In the last couple of months I've machined the rotors on a couple of my cars...and used the old pads. Someone did previous pad changes without machining, so doing a catch up. It takes a couple of hundred km's for the surfaces to match again...no problems.
Originally Posted By: ARCOgraphite
Are not rear rotors thin to begin with. You sure you need rear rotors they don't heat up much on a compact passenger car.
Rear disc brake = high cost and headache that didn't exist with rear drums!
NO Benefit on the average car, only downside for consumer and $$$ UPSIDE for dealers and garages.
There is absolutely no reason to replace the pads if they have > 50% remaining and do not show signs of heat damage. Place a sheet of 80 grit sandpaper on a hard, flat surface and run the pad on the sheet until the pad glazing is removed and the pad is flat again.
Disc brakes are MUCH easier to service than drums
Ive NEVER had to service rears at 40k now its normal. Way undersized pads. Ripoff and on purpose by Asian auto manufacturers. Yes YOU Honda and Nissan! Part of it is the ASC TS over use of rear brakes for vector correction; If you are going to overuse them, beef them up!
+1
additionally I checked thickness on all 4 corners with digital caliper.. they were close enough... = reinstall
