Trying to fix chainsaw
by turtlevette
06/23/18 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
New belt squeal cause damage to belt?
by pda1122
06/23/18 05:33 PM
Food Safety - If You Have Children
by Zee09
06/23/18 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
06/23/18 05:02 PM
Chain cleaning and lube
by dadinfo
06/23/18 04:57 PM
Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
06/23/18 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
06/23/18 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
06/23/18 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
06/23/18 04:30 PM
mobil 1 rebate check
by Fitter30
06/23/18 03:52 PM
Cab mount failure
by ram_man
06/23/18 03:31 PM
02 Saab aero oil?
by Newuser
06/23/18 03:00 PM
Extend wifi range
by clarkflower
06/23/18 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
06/23/18 01:57 PM
Lease Buyout by Dealer
by Throt
06/23/18 01:52 PM
13 Ford Escape
by RedOak
06/23/18 01:10 PM
New washer pump leaking fluid
by llmercll
06/23/18 12:17 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
78 registered (2015_PSD, 2004tdigls, asiancivicmaniac, AndyB, AP9, 11 invisible), 1462 Guests and 50 Spiders online.
65303 Members
67 Forums
285870 Topics
#4654345 - 02/02/18 09:45 PM Bypass oil setup help
arayray94 Offline
Loc: Missouri
Looking for some help on a oil filtration setup I am planning. I am using baldwin filter bases with wix filters. Details are below, are these good filters to use?
Regular Filter Base: OB8722 (w/ bypass indicator)
Regular Filter: WIX 51495 (17 micron rating)
Bypass Filter Base: OB8720 (w/o bypass indicator)
Bypass Filter: WIX 51457 (3 micron rating)
#4654429 - 02/03/18 01:45 AM Re: Bypass oil setup help [Re: arayray94]
Linctex Offline
Loc: Waco, TX
Those are $35-$40 filters...?
What vehicle/engine are you thinking of?
#4654430 - 02/03/18 01:48 AM Re: Bypass oil setup help [Re: arayray94]
Linctex Offline
Loc: Waco, TX
#4654739 - 02/03/18 10:52 AM Re: Bypass oil setup help [Re: arayray94]
arayray94 Offline
Loc: Missouri
I will be putting this on my 6.0 powerstroke diesel, I chose to go with those bases for their input/output size. My system will be using 12an hose/fittings for best flow. I already purchased the bases so I will be sticking with them.
#4654962 - 02/03/18 02:32 PM Re: Bypass oil setup help [Re: arayray94]
Linctex Offline
Loc: Waco, TX
You are terribly misinformed.....
A Bypass oil filter uses 1/8" or 1/4" lines, at the MOST - you are only flowing about a quart of oil per minute.
You have taking a very wrong turn somewhere in your idea of this design.
#4655110 - 02/03/18 05:20 PM Re: Bypass oil setup help [Re: arayray94]
xtell Offline
Loc: ohio
arayray94,
Linctex is correct. If you are going to run a spin on bypass filter you would need a filter mount such as a Baldwin OB1305 or a Wix 24755. Both of these mounts have the same thread size 5/8-18 with inlet and outlet hole sizes 1/8 NPT. The Baldwin B50 and B164 filters are Bypass filters with .060 built in restrictors. I run a .030 in-line restrictor in my Spin on Bypass filter set-ups to restrict the oil flow even more. You can tap into an oil port on the engine. I use a sandwich adapter on my gas engines which allows me to retain my full flow filter and from a port on the sandwich adapter I run a line to the inlet of the Baldwin OB1305 Mount and my return line goes into s swivel fitting mounted on my oil cap. I use the smaller Baldwin B50 Bypass filter. My oil flow with warm oil is under a quart a minute.
nuff said,
xtell
#4655900 - 02/04/18 12:54 PM Re: Bypass oil setup help [Re: arayray94]
CT8 Offline
Loc: Idaho
Bypass fiters aren't really worth the results. No matter what has been read. Have fun though.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4656472 - 02/04/18 11:01 PM Re: Bypass oil setup help [Re: CT8]
Linctex Offline
Loc: Waco, TX
Well, (Like everything) it depends......
Amsoil SS 5w-20, 62,000 miles, '11 Ford Expedition
https://www.bobistheoilguy.com/forums/ubbthreads.php/ubb/showflat/Number/4578469/
#4658289 - 02/06/18 06:01 PM Re: Bypass oil setup help [Re: arayray94]
arayray94 Offline
Loc: Missouri
I am a total noob to oil analysis and bypass filters, I really would like to get into it. I am installing a oil-to-air oil cooler on my 6.0 powerstroke and figure why not add a bypass filter while I am at it.
[*]I already have the OB8722 base for my regular filter, is the WIX 51495 a good filter on it's own?
[*]Any guides or links to learn more about oil analysis and what to look for?
Edited by arayray94 (02/06/18 06:02 PM)
#4658391 - 02/06/18 07:34 PM Re: Bypass oil setup help [Re: arayray94]
xtell Offline
Loc: ohio
Quote:
[/quote]*]I already have the OB8722 base for my regular filter, is the WIX 51495 a good filter on it's own?[quote]
The filter you chose flows a lot of oil but as far as its filtering qualities, some regular oil filters do a lot better. It is not a bypass filter. Did you check the prior posts as far as potential bypass mounts and filter selections?
Edited by xtell (02/06/18 07:35 PM)
#4658584 - 02/06/18 11:22 PM Re: Bypass oil setup help [Re: Linctex]
CT8 Offline
Loc: Idaho
What is the cost of the BP filters, extended oil change intervls and uoas etc?
Geoff Metcalf
#4671868 - 02/20/18 12:16 PM Re: Bypass oil setup help [Re: arayray94]
valley_ranch Offline
Loc: ranches in Sierra Nevada Calif...
Bypass filter ~ are wonderful ~ Oil can be as clean ~ free of particles as when poured in at oil change``` What could be better than having clean oil ~ at all times ```
I use Frantz ~ there are others ~ just never used them ```
