'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
34 registered members (Bailes1992, ChrisD46, ArrestMeRedZ, ctechbob, billt460, Dave9, 2 invisible), 551 guests, and 56 spiders.
Topics286,049
Posts4,901,475
Members67,551
Most Online2,967
Mar 10th, 2019
Coil pack going bad? #4679533
02/27/18 10:49 AM
02/27/18 10:49 AM
Alabama
NavyVet88 Offline OP
Alabama
2003 Buick Century 3.1L
Here lately ive noticed that first starting the car after a few days without running, the car is temperamental about starting. By that I mean it takes two or three tries to get it started. The engine turns over just fine, but it doesn't actually start until mostly the 3rd and sometimes 4th try.
The motor was replaced about a year ago(used of course) just after I got the car and it was starting just fine at the time. Battery was replaced at the same time. Is this a coil pack going bad?
Thanks guys,
2013 Honda Civic LX 1.8L 140k M1 HM 0w20 with Fram XG7317
2003 Buick Century 3.1L 196k Maxlife 5W-30 with Fram TG3387A
Maintenance Mechanic by trade, working class for life.
Re: Coil pack going bad? [Re: NavyVet88] #4679548
02/27/18 11:01 AM
02/27/18 11:01 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
Load test the battery?
Check the Starter?
  • 2017 Toyota Sienna
Re: Coil pack going bad? [Re: NavyVet88] #4679579
02/27/18 11:42 AM
02/27/18 11:42 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
If it is only after sitting for a couple days, I would think the fuel pressure is not being maintained in the system when off. Could be a bad check valve in the fuel pump assembly. Try turning the key to the on position a couple times before starting to let the fuel system prime.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Coil pack going bad? [Re: NavyVet88] #4679582
02/27/18 11:48 AM
02/27/18 11:48 AM
Rockwall, Texas
Old Mustang Guy Offline
Rockwall, Texas
When I had a coil pack going out the car still started fine but ran rough.
Re: Coil pack going bad? [Re: mightymousetech] #4679597
02/27/18 12:01 PM
02/27/18 12:01 PM
Alabama
Alabama
Well the car only gets driven a couple times a week for groceries and such or quick errands. I failed to mention in my opening post that once the engine does start, it struggles to get going unless you press the gas pedal a bit to help it.
Re: Coil pack going bad? [Re: NavyVet88] #4679598
02/27/18 12:03 PM
02/27/18 12:03 PM
Ontario, Canada
Ontario, Canada
Could be just plugs. When were they replaced last?
Mighty Mouse Tech
Re: Coil pack going bad? [Re: mightymousetech] #4679608
02/27/18 12:15 PM
02/27/18 12:15 PM
Alabama
Alabama
About 6 months ago. Oem plugs to boot.
About 6 months ago. With oem plugs.
Re: Coil pack going bad? [Re: NavyVet88] #4679610
02/27/18 12:17 PM
02/27/18 12:17 PM
Alabama
Alabama
Could it be the throttle body?
Re: Coil pack going bad? [Re: mightymousetech] #4679624
02/27/18 12:26 PM
02/27/18 12:26 PM
WI
BurrWinder Offline
BurrWinder  Offline
WI
[quote=mightymousetech]If it is only after sitting for a couple days, I would think the fuel pressure is not being maintained in the system when off. Could be a bad check valve in the fuel pump assembly. Try turning the key to the on position a couple times before starting to let the fuel system prime.
I have a feeling that you most likely have a leaking fuel pressure regulator on the fuel rail, this is a fairly common problem on these engines and is easily diagnosed - remove the vacuum hose going to it on the fuel rail and inspect for any raw fuel vapors / liquid coming out of the regulator ( or filling the vac. line, if failed bad enough ) Just key up the vehicle ignition, ( cycle on but don't start car ) a few times after sitting ( for a bit )
with the vacuum line off... any liquid fuel that comes out and it is automatically a failed part.
The result of this is hard starting as it is too rich from the leaking fuel from the regulator, causing a hard start.
I would put a large bet on this being your failure, esp. at the miles accrued and if it never has been replaced before...
BurrWinder
Re: Coil pack going bad? [Re: BurrWinder] #4679630
02/27/18 12:31 PM
02/27/18 12:31 PM
Alabama
Alabama
BurrWinder
Thank you sir I will check this this weekend when off work.
Re: Coil pack going bad? [Re: NavyVet88] #4679660
02/27/18 01:16 PM
02/27/18 01:16 PM
Rockwall, Texas
Rockwall, Texas
When I had a throttle body go bad the symptoms were in fact like you describe.
Re: Coil pack going bad? [Re: mightymousetech] #4679720
02/27/18 02:47 PM
02/27/18 02:47 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
This is where to start trouble shooting.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Coil pack going bad? [Re: NavyVet88] #4679726
02/27/18 02:53 PM
02/27/18 02:53 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Thanks guys,
How old do you think those sparkplugs in the used engine were? Maybe pull and plug and have a look. Spark plug wires also eventually should be changed. Spray a bit of water on the coil pack to see if there are cracks in the coil pack that you might be able to short out as evidence of a problem.
If you want the job done right......do it yourself.
Re: Coil pack going bad? [Re: NavyVet88] #4679772
02/27/18 03:50 PM
02/27/18 03:50 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Throttle body
Fuel pressure
MAF sensor
leaky injector
Thats what I would look into
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Coil pack going bad? [Re: NavyVet88] #4679821
02/27/18 05:44 PM
02/27/18 05:44 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Fuel pressure regulator.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
