Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
new tire 4 years old
by 1978elcamino. 04/19/19 08:51 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
103 registered members (Astro14, ABCarr, AandPDan, Al, 2004tdigls, andyd, 10 invisible), 2,242 guests, and 30 spiders.
Topics287,749
Posts4,933,775
Members67,850
Most Online2,967
Mar 10th, 2019
Most PEA means best fuel cleaner? #4679113
02/26/18 08:37 PM
02/26/18 08:37 PM
canada
apollo18 Offline OP
apollo18  Offline OP
canada
I've been reading around for the best fuel system cleaner and isn't the best fuel system cleaner basically the one with the most PEA? Seems like 3M or Gumout has the most. Or is techron/redlime the best because of the certain blend
Thanks
Re: Most PEA means best fuel cleaner? [Re: apollo18] #4679128
02/26/18 08:47 PM
02/26/18 08:47 PM
Ont Canada
Koz1 Offline
Koz1  Offline
Ont Canada
What I have seen with fuel injector cleaner is high PEA thickens my oil. It has happened several times. So I dont use it. A lot of people love it though.
Currently using, Fuchs TITAN GT1 PRO FLEX 5W-30, M1 5W-20 and Castrol Edge 0W-20 Gold B.
Re: Most PEA means best fuel cleaner? [Re: apollo18] #4679140
02/26/18 08:57 PM
02/26/18 08:57 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Generally yes but for varnish issues in carbs commonly found on small engines Chemtool is far more effective. Both work better when used as a preventative rather than a cure.
Re: Most PEA means best fuel cleaner? [Re: apollo18] #4679160
02/26/18 09:15 PM
02/26/18 09:15 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
its not that big a deal which has the "most PEA"
If you think more is better just use the 20oz bottle in 12 gallons of gas instead of the 12oz bottle.
As long as you use major name brand good products.. and not the diluted versions.
Re: Most PEA means best fuel cleaner? [Re: Koz1] #4679163
02/26/18 09:16 PM
02/26/18 09:16 PM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
Heh Heh The stuff you're running can stand a little thickening. I'm pretty sure Regane helped clean something out in my wife's '86 5283 once mebbe 15 yrs ago. I used to run a bottle through the cars once a yr. I stopped due to not noticing any difference. BMW EFI was very robust and I always buy gas from high volume stations Occasional Italian tuneups kept the pistons and valves clean enough. I keep a can of B 12 Chemtool on hand for the OPE carbs and MMO for the fun of it
Thick oil is better grin2
Re: Most PEA means best fuel cleaner? [Re: apollo18] #4679182
02/26/18 09:34 PM
02/26/18 09:34 PM
workbench CZ-USA KS KC
Marco620 Offline
Marco620  Offline
You could micro dose with Gumout Regane or Redline Si-1 and still reap benefits. Once I used it to clean full throttle and bottle after should last a long time. Got 142000 miles on a 15 Civic I bought in 2016 and we see no deposits when we take it down. Throttle body is sprayed with CRC GDi cleaner every 75k and use only ethanol free fuel or 93 E10 mixed with 87 Pure in Leavenworth,KS. Only run 93 at 50 percent to keep octane up when racing around.
15' Civic 1.8 i-vtec 229,500 mi Redline oil & M1 3:1/BP transmax cvt fluid & Archoil9100
Say no to drugs, union made cars and amsoil.
Son of a Navy Corpsman. Support vets!
Re: Most PEA means best fuel cleaner? [Re: Marco620] #4679205
02/26/18 09:50 PM
02/26/18 09:50 PM
South Carolina
bmwtechguy Offline
bmwtechguy  Offline
South Carolina
I have used Redlime grin in the past, but now I have stocked up enough on Gumout Regame grin at about half price and I use it for preventative maintenance just before oil changes on our vehicles. On a vehicle that has had no fuel system cleaner in a long while, sometimes I dump in 2 bottles for a quick cleanup.
Re: Most PEA means best fuel cleaner? [Re: Rand] #4679216
02/26/18 09:55 PM
02/26/18 09:55 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Especially if you are only buying Top Tier fuels...
then you don't need the extra bottles of injector cleaner.
Re: Most PEA means best fuel cleaner? [Re: Linctex] #4679232
02/26/18 10:08 PM
02/26/18 10:08 PM
Marco620 Offline
Marco620  Offline
Top Tier doesnt clean GDi. You need N2 PEA based fuel cleaners and a PEA based throttle body cleaner from Gumout or CRC.
Re: Most PEA means best fuel cleaner? [Re: Rand] #4679244
02/26/18 10:15 PM
02/26/18 10:15 PM
CA
CharlieBauer Offline
CA
Agree. Follow the instructions and you'll be using the right amount.
There is no need to use double the dosage because PEA has a maximum effectiveness level and double dosage is beyond that.
If you use two bottles, best to use them in back to back tanks not in a single tank.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Most PEA means best fuel cleaner? [Re: apollo18] #4679246
02/26/18 10:17 PM
02/26/18 10:17 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
What specifically are you trying to clean? Carbon deposits? Or just keep the pumps, lines, and injectors free flowing?
Re: Most PEA means best fuel cleaner? [Re: apollo18] #4679392
02/27/18 07:04 AM
02/27/18 07:04 AM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
I would use a name brand PEA and follow the directions. I think Techron says once per oil change.
2015 Ford F250 w/Powerstroke
Re: Most PEA means best fuel cleaner? [Re: Marco620] #4679395
02/27/18 07:07 AM
02/27/18 07:07 AM
Trav Offline
Trav  Offline
I run Redline approx 2oz to 15gal of fuel, the injectors are nice and clean with good flow and spray pattern after now more than 50K on previously cleaned injectors, they required no addition service and STFT still hover around zero. Pretty good stuff I would say.
On another car that has only ever seen top tier since new and no additives I am curious to see how they are but with only 5K on the clock its going to take some years.
Re: Most PEA means best fuel cleaner? [Re: Koz1] #4679442
02/27/18 08:38 AM
02/27/18 08:38 AM
Massachusetts
deven Offline
deven  Offline
Massachusetts
Just use the fuel injector cleaner right before an oil change then and problem solved.
Proud user of ROYAL PURPLE products!
2019 BMW 330i X-drive(Factory Fill)
KEEP IT SIMPLE STUPID. IT'S ONLY OIL
Re: Most PEA means best fuel cleaner? [Re: deven] #4680962
02/28/18 08:33 PM
02/28/18 08:33 PM
Ont Canada
Koz1 Offline
Koz1  Offline
Ont Canada
Its probably vehicle, driving, oil and fuel dependent. If the product thickens the oil greatly, its definitely not good for the oil at all. It has been the only time my oil went this way so I just will not use it. Sure it will clean my engine but it kills my oil which I really dont ever want to do.
