CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
115 registered members (14Accent, 1WildPig, 38Chevy454, 240_Ed, 380SLbenz, 10 invisible), 2,113 guests, and 53 spiders.
Topics286,202
Posts4,904,104
Members67,576
Most Online2,967
Mar 10th, 2019
Question on Hydraulic Timing Chain Tensioners #4676853
02/24/18 07:55 PM
02/24/18 07:55 PM
Midwest USA
LoneRanger Offline OP
Midwest USA
Occasionally get a rattle upon start up that clears in a couple seconds. The Guzzi has a Morse timing chain with hydraulic tensioners. Could it be a tensioner bled down that's the source of this momentary rattle?
'09 Subaru Forester ...................(QS HM 5W30)
'16 Moto Guzzi Stelvio 1200 .....(ENI i-Ride PG 10W60)
Re: Question on Hydraulic Timing Chain Tensioners [Re: LoneRanger] #4676859
02/24/18 07:59 PM
02/24/18 07:59 PM
IL
Vern_in_IL Offline
Vern_in_IL  Offline
IL
could be a bad ADBV in the oil filter.
Re: Question on Hydraulic Timing Chain Tensioners [Re: LoneRanger] #4676860
02/24/18 08:01 PM
02/24/18 08:01 PM
southern mo
ram_man Offline
ram_man  Offline
southern mo
What kind of oil filter could be a tensioner but don't overlook the filter.
2014 dodge dart GT
1995 Dodge ram 1500
Re: Question on Hydraulic Timing Chain Tensioners [Re: LoneRanger] #4676864
02/24/18 08:07 PM
02/24/18 08:07 PM
USA
oldhp Offline
oldhp  Offline
USA
I always thought the tensioner had some kind of a mechanical device to hold the slack when engine was shut off. No?
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: Question on Hydraulic Timing Chain Tensioners [Re: LoneRanger] #4676910
02/24/18 08:52 PM
02/24/18 08:52 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
I know my Mercedes has a ratcheting mechanism to take up any slack.
Re: Question on Hydraulic Timing Chain Tensioners [Re: Kestas] #4677023
02/24/18 10:33 PM
02/24/18 10:33 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
So do all the Ford 4.6 and 5.4 engines.
Many engines do.
Re: Question on Hydraulic Timing Chain Tensioners [Re: LoneRanger] #4677165
02/25/18 01:53 AM
02/25/18 01:53 AM
The Canyons
02SE Offline
02SE  Offline
The Canyons
Your bike is pretty new, and the most wear to the sprockets and timing chain occur in the first few thousand miles. The plunger has teeth along it's length (the ratchet mechanism mentioned) and as the initial wear to the chain and sprockets occurs, at some point the tensioner will be between being loose on one tooth, but not yet able to click to the next tooth. So there is that slack in the chain when the engine is first started, but before the oil pressure can press the tensioner against the camchain guide, and take up the slack.
Long story short: Eventually the chain and sprockets will wear just enough for the tensioner to click to the next tooth, and the momentary rattle before oil pressure builds, will cease. At that point the chain and sprockets will wear at a very slow rate from then on.
Sometimes the tensioners can go bad, but that's rare. So I wouldn't worry about it.
Re: Question on Hydraulic Timing Chain Tensioners [Re: 02SE] #4678316
02/26/18 01:31 AM
02/26/18 01:31 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
+1 on 02SE's comments. My Busa went through the same thing with the updated ratcheting/oil pressure feed CCT.
Re: Question on Hydraulic Timing Chain Tensioners [Re: LoneRanger] #4678418
02/26/18 07:45 AM
02/26/18 07:45 AM
Midwest USA
Midwest USA
Thanks for the info, that makes sense.
