03/18 07:49 AM
03/03/18 07:49 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Not a bad video, however 'imo' clearly made from the Pentosin/Pentofrost point of view and based on their product offerings.
OAT AF's do not require or need an inorganic acid like silicate or phosphate to make an effective AF. Dexcool, Peak Global Lifetime and the newer FCA/Mopar OAT are examples of AFs with no inorganic acid. Afaik, Pentosin offers no similar OAT AFs.
Also missed the first time I watched, he says 'DI water is what they recommend, can use distilled but it still contains minerals'. Based on my experience, I say phooey to that. Distilled water works just fine, is readily available and inexpensive. Also what some of the vehicle manufactures recommend when doing a flush or mixing with a concentrated AF.
Re: Good Info On Antifreeze [Re: Sayjac] #4684720
03/05/18 12:24 AM
03/05/18 12:24 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Distilled water contains minerals?!? Lol.
They must be talking some very low concentrations.
DI water when made will have a resistance of about 18MOhm. It quickly drops, not due to minerals but due to CO2 in the air.
Some say DI strips minerals, because it has none and can become slightly acidic due to carbonic acid of some sort. I don't know the truth.
But I do know if it's distilled properly, the mineral,content should be minuscule.
