Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
80 registered members (avi1777, ARCOgraphite, Bailes1992, BeerCan, Blkstanger, Berny, 8 invisible), 1,622 guests, and 59 spiders.
Topics286,387
Posts4,907,333
Members67,614
Most Online2,967
Mar 10th, 2019
Battery insulation wrap or sleeve #4641273
01/20/18 07:51 PM
01/20/18 07:51 PM
Crawfordville FL
SilverFusion2010 Offline OP
Crawfordville FL
My OE battery insulator had a tragic accident. Are there cheap aftermarket options available or should I order OEM from dealer?
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Battery insulation wrap or sleeve [Re: SilverFusion2010] #4641284
01/20/18 08:02 PM
01/20/18 08:02 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
To tell the truth, I've never really found them to be particularly useful. If there is a small opening, cold is going to get in there and since everything moves from warm to cold, you are heating the outdoors a lot, which doesn't work well. A heating pad directly under the battery (don't bother getting one oversized, undersized is actually better) works better in my experience than trying to wrap the thing somehow. Lead-Acid batteries often need venting, which is counter-productive if you're trying to keep it warm.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Battery insulation wrap or sleeve [Re: SilverFusion2010] #4641285
01/20/18 08:05 PM
01/20/18 08:05 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
I'm interested in the accident. What happened?
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: Battery insulation wrap or sleeve [Re: Johnny2Bad] #4641295
01/20/18 08:25 PM
01/20/18 08:25 PM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
A review of the OP location is worth considering
2004 Prius; 110K; ASL
2007 Yaris 86K 0w-40 Castrol
2006 B2300;132K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Battery insulation wrap or sleeve [Re: SilverFusion2010] #4641315
01/20/18 08:58 PM
01/20/18 08:58 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Usually a battery insulator is to keep spikes in engine room temps out of the battery... Batteries do not like to over-heat ...
You can use wet suit foam to insulate a battery. 3M77 adhesive and stick it on all four sides. Should be on there for the duration of the batteries life span smile
Re: Battery insulation wrap or sleeve [Re: SilverFusion2010] #4641341
01/20/18 09:21 PM
01/20/18 09:21 PM
Georgia
MParr Offline
MParr  Offline
Georgia
OE insulators are not very expensive.
Check out Tasca Parts
2013 KIA Optima EX 2.4L. Now: Unknown &OE filter
2017 Ford Escape SE 2.0T Now: NAPA Synthetic 5W30 & NAPA Gold 1348
Re: Battery insulation wrap or sleeve [Re: SilverFusion2010] #4641360
01/20/18 09:39 PM
01/20/18 09:39 PM
VA
Rhymingmechanic Offline
VA
DEI makes a foil-backed battery wrap that can be cut to size. It's fairly easy to install, and I have reused the same kit. I already had some aluminum tape to fasten it with the second time.
I don't know if it really does anything but make me feel good. I added it to a Vibe that had no factory insulator.
Re: Battery insulation wrap or sleeve [Re: BrocLuno] #4641379
01/20/18 09:57 PM
01/20/18 09:57 PM
ME
eljefino Offline
eljefino  Offline
ME
Or just glue four promotional mousepads to the sides. Save your wetsuit money for pizza and beer. cheers
"Someone" figured out the average car runs for half an hour or whatever and this foam helps keep the battery from heat soaking in that time. It costs them a dime and saves more than that in warranty costs.
Re: Battery insulation wrap or sleeve [Re: SilverFusion2010] #4641480
01/20/18 11:55 PM
01/20/18 11:55 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
If yours was a Group 96R, I can send you the one I took out of my wife's Mustang
When I upgraded my wife's Mustang from a Group 96R OEM battery to a Group 48 AGM battery, this is what I used on the Group 48.
https://shop.advanceautoparts.com/p/desi...ttery+insulator
After discount code & Speedperks reward it was cheaper than Amazon. YMMV
You can also peruse eBay for your battery group size.
Also curious for more details on the incident. Rodent related?
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Battery insulation wrap or sleeve [Re: SilverFusion2010] #4641575
01/21/18 06:08 AM
01/21/18 06:08 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Bubble wrap?
Or bits of torn windscreen reflector stuff? (Curses, just threw some away)
Re: Battery insulation wrap or sleeve [Re: Leo99] #4641600
01/21/18 07:49 AM
01/21/18 07:49 AM
Crawfordville FL
Crawfordville FL
I happened to it. Long day, frustrating repair and it was getting in my way.
The battery is a 96R mounted by the firewall on the drivers side.
