The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
What's in Maxima oil?
by Truckedup. 03/23/19 06:29 PM
2015 Acura TLX 3.5L V6
by blackdiamond. 03/23/19 06:20 PM
Group 3 oil with best heat stability?
by LSXHitman. 03/23/19 05:24 PM
FixItDad28, RandomJoe, Sciascia, sosp197, peppercorn
67597 Registered Users
27 registered members (Duffyjr, dishdude, Brad_C, carlprop, c502cid, csandste, 1 invisible), 733 guests, and 56 spiders.
Topics286,320
Posts4,906,408
Members67,597
Most Online2,967
Mar 10th, 2019
What is this oil leak from? #4648089
01/27/18 03:54 PM
01/27/18 03:54 PM
WI
HoosierJeeper Offline OP
WI
On my 07 LR3 it started leaking oil rather suddenly a few nights ago and marked it's territory in the garage. I found the source of it, but I have no idea what it's called. The oil filter screws onto what I believe is the cooler and then the cooler connects to this piece that mates to the engine block and it looks like that's where the leak is from. Any ideas on what this part is called?
Here are a couple pics. I circled the leak origin in blue.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: What is this oil leak from? [Re: HoosierJeeper] #4648096
01/27/18 04:02 PM
01/27/18 04:02 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Oil cooler/filter adapter?
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: What is this oil leak from? [Re: HoosierJeeper] #4648112
01/27/18 04:30 PM
01/27/18 04:30 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Isn't that some type of solenoid?
Re: What is this oil leak from? [Re: HoosierJeeper] #4648132
01/27/18 04:57 PM
01/27/18 04:57 PM
MN
14Accent Offline
14Accent  Offline
MN
Oil filter adaptor to block gasket
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: What is this oil leak from? [Re: HoosierJeeper] #4648145
01/27/18 05:11 PM
01/27/18 05:11 PM
California
VeryNoisyPoet Offline
California
Looks suspiciously like the oil cooler thermostat on my car (minus the wires). Leak possibly from a large gasket/ o-ring where it mates to the block.
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: What is this oil leak from? [Re: HoosierJeeper] #4648175
01/27/18 05:40 PM
01/27/18 05:40 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Heh heh, reminds me of a joke" Why don't the Brits make computers?" Dunno , why? "because they haven't figured out how to make them leak oil"
Thick oil is better grin2
Re: What is this oil leak from? [Re: HoosierJeeper] #4648191
01/27/18 05:57 PM
01/27/18 05:57 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
+1 oil filter adapter, the gasket...
https://www.amazon.com/Genuine-ROVER-FILTER-GASKET-LVF500010/dp/B01N7EYGBS
Check for your engine.
Re: What is this oil leak from? [Re: HoosierJeeper] #4648193
01/27/18 05:59 PM
01/27/18 05:59 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
I'd start by checking the tightness of that bolt in pic #2, it may just be that it has loosened off for no apparently reason.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: What is this oil leak from? [Re: HoosierJeeper] #4648285
01/27/18 07:53 PM
01/27/18 07:53 PM
5600 feet elevation, Arizona
double vanos Offline
Land Rover: putting oil back into the ground - you canít get any greener than that....
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: What is this oil leak from? [Re: double vanos] #4649014
01/28/18 01:17 PM
01/28/18 01:17 PM
Trav Offline
Trav  Offline
The fact they still use that engine proves GM had a winner with engine though and like almost everything else they had that was ahead of it time they shelved it or sold it to someone else.
Porsche didn't get the idea to add 2 more cylinders until GM did it (and even had a turbo model long before the 930 was even thought of) with an air boxer 4 years before. That GM designed all aluminum V8 Rover uses was decades ahead of its time.
Re: What is this oil leak from? [Re: HoosierJeeper] #4649396
01/28/18 07:14 PM
01/28/18 07:14 PM
USA
07titan Offline
07titan  Offline
USA
My 07 nissan titan recently developed a small oil leak, around the oil filter. I discovered this was a simple fix, a new gasket was needed, called a oil cooler gasket, part # 21304-JA11A. Very simple fix, on my next oil change. 2 different vehicles, but similar problem. My gasket cost $6.00 and change, similar to the gasket on a oil filter. Problem was explained on a nissan titan forum. This is a simple problem nissan dealerships love,$$$$$.
07 Nissan Titan
08 Jeep Grand Cherokee
Re: What is this oil leak from? [Re: HoosierJeeper] #4649398
01/28/18 07:15 PM
01/28/18 07:15 PM
WI
WI
It's the Jag 4.4, not the old Rover V8. Not sure if there's any relation...
Would anyone happen to be able to roughly estimate the book time it would be to replace it? Thinking of trading it in and weighing fixing it beforehand or not.
Re: What is this oil leak from? [Re: HoosierJeeper] #4649540
01/28/18 09:40 PM
01/28/18 09:40 PM
Trav Offline
Trav  Offline
Oh ok I see its an 07, the Rover power ended in 06. Still, it had a pretty good run 1960-2006.
I can look at the book tomorrow but it doesn't appear to be a difficult or time consuming job.
Re: What is this oil leak from? [Re: HoosierJeeper] #4649914
01/29/18 10:09 AM
01/29/18 10:09 AM
Trav Offline
Trav  Offline
Book pays 0.8 hr for replacing the adapter, it looks like you might be able to do it much quicker by just removing the mounting bolts (providing you have access to them without pulling the cooler), pull it back, put the new gasket in and tighten it back up.
Re: What is this oil leak from? [Re: HoosierJeeper] #4649963
01/29/18 11:11 AM
01/29/18 11:11 AM
WI
WI
Awesome! Thanks so much. Really appreciate it.
