Best additive in oil to clean sludge?
by ffgb
06/21/18 02:19 PM
Who is a Dirt Track regular?
by thooks
06/21/18 01:39 PM
eco plug oil plug video is restricted
by edwardh1
06/21/18 01:27 PM
Political comments
by ridgerunner
06/21/18 01:23 PM
My Ford orange turned pink
by BeerCan
06/21/18 12:45 PM
Any plants/garden experts?
by maverickfhs
06/21/18 12:43 PM
Internet Sales Tax O.K.ed by Supreme Court
by doitmyself
06/21/18 12:23 PM
Brake fluid for a '03 Volvo S60
by earthworm
06/21/18 11:22 AM
Oil Weight Change - Mid Production Cycle
by PolarisX
06/21/18 11:20 AM
Kia ATF - OEM, Eneos, Maxlife - TDS - DIFFERENT!
by Spddm0n
06/21/18 11:19 AM
Dillon Precision Is Simply The Best!
by 2015_PSD
06/21/18 11:17 AM
First OCI - 156k miles Prius
by Greg L
06/21/18 11:11 AM
Brake Squeal on Rear Discs
by BlitzPuppet
06/21/18 11:10 AM
Coolant leak.
by LeakySeals
06/21/18 11:05 AM
Looking for a Home Depot coupon 10% off?
by GravelRoad
06/21/18 10:59 AM
Which is more important for low wear HTHS or ZDDP?
by Building3
06/21/18 10:40 AM
Valvoline DuraBlend 80W-90
by dogememe
06/21/18 10:34 AM
Lifter Tick
by Delta
06/21/18 10:28 AM
I Got Locked Up Today
by Zee09
06/21/18 10:24 AM
GM new 2.7 turbo pick up motor
by ZZman
06/21/18 09:45 AM
wil892, Spddm0n, ronw1309, Suth31, yamahaboy125
65286 Registered Users
107 registered (04sierrashortbed, 2015_PSD, 853okg, 14ecocruze, 28oz, 4WD, 9 invisible), 1581 Guests and 48 Spiders online.
65286 Members
67 Forums
285715 Topics
#4649092 - 01/28/18 01:08 PM OK, back to the old'ish days - 283 PCV
BrocLuno Offline
Loc: Kalifornia Kollective
So I have a little 283 project in the shop. Was topped with 601 heads at nigh on to 10:1, but that's too steep for local pump gas, and not conducive to maybe going into a CJ ...
So I have some bigger chamber vortec heads that will drop the CR nicely and create swirl smile
But I also have some nice old school "Chevrolet" stamped steel valve covers w/o fill holes. etc.
I want to pull the freeze plug from the old block port for the road draft tube and insert a piece so I can fit the PCV there. I can put a fill tube into the intake with a cap. Make it look 1960's period correct.
So does anyone know of a road draft plug kit with a PCV port for an early SBC?
Edited by BrocLuno (01/28/18 01:09 PM)
#4649100 - 01/28/18 01:17 PM Re: OK, back to the old'ish days - 283 PCV [Re: BrocLuno]
Trav Offline
Loc: MA, Mittelfranken.de
#4649118 - 01/28/18 01:36 PM Re: OK, back to the old'ish days - 283 PCV [Re: BrocLuno]
Blkstanger Offline
Loc: Lakeside, CA
99 Jeep WJ 4.7 185,000 Maxlife 10w30, Fram Ultra.
#4649154 - 01/28/18 02:09 PM Re: OK, back to the old'ish days - 283 PCV [Re: BrocLuno]
Chris142 Offline
Loc: Deplorable in apple valley, ca
Drill a hole in the plug that's blocking the road draft tube so that you can push in a grommet with a pcv in it.put a vented oil fill cap on the tube that's sticking out of the front on the intake.
I am not familiar with later heads. Don't lower the compression too much. They like 10:1.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4649305 - 01/28/18 04:34 PM Re: OK, back to the old'ish days - 283 PCV [Re: BrocLuno]
NYEngineer Offline
Loc: NY, NY
http://mewagner.com/?p=540
Just showing you this in case you need a better PCV than is available at the parts store.
#4649394 - 01/28/18 06:12 PM Re: OK, back to the old'ish days - 283 PCV [Re: BrocLuno]
BrocLuno Offline
Ah yes, thanks for the ideas. Cool, if a bit too much bling ...
Chris142 I'd rather not be drilling into a fresh motor if I can help it. Rather just pop the plug and install something else ...
Blkstanger, that looks about right. Looks like an F-150 SBF PCV into a grommet. Just need to figure out which one ...
If you have more, put them up. I'm sure I'll find one that strikes my fancy smile
#4649538 - 01/28/18 08:37 PM Re: OK, back to the old'ish days - 283 PCV [Re: BrocLuno]
Chris142 Offline
that's what I meant!
#4649543 - 01/28/18 08:45 PM Re: OK, back to the old'ish days - 283 PCV [Re: BrocLuno]
Linctex Offline
Loc: Waco, TX
In that displacement range, I never liked the 283 for lack of torque.
I have always been able to build a stout 305 that outperformed it at nearly any point in the rpm range (except over 5000).
#4649597 - 01/28/18 09:29 PM Re: OK, back to the old'ish days - 283 PCV [Re: BrocLuno]
malibuguy79 Offline
Loc: Maryland
ah man...601 heads. good stuff, closed small chambers, decent ports. arguably the best flowing 305 heads. watch out there is 601 heads for 267 that has baby valves. Good head for a 267 but useless on anything with a bore
Greg...the exhaust guy
I have a 10 Yaris, 97 Tercel 1nzfe swap coming, 82 Malibu 1uzfe swap in progress
She has 18 Fit and 01 Forester
