I just finished crawling out from under my truck to see what Transfer case I have and noticed it read, Borg Warner.
I did some quick reading and found out there are 2, maybe more, types, 44-44 and 44-45. If I am correct, the 44-44 is for those that have auto 4x4, which mine does.
My question is, is the fluid the same for both and do I have no choice but to go to the dealer for this fluid? It is not ATF, but some other special kind of fluid specifically made for this transfer case.
I read where it is $28 U.S. per quart and I need 2 as the TC takes approx 1-1/2 quarts to fill.
