OCI. With short trips. Nissan 4 liter
by Gawardawg
35 minutes 53 seconds ago
Approach Watching on the Beach @ St Maarten ...
by LoneRanger
47 minutes 14 seconds ago
Honda Accord Needs Shocks; Front, Back, or Both?
by tc1446
Today at 05:50 AM
How much oil does your oil filter hold?
by Snagglefoot
Today at 05:44 AM
better day
by mx5miata
Today at 05:26 AM
BRAVO to Officer Wheeles......
by Sayjac
Today at 05:17 AM
People Watching ....Airport style.
by ZZman
Today at 04:24 AM
Subaru's at play...
by OneEyeJack
Today at 03:50 AM
Treating a 2003 Jetta
by llmercll
Today at 01:41 AM
Brakes not working - brake pedal sinks
by tookien
Today at 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
Today at 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
Today at 12:16 AM
One Dollar Per Gallon?
by Y_K
Yesterday at 11:53 PM
Walmart Tightening up Returns
by John_K
Yesterday at 10:21 PM
flare nut wrench set
by spasm3
Yesterday at 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
Yesterday at 09:45 PM
How much is too much?
by Sealbilly
Yesterday at 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
Yesterday at 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
Yesterday at 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
Yesterday at 08:33 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
75 registered (adamrc, 69Torino, advocate, 91camarosRS, 1foxracing, 08z06, 6 invisible), 1180 Guests and 39 Spiders online.
65265 Members
67 Forums
285582 Topics
#4655228 - 02/03/18 07:46 PM Hood release issues on 1996 Century
007 Offline
Loc: Clermont, Fl
Looking for a solution for a sticky hood release mechanism on my 1996 Buick Century. Replaced the handle and cable once before but its getting to the point where its gonna break. Have to push down on hood while pulling lever to release. Lock does not seem like the spring is working to let it go back into position as I have to push the cable with the handle to lock down hood. Any ideas?
#4655267 - 02/03/18 08:20 PM Re: Hood release issues on 1996 Century [Re: 007]
Oldtom Offline
Loc: Cecil County Maryland
My hood release got " sticky " and I fixed it by applying a paint brush full of Fluid Film to the mechanism. Fluid Film works great for latches and hinges. The stuff penetrates into tight clearances. Great for rust proofing as well.
#4655288 - 02/03/18 08:41 PM Re: Hood release issues on 1996 Century [Re: 007]
Nick1994 Offline
Loc: Phoenix, AZ
WD40
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
#4655495 - 02/04/18 05:28 AM Re: Hood release issues on 1996 Century [Re: 007]
Trav Offline
Loc: MA, Mittelfranken.de
Clean the mechanism well with WD40 or brush on simple green as most solvents don't play well with paints and plastics and rinse it thoroughly.
Remove the cable end and lube the cable and the mechanism with Fluid Film or white lithium grease. You will need one of these, this one of ebay but you can get them almost anywhere where they service motorcycles.
https://www.ebay.com/i/152719161690?chn=ps
#4655527 - 02/04/18 07:25 AM Re: Hood release issues on 1996 Century [Re: Oldtom]
WyrTwister Offline
Loc: Texas
I have used PB Blaster . A little thicker than WD40 . Seems to stay put / last a little longer .
I wonder about 5W-30 synthetic ?
Wyr
God bless
#4655752 - 02/04/18 11:00 AM Re: Hood release issues on 1996 Century [Re: 007]
007 Offline
Loc: Clermont, Fl
Cleaned everything up. Cable and mechanism still grabbing even with hood open after soaking with WD40.
#4655839 - 02/04/18 12:01 PM Re: Hood release issues on 1996 Century [Re: 007]
Trav Offline
With the hood open does the mechanism work properly? If it does it sounds like the latch mechanism may have shifted down.
In this case mark the current location with a sharpie and loosen the bolts, move it up about 1/8 of an inch and try it.
You may need to screw the bumpers on both sides down a bit.
#4656163 - 02/04/18 05:25 PM Re: Hood release issues on 1996 Century [Re: 007]
007 Offline
Loc: Clermont, Fl
With the hood open the latch still is not moving freely when pulling the hood release. Not sure if its the cable binding or the latch itself.
#4656323 - 02/04/18 08:14 PM Re: Hood release issues on 1996 Century [Re: 007]
Trav Offline
Time to mark the location of the latch, unhook the cable and remove it. Check the operation, if its not smooth soak it overnight in Simple Green (seriously), rinse it well, dry it and check the operation.
If the cable is stiff use the tool I linked to with Liquid Wrench and see it that frees it up, if not replace it. Put newspaper on the floor under the latch to catch the rusty junk that comes out of the other end of the cable.
