Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
72 registered members (4WD, ABomb369, 94astro, alarmguy, Astro_Guy, atikovi, 5 invisible), 1,150 guests, and 35 spiders.
Topics295,207
Posts4,929,935
Members66,711
Most Online2,553
Oct 27th, 2018
2003 Civic Oil Burning Help #4645241
01/24/18 06:10 PM
01/24/18 06:10 PM
VA
maverickfhs Offline OP
VA
I opened this thread sometime ago: https://bobistheoilguy.com/forums/ubbthreads.php/topics/4411189#Post4411189
We tried using M10W40, STP Oil treatment(which reduced oil consumption), replaced PCV valve, although old one was fine.
Car is still consuming oil say a quart in 500-750 miles, without any visible smoke and no dripping on the driveway and no leaks. Overall power and fuel economy, everything is fine.
In terms of HM oil, which one do you guys suggest? Anything in 10W30 or 5W30 weight? Of if you have any other advice or tips for taking care of this Oil issue? Without this oil issue, car has been very dependable.
Thanks so much for the help.
2006 Civic EX 202K/AT
2006 Acura TSX 180K/AT
Re: 2003 Civic Oil Burning Help [Re: maverickfhs] #4645249
01/24/18 06:14 PM
01/24/18 06:14 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Maxlife Red bottle 5w30 and a new oem pcv valve did the trick for my 99 Accord that was consuming oil. The first time I noticed it low a qt I topped off with Mobil 5000 and it quickly consumed that. But after topping off with ML and the pcv valve no more consumption. So it was one of the two. The trick is to catch it early.
Re: 2003 Civic Oil Burning Help [Re: maverickfhs] #4645266
01/24/18 06:23 PM
01/24/18 06:23 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
I would try a Dino oil.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 2003 Civic Oil Burning Help [Re: maverickfhs] #4645267
01/24/18 06:25 PM
01/24/18 06:25 PM
VA
VA
Believe it or not, it has mostly been used with Dino.
Any particular weight of Dino?
Re: 2003 Civic Oil Burning Help [Re: maverickfhs] #4645270
01/24/18 06:28 PM
01/24/18 06:28 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I wonder if the OP mixed up a bunch of different oils?
Originally Posted By: maverickfhs
I have seen many guys here make their own oil brew and mention, if 0W20 is mixed with 0W40 with 4/1 parts, it'll be close to 0W30 and what not terms of ratios...
Question is, how do you get that approximation of mixing blends?
Is there an online calculator for viscosity and all and for that what do I need?
Thanks for any advice and help thumbsup
Re: 2003 Civic Oil Burning Help [Re: maverickfhs] #4645293
01/24/18 06:46 PM
01/24/18 06:46 PM
Orlando, FL
Mr Nice Offline
Mr Nice  Offline
Orlando, FL
I agree with MaxLife and new PCV valve.
Re: 2003 Civic Oil Burning Help [Re: maverickfhs] #4645338
01/24/18 07:43 PM
01/24/18 07:43 PM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
Recommend Maxlife. Start with 5w30.
1998 Honda Accord EX 2.3L Auto (Sold) 214k mi
2009 Scion tC Manual (Daily Driver) 165k mi
Re: 2003 Civic Oil Burning Help [Re: maverickfhs] #4645343
01/24/18 07:50 PM
01/24/18 07:50 PM
Spring,Texas
Bud_One Offline
Bud_One  Offline
Spring,Texas
I'd try an 10W30 Conventional first .
I've had good results with Havoline and Chevron Supreme 10W30 slowing down consumption in my old Accord.
2cents
16 Civic-QSUD 0W-20, XG7317
14 Civic-Idemitsu Zepro 0W-20, XG7317
05 Chevy 2500HD-QSUD 10W-30, XG3675
97 Accord Wagon-Havoline ProDS 10W-30, TG7317
Re: 2003 Civic Oil Burning Help [Re: maverickfhs] #4645437
01/24/18 09:22 PM
01/24/18 09:22 PM
Chester County/Pa.
Dobbie Offline
Dobbie  Offline
Chester County/Pa.
Why not try a 10W30 or 10W40 HM oil for multiple OCIs? What do you have to lose.
Re: 2003 Civic Oil Burning Help [Re: maverickfhs] #4645529
01/24/18 11:54 PM
01/24/18 11:54 PM
Elizabeth. Colorado
c502cid Offline
c502cid  Offline
Elizabeth. Colorado
As the owner of many a Honda, the oil burning issue is their Achilles heel. I have had some luck with adding about 10-15% MMO to either an oil change or whatever I'm adding every time I top it off. If you changed the PCV (and thank you Honda engineers for putting the PCV in a horrible to access location) the next issue is stuck rings. I slowed down a Prelude from a qt every 400 miles to a qt every 800-1000 miles doing this for about 3 months.
Just to note, the oil passage between the PCV and the throttle body gets horribly plugged up. Now every Honda I get gets a new PCV, then I pull off the throttle body and run a flexible pipe cleaner soaked in carb cleaner through the passage. It takes time but most are clogged up. Clean the IAC valve and the throttle plate while the throttle body is off too!
Good luck. I have a love/hate relationship with Honda.
17 SuperDuty 6.2 4x4
15 Chev Trax AWD
02 GMC 3500 8.1/Allison 4x4
00 Blazer 4x4
97/98 Civic's
84 Chev K30 454EFI 4x4
71 GMC Jimmy 502 RamJet
Re: 2003 Civic Oil Burning Help [Re: c502cid] #4645666
01/25/18 08:06 AM
01/25/18 08:06 AM
wv
krismoriah72 Offline
wv
Oil control rings are stuck with carbon buildup.
You can do an aggressive piston soak with possible luck.
Here is a Honda stuck oil control ring thread-
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3990497/Freeing_up_dirty,_stuck_oil_co
Re: 2003 Civic Oil Burning Help [Re: c502cid] #4645668
01/25/18 08:11 AM
01/25/18 08:11 AM
MN
Tman220 Online content
Tman220  Online Content
MN
In general on these engines what usually causes them to burn oil so badly? I have nearly the same car as the OP (04 Civic LX M5) with about the same amount of miles 154K and I have a complete opposite experience with oil consumption. Between 5000 mile changes oil consumption is barely noticeable on the dipstick.
On the OP's car, I would suspect valve seals because of the unknown history of the used head. Do these engine also have a tendency to plug the oil return holes in the pistons?
Then again my engine has never been seriously over heated either due to the head gasket issues these engines seem to have. I'm guessing that's why the head was replaced in he first place on the OP's car.
2012 Regal GS Turbo PP 5w30
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30
Re: 2003 Civic Oil Burning Help [Re: maverickfhs] #4645674
01/25/18 08:18 AM
01/25/18 08:18 AM
VA
VA
Tman220, it never burned oil before, but jumped timing and because of that head needed to be replaced. Now it's consuming oil. Never overheated either.
Re: 2003 Civic Oil Burning Help [Re: maverickfhs] #4645676
01/25/18 08:19 AM
01/25/18 08:19 AM
OK, USA
bradtech Offline
bradtech  Offline
OK, USA
I'm starting to notice a considerable difference with Castrol GTX 10w30 HM in my 2.8L 1993 s10 with 205k. I even have a minor rear main leak. I've only put 6000-7000 miles on it in two years though. Have thought about going up to 10w40 next OC.
17 Chevrolet Malibu 3k 5w30 AC Delco Full Syn
08 Hyundai Santa Fe 78k 5w20 GTX HM OEM Filter
93 Chevy S10 203k 10w30 GTX HM ACDELCO PF52E Filter
Re: 2003 Civic Oil Burning Help [Re: Tman220] #4645684
01/25/18 08:24 AM
01/25/18 08:24 AM
SC, USA
Bxnanaz Offline
Bxnanaz  Offline
SC, USA
In his case, H series engines have FRM cylinder liners which are extremely tough, but prone to wearing down rings. If you replace rings on an H series, itís OEM, or Mahle Gold. PCV valve on an H is right on top the Valve cover..
