Originally Posted By: mightymousetech
Originally Posted By: miden851
There is A and B maintenance step access thru the vehicle maintenance info; If you rotate the tires you'll need to go there and opt for B reset; this sends the information that you did the necessary rotation and I think this will turn it off
Our CRV also have the tire pressure reset button that is used in case of an emergency, such as tire puncture or any low air pressure level in tires;
Huh? None of that makes sense.
Same here. ???
On the newer CRVs, I recall there being a special tpms reset procedure after certain repairs. On a 2017 that I reflashed the adaptive cruise module on, the service bulletin stated to hit the tpms reset button multiple times in a row to clear the learned values. I suggest getting a 1 day subscription to Honda Service Express and reviewing the tpms reset procedure.
