Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
102 registered members (ArrestMeRedZ, Arminius, 2012AccentSE, avi1777, albenjoseph, 55Test, 9 invisible), 1,969 guests, and 50 spiders.
Topics286,148
Posts4,903,019
Members67,565
Most Online2,967
Mar 10th, 2019
Motor Oil Selection - Decision Making Process #4650548
01/29/18 07:57 PM
01/29/18 07:57 PM
Calgary, Canada
nielkfj Offline OP
nielkfj  Offline OP
Calgary, Canada
Thanks to the respondents to my other thread for recommendations on a motor oil for my 2013 GTI.
In this thread I’d like to ask about the primary factors that I should consider when selecting motor oil in the future.
I assume the most important factor would be ensuring that the oil meets the OEM specification (VW 502.00 or 503.00 or 504.00). But what are the other important factors to consider - such as other OEM specs that are listed on the bottle, or specific physical properties of the oil?
For example here are some other manufacturer specs I've seen mentioned:
Porsche A40
MB 229.5
BMW LL-01
And here are some physical properties I've seen mentioned:
NOACK volatility (lower is better)
HT/HS viscosity (higher is better)
Sulfated Ash content (lower is better)
Mini-Rotary Viscometer at low temp (lower is better)
Are there other important physical properties or OEM specification to consider, and how would you rank them in order of importance?
2013 VW GTI Base Model (Canadian) - 100% stock
Re: Motor Oil Selection - Decision Making Process [Re: nielkfj] #4650553
01/29/18 08:02 PM
01/29/18 08:02 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
I trust in the OEM to set the specs they think are important. No need to overthink it.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: Motor Oil Selection - Decision Making Process [Re: nielkfj] #4650563
01/29/18 08:13 PM
01/29/18 08:13 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
I don't think higher is better for HT/HS. I don't think it matters as long as it is 3.5 or higher.
I replaced the intake manifold on my GTI around 80K miles and cleaned the intake valves while I was at it. It is not a difficult repair or expensive repair.
The Humble Mechanic has a video on it.
https://www.ecstuning.com/b-genuine-volk...bd/06j133201bh/
Me: 13' VW GTI 3 door 6 speed manual
Re: Motor Oil Selection - Decision Making Process [Re: skyactiv] #4650578
01/29/18 08:36 PM
01/29/18 08:36 PM
MN
oil_film_movies Offline
MN
HTHS must be greater than X. Higher just means you have more than you need, and fuel economy & cold flow suffers.
The value of "X" is communicated by the manufacturer using the spec they mention. For example, some engines require >2.9, others are at >3.4, etc.
Going with less HTHS than the spec means there could be excess wear, or in severe cases, spun bearings.
Re: Motor Oil Selection - Decision Making Process [Re: nielkfj] #4650642
01/29/18 10:26 PM
01/29/18 10:26 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Find an oil that meets all 4. VW 502 is generally regarded as the “easiest” of the top 4 euro A3/B4 oil certifications to pass.
Castrol, Motul, and Pennzoil all make oils that meet main 4.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: Castrol 0W-40
Re: Motor Oil Selection - Decision Making Process [Re: nielkfj] #4650666
01/29/18 10:58 PM
01/29/18 10:58 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
The manufactures recommendations are what you want, the rest is going to be sport.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Motor Oil Selection - Decision Making Process [Re: nielkfj] #4650698
01/30/18 12:28 AM
01/30/18 12:28 AM
Texas (south)
FermeLaPorte Offline
Texas (south)
I would use a German-made oil like Motul or LiquiMoly which what people over there in Germany use
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Motor Oil Selection - Decision Making Process [Re: nielkfj] #4650726
01/30/18 03:29 AM
01/30/18 03:29 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Exactly. Generally, the more specs it meets, the better, but they're all pretty much interchangeable. It's safe to just pick the coolest-looking bottle.
Motul is French.
"Zed's dead baby, Zed's dead."
Re: Motor Oil Selection - Decision Making Process [Re: FermeLaPorte] #4650730
01/30/18 03:50 AM
01/30/18 03:50 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Liqui Moly is average oil at best. Just because it has huge letters that says: MADE IN GERMANY, does not mean it is better then other ones.
Motul is French! Motul did not update its products for like 10 years.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: Motor Oil Selection - Decision Making Process [Re: nielkfj] #4650742
01/30/18 05:24 AM
01/30/18 05:24 AM
Virginia Beach
Astro14 Offline
Astro14  Offline
Virginia Beach
Things to consider:
1. What meets spec for your car
2. What is available
In my neck of the woods, Mobil 1, at $23/5quart jug from Walmart meets the above. And UOA has verified that it works well in my German car.
No need to obsess...
32 Packard 15W40
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Motor Oil Selection - Decision Making Process [Re: Astro14] #4650782
01/30/18 06:52 AM
01/30/18 06:52 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Originally Posted By: Astro14
Things to consider:
Too true.
Start with the OEM specs, actually licenced, not meets or exceeds, or recommended for. Actual licence.
Then you are good to go.
Then if the oil you have throws in things like DEXOS, Honda HT-06, ACEA, the Porsche spec then grab them with both hands if it's at your price point.
They are all there because the OEMs found that there was an issue with their kit that "plain vanilla" didn't work with.
When it comes to an API/ACEA spec, they all lobby to have their issue included in the standard raft, spreading the cost over all the bottles sold. If they don't get in, and there's enough of an issue for them, they go it alone, and make their own spec.
Re: Motor Oil Selection - Decision Making Process [Re: nielkfj] #4650854
01/30/18 09:03 AM
01/30/18 09:03 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Porsche A40
MB 229.5
BMW LL-01
Those specifications already specify the other things you mention.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Motor Oil Selection - Decision Making Process [Re: edyvw] #4650925
01/30/18 10:18 AM
01/30/18 10:18 AM
The land of USA-made Subies!
SubieRubyRoo Online happy
SubieRubyRoo  Online Happy
I've only used Motul Gear 300, but maybe, just maybe, it's possible that their products as they were designed 10 years ago, were forward-looking and well-engineered enough that the 10 year timelapse was just allowing other manufacturers to catch up? SN has been in effect since 2010, so it's possible that if their products were only designed to exceed SN, well, then they haven't necessarily NEEDED a change. All depends on the intended market and what specifications they're looking to meet.
Re: Motor Oil Selection - Decision Making Process [Re: Leo99] #4650983
01/30/18 11:08 AM
01/30/18 11:08 AM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
There's really not much "overthinking" on the forum Leo. Pray tell where did you come up with such a crazy notion? Regards
Re: Motor Oil Selection - Decision Making Process [Re: nielkfj] #4651068
01/30/18 12:35 PM
01/30/18 12:35 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
The HTHS is driven by bearing clearances, sump temps and RPM range. Has your engine been modified? Does it see track days? Do you spend long stretches at redline? Answer yes to any of these and you must make adjustments.
I always start with the Porsche A40 list if track days will be involved smile
