F1 - 2018 Russian Grand Prix
by gofast182. 09/26/18 06:11 AM
Pets Puking in Middle of the Night :~/
by LoneRanger. 09/26/18 05:16 AM
Is there a new (2018) list of GM Dexron VI licensees?
by garageman402. 09/26/18 01:20 AM
Thoughts on new AMAZON branded oil...?
by PantherFan88. 09/25/18 10:47 PM
Clutch kit?
by andrewp1998. 09/25/18 10:34 PM
Galaxy S8+ weird app when clearing storage
by KrisZ. 09/25/18 10:18 PM
Brake bleeder - cfm ?
by hallstevenson. 09/25/18 09:43 PM
18' Corolla vs 18' Elantra
by wolf_06. 09/25/18 09:41 PM
Using Tc-w3 bad for my car?
by Floydian. 09/25/18 09:25 PM
I'm going to start using type F in my gm autos
by turtlevette. 09/25/18 09:17 PM
Cleaning deceased MIL condo and found $15K cash
by Mr Nice. 09/25/18 09:12 PM
Gluten
by StevieC. 09/25/18 07:55 PM
Amazon Prime delivering inside your house
by StevieC. 09/25/18 07:49 PM
2018 MB C300 M1 0W-40 3,475 Miles
by 2015_PSD. 09/25/18 06:44 PM
02-05 Silverado frame rot
by Oildudeny. 09/25/18 06:38 PM
Aftermarket Back Up Camera
by lancerplayer. 09/25/18 06:20 PM
Service champ filter CUT OPEN
by 53' Stude. 09/25/18 05:05 PM
Pressure washer pump life just 23 hours?
by HawkeyeScott. 09/25/18 05:01 PM
Everzooom, donnyw, Dfeeds, JJ_RA, Captjayd
66077 Registered Users
84 registered members (AandPDan, 53' Stude, 2010Civic, ABomb369, Ag76, 5 invisible), 1,051 guests, and 40 spiders.
Topics291,028
Posts4,854,785
Members66,077
Most Online3,590
Jan 24th, 2017
Door lock busted on 86 Buick Century #4654042
02/02/18 05:09 PM
02/02/18 05:09 PM
Clermont, Fl
007 Offline OP
007  Offline OP
Clermont, Fl
My son tells me he can not open the front passenger door from the inside as the handle has no tension and is loose. The door can be opened from the outside. Is there a rod inside the door going to the handle that had some sort of clip break? Trying to plan ahead if I have to get a part to fix it and if so where can it be purchased?
Re: Door lock busted on 86 Buick Century [Re: 007] #4654092
02/02/18 06:02 PM
02/02/18 06:02 PM
Eastern Seaboard
Collingwood Offline
Collingwood  Offline
Eastern Seaboard
Your best bet would be to get a small crowbar and gently pop off the interior trim panel. They are held on by clips. Then see if you can bend the rod back. Sometimes there is metal in the way.
Something like this. https://www.walmart.com/ip/TradesPro-7-M...13=&veh=sem
Re: Door lock busted on 86 Buick Century [Re: 007] #4654106
02/02/18 06:14 PM
02/02/18 06:14 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
Junk yards will probably have the part. Might cost a bit more than it should.
The inside metal edges of the door can be very sharp. Be careful in there you cut up your hands.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles
2004 Rav4 359,000 miles
2015 Camry 59,000 miles
Re: Door lock busted on 86 Buick Century [Re: 007] #4654112
02/02/18 06:15 PM
02/02/18 06:15 PM
Clermont, Fl
007 Offline OP
007  Offline OP
Clermont, Fl
Is there a plastic clip that broke?
Re: Door lock busted on 86 Buick Century [Re: 007] #4654124
02/02/18 06:27 PM
02/02/18 06:27 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
I used to have a 1986 Oldsmobile Cutlass Ciera same car as your Century basically. When my door did this it was a broken interior door handle. At the time I just bought a replacement which was if I recall correctly under $20 at the parts store. Check Rock Auto. My bet is on a broken door handle not the clip.
Luke
Re: Door lock busted on 86 Buick Century [Re: 007] #4654132
02/02/18 06:35 PM
02/02/18 06:35 PM
MN
14Accent Offline
14Accent  Offline
MN
There's still an A-body around that hasn't rotted out? I'm impressed.
Agreed it's probably the door handle. They're made of pot metal and break after a while. You'll probably need need new door panel clips too, after this long you can almost guarantee the plastic is extremely brittle and they'll break on removal.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: Door lock busted on 86 Buick Century [Re: FlyNavyP3] #4654134
02/02/18 06:37 PM
02/02/18 06:37 PM
Clermont, Fl
007 Offline OP
007  Offline OP
Clermont, Fl
Could be
Thanks
Re: Door lock busted on 86 Buick Century [Re: 14Accent] #4654253
02/02/18 09:07 PM
02/02/18 09:07 PM
ME
eljefino Offline
eljefino  Offline
ME
This, my ciera suffered.
HF has a plastic door trim tool set (blue in color) for $6 that will come in handy for this job.
Should just be one phillips screw inset in the handle cavity then two more under little rubber corks on the armrest. Then the rest are just plastic "Xmas trees" around the perimeter.
Re: Door lock busted on 86 Buick Century [Re: 007] #4654786
02/03/18 12:33 PM
02/03/18 12:33 PM
Clermont, Fl
007 Offline OP
007  Offline OP
Clermont, Fl
Is the door handle unit held on by screws or rivets?
Re: Door lock busted on 86 Buick Century [Re: 007] #4654964
02/03/18 03:34 PM
02/03/18 03:34 PM
Clermont, Fl
007 Offline OP
007  Offline OP
Clermont, Fl
You guys were right it was the handle. What a pain fixing as many plastic connectors around the door panel were brittle and broke!
Re: Door lock busted on 86 Buick Century [Re: 007] #4654998
02/03/18 04:11 PM
02/03/18 04:11 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Yep. On my BMW there are jobs where I spend as much or more on plastic thingamabobs as I do on the part that needs replacing.
1994 BMW 530i, 229K
1996 Honda Accord, 263K
1999 Toyota Sienna, 402K
2000 Toyota ECHO, 272K
Re: Door lock busted on 86 Buick Century [Re: 007] #4655014
02/03/18 04:34 PM
02/03/18 04:34 PM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
Brittle plastic? Try living here!
2018 Challenger SRT
Re: Door lock busted on 86 Buick Century [Re: 007] #4655469
02/04/18 03:38 AM
02/04/18 03:38 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
I didn't even chime in on the thread since the advice given was correct and I went into a flashback to the taxi days, with GMs of the same vintage having their doors opened several billion times a day, and the handles meeting the same fate every year or two. I curled up in a ball on the floor after reading your post. wink
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Door lock busted on 86 Buick Century [Re: 007] #4656010
02/04/18 03:38 PM
02/04/18 03:38 PM
Alabama, United States
Red91 Offline
Red91  Offline
All I have to say is keep that Century on the road as long as possible. What engine's in it?
My brother and I shared a grey '93 with the 3300 V6, then he had a purplish '93 with the same engine. I have a soft spot for most late late eighties to mid nineties GM's.
'89 Chevy 1500
Supertech 20/50
'15 Chevy Cruze
AcDelco syn dexos 5/30
