Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
75 registered members (Aero540T, 2010Civic, agpatel, Aichiguy, AdditiveOCD, 7 invisible), 1,352 guests, and 63 spiders.
Topics286,438
Posts4,908,166
Members67,622
Most Online2,967
Mar 10th, 2019
Looking to maybe change oils.... #4657609
02/06/18 07:25 AM
02/06/18 07:25 AM
Missouri, USA
Tlhfirelion Offline OP
Missouri, USA
Always used Mobil 1 for most everything. If that wasnít available, Valvoline. Now my 2001 Toyota Sequoia seems to have slight issue in the winter with Mobil 1 high mileage 5W/30, which is the weight called for my my owners manual and oil cap. As far as I recall this is a conventionl oil? I have 236,000 miles on the V8, live in southeast Missouri and almost all my driving is highway miles, 30-60 miles per trip. Some 4 wheel drive in bad weather but not much.
I have no oil leaks, no mechanical issues and am just wondering if there is a better oil, especially for cold weather starts? Would a blend like Valvoline Maxlife be a better choice? Almost every day is I start it, let it warm up for a minute, drive a few hundred yards to the highway and up to 65-70 mph for a long drive of slightly hilly highway.
I may be under the false impression that a switch to a synthetic at this higher mileage could clean it up and create leaks. That may be an old wives tale?
Your advice is appreciated.
Re: Looking to maybe change oils.... [Re: Tlhfirelion] #4657618
02/06/18 07:38 AM
02/06/18 07:38 AM
Indiana (IN)
shanneba Offline
shanneba  Offline
Indiana (IN)
Mobil 1 High mileage is a "synthetic" oil.
https://mobiloil.com/en/motor-oils/mobil-1/mobil-1-high-mileage
"Mobil 1 High Mileage oils are designed to help extend engine life in high mileage engines. These advanced full synthetic motor oils feature:"
2003 BMW 330Ci
2013 HD Sportster XL1200C
Re: Looking to maybe change oils.... [Re: Tlhfirelion] #4657642
02/06/18 08:10 AM
02/06/18 08:10 AM
Michigan
ZZman Offline
ZZman  Offline
Michigan
5w oil in your climate is more than sufficient. And the M1HM is synthetic as stated earlier.
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram TG
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: Looking to maybe change oils.... [Re: Tlhfirelion] #4657645
02/06/18 08:11 AM
02/06/18 08:11 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Letís see. Youíve made it to 236,00 miles, have no leaks, and no mechanical problems. Sounds like you are using a pretty good oil. And yes it is a synthetic. If you are not satisfied with your starts you could change to Mobil 1 0W-30. Make sure itís not your battery that is the problem.
SF
If you want the job done right......do it yourself.
Re: Looking to maybe change oils.... [Re: Tlhfirelion] #4657654
02/06/18 08:23 AM
02/06/18 08:23 AM
Alberta
tcp71 Offline
tcp71  Offline
Alberta
Iím running 5w30 in Calgary. It was -24C when I started the truck a couple of days ago. Stick with what you are doing.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: mobil 0w40 (varies)
Re: Looking to maybe change oils.... [Re: Tlhfirelion] #4657662
02/06/18 08:40 AM
02/06/18 08:40 AM
Wichita, Kansas
vwalburn Offline
vwalburn  Offline
Wichita, Kansas
Like they've said, I would be looking at the battery in cold weather. That is a good synthetic oil for cold weather. Battery may be giving you a warning.
1996 Dodge Ram 1500
Valvoline MaxLife
2002 Honda Accord
Valvoline SynPower
2011 Chevrolet Equinox
Mobil1
1964 Pontiac GTO
Pennzoil 10W-40
Re: Looking to maybe change oils.... [Re: vwalburn] #4657669
02/06/18 08:44 AM
02/06/18 08:44 AM
Virginia
bbhero Online sick
bbhero  Online Sick
Virginia
Very good post here by vwalburn and Snagglefoot.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: Looking to maybe change oils.... [Re: Tlhfirelion] #4657670
02/06/18 08:45 AM
02/06/18 08:45 AM
Missouri, USA
Missouri, USA
https://jet.com/product/detail/b1302678894f4ce5a13fb1eaba7a189d?jcmp=pla:bng:All%20Products%20Catch%20All:All%20Products:na:PLA_112586931_4372403789_pla-4579946966786142_m:na:na:na:2PLA15&pid=kenshoo_int&c=112586931&is_retargeting=true&clickid=0c30aea2-f065-41c8-963f-6af1da055e16&msclkid=d38f4cb5a4ad122c5ff716cc0ab6e4a4
Apologies, to clarify this is what I meant. I forgot the word ďsuperĒ.
Re: Looking to maybe change oils.... [Re: vwalburn] #4657674
02/06/18 08:51 AM
02/06/18 08:51 AM
Missouri, USA
Missouri, USA
The issue is not the battery. I had it, along with the alternator tested, twice. I also, just to be sure, switched batteries at my brothers house with his new interstate battery and the vehicle started the same.
Re: Looking to maybe change oils.... [Re: Tlhfirelion] #4657681
02/06/18 08:55 AM
02/06/18 08:55 AM
Snagglefoot Offline
Snagglefoot  Offline
Which Super? Super 1000, or Super 2000?
Re: Looking to maybe change oils.... [Re: Tlhfirelion] #4657689
02/06/18 09:03 AM
02/06/18 09:03 AM
Snagglefoot Offline
Snagglefoot  Offline
Mobil deserves your business. Here is my two cents. Try Mobil 1 0-30 Advanced Fuel Economy if you want to feel an easier start. Otherwise it seems you are doing well with the Super.
SF. 2cents
Re: Looking to maybe change oils.... [Re: Snagglefoot] #4657690
02/06/18 09:04 AM
02/06/18 09:04 AM
Missouri, USA
Missouri, USA
As far as the 1000 or 2000 I do not know. Itís the exact one in the link above. Thank you.
Re: Looking to maybe change oils.... [Re: Tlhfirelion] #4657698
02/06/18 09:17 AM
02/06/18 09:17 AM
NY
137_Trenton Offline
137_Trenton  Offline
NY
What exactly is the "slight issue"? Is it just having trouble cranking? Maybe I'm missing it, but I don't see where you actually described the issue. The vehicle is 17 years old... if it's a cranking issue and the battery has been tested to be good, it very well could be the starter on the way out. There is no way it's cold enough in Missouri to have issues with a 5W30.
Re: Looking to maybe change oils.... [Re: Tlhfirelion] #4657701
02/06/18 09:20 AM
02/06/18 09:20 AM
Snagglefoot Offline
Snagglefoot  Offline
Sorry, but the link doesnít open properly. Iím still interested in seeing it.
Re: Looking to maybe change oils.... [Re: Snagglefoot] #4657735
02/06/18 09:51 AM
02/06/18 09:51 AM
Missouri, USA
Missouri, USA
https://www.walmart.com/ip/Mobil-Super-5W-30-High-Mileage-Motor-Oil-5-qt/17034362
Does this link work?
The intent of my thread is getting off the rails a bit, partly due to my incorrect product description from the start.
SO, letís start over. What oilS would be a good option for a 2001 Toyota Sequoia with 236k on the odometer in the region and driving patterns I described?
Thank you.
