CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
126 registered members (14Accent, 1WildPig, 240_Ed, 380SLbenz, 1978elcamino, 11 invisible), 2,126 guests, and 54 spiders.
Topics286,202
Posts4,904,104
Members67,576
Most Online2,967
Mar 10th, 2019
Moly lowers Timken OK load #4671215
02/19/18 07:13 PM
02/19/18 07:13 PM
Lakeside CA
another Todd Offline OP
Lakeside CA
I am looking at Mystik JT6 Hi Temp grease specs and it has an Timken OK load of 80; but the same grease with 3% moly has a Timken OK load of 60. I thought moly would always increase load capacity, but apparently not always true. Anybody have insight on why moly would lower the load carrying ability of this grease?
2015 Ford F250 Diesel Crew Cab FX4
2017 Ford Escape 2.0
2002 GMC Yukon
2015 Hyundai Accent
2008 Yamaha Rhino 700 FI
Re: Moly lowers Timken OK load [Re: another Todd] #4671303
02/19/18 08:20 PM
02/19/18 08:20 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
What matters is how much EP additive is in each formulation.
Moly is primarily a friction modifier but in larger treatment levels contributes to some (not the only) EP activity.
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: Moly lowers Timken OK load [Re: another Todd] #4671453
02/19/18 11:47 PM
02/19/18 11:47 PM
CZ factory 🏭 KC KS
Marco620 Offline
Marco620  Offline
CZ factory 🏭 KC KS
Sounds legit to me.
15' Civic 1.8 i-vtec 221,000 mi 0w20 Redline/Redline CVT/Archoil9100/TEIN/Eibach/Tanabe Sustec/Borla Exhaust/87 E0 fuel/Yokohama
Son of a Navy Corpsman. Support vets!
Re: Moly lowers Timken OK load [Re: another Todd] #4671470
02/20/18 12:49 AM
02/20/18 12:49 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Moly is for helping things that "slide against each other" to not wear.. (Like cam lobes & rockers)
Roller bearings aren't supposed to do any "sliding". Just rolling.
Re: Moly lowers Timken OK load [Re: another Todd] #4671632
02/20/18 09:10 AM
02/20/18 09:10 AM
NJ, USA
MotoTribologist Offline
NJ, USA
The percentage of moly in a grease is not directly correlated to EP performance. A grease with less or no molybdenum and a higher EP test result contains some additional non-moly EP additives to boost performance.
Re: Moly lowers Timken OK load [Re: MotoTribologist] #4673649
02/21/18 07:33 PM
02/21/18 07:33 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Lithium Complex greases are typically "extreme pressure"
Re: Moly lowers Timken OK load [Re: Linctex] #4674166
02/22/18 10:27 AM
02/22/18 10:27 AM
NJ, USA
NJ, USA
If they contain EP additives they certainly are. Lithium complex thickener offers little to no inherent EP performance though.
Re: Moly lowers Timken OK load [Re: another Todd] #4679837
02/27/18 06:12 PM
02/27/18 06:12 PM
WA, USA
digireg2 Offline
digireg2  Offline
WA, USA
Not only moly is the part of the formula you would have to exclude a lot of factors.
1. EP testing is relevant for EP conditions they are rare.
2. Moly in greases is antiwear additive.
3. Moly oxidizes readily in a presence of air and moisture turning into abrasive Molybdenum Oxide (III)
Re: Moly lowers Timken OK load [Re: digireg2] #4680357
02/28/18 08:51 AM
02/28/18 08:51 AM
the Netherlands
miro Offline
miro  Offline
the Netherlands
Good mentioned. In era of MOS2 hype people forget there is no single wonderful material for all the problems that we have.
Some basics from WIkipedia - https://en.wikipedia.org/wiki/Molybdenum_dioxide
Molybdenum oxide is a constituent of "technical molybdenum oxide" produced during the industrial processing of MoS2
2 MoS2 + 7O2 → 2MoO3 + 4SO2
MoS2 + 6MoO3 → 7MoO2 + 2SO2
2 MoO2 + O2 → 2MoO3
Re: Moly lowers Timken OK load [Re: another Todd] #4704743
03/23/18 10:13 PM
03/23/18 10:13 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
My truck calls for a moly grease in its wheel bearings. I use it in them and the u-joints. Never had a failure.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Moly lowers Timken OK load [Re: MolaKule] #4705020
03/24/18 08:52 AM
03/24/18 08:52 AM
Upper midwest
Mainia Offline
Mainia  Offline
Upper midwest
I thought I heard 3% moly is ok for ball bearings, but 5% and above is not?? Going by Caterpillar specs.
Re: Moly lowers Timken OK load [Re: Mainia] #4705237
03/24/18 12:56 PM
03/24/18 12:56 PM
Where the wind comes sweepin'
Reddy45 Online shocked
Reddy45  Online Shocked
I am inclined to think that most people who have used moly grease in a roller application ended up using a 3% moly formula that is very commonly bought at the auto store.
