Follow up on wheel for Chevy Sonic
by WyrTwister. 12/19/18 09:41 AM
Borescope who has one and what is a good one
by Rat407. 12/19/18 09:13 AM
Lubsoil Universal Synthetic Trans Fluid
by GMBoy. 12/19/18 09:00 AM
1994 Civic LX, 1.5L hard to start
by Gito. 12/19/18 08:01 AM
Observation of Mechanics and their tools...
by ToadU. 12/19/18 07:56 AM
Toshiba Laptop HDD Replacement
by Ifixyawata. 12/19/18 07:49 AM
Aisin Warner TF-71SC
by Bailes1992. 12/19/18 06:37 AM
on the Fence about giving up Facebook
by Donald. 12/19/18 06:20 AM
Motorcraft Mercon LV, 15k, 15' Ford Fusion 6F35
by ssamaroo01. 12/19/18 06:14 AM
RockAuto AC compressors
by chrismo. 12/19/18 05:38 AM
Fullers Vintage Ale anyone?
by Lolvoguy. 12/18/18 11:23 PM
Got an alignment
by michaelluscher. 12/18/18 11:18 PM
Castrol Edge 0W-40; 9,762 mi; 2016 Ford Fiesta ST
by asiancivicmaniac. 12/18/18 10:50 PM
Windows Defender Error Code
by ZeeOSix. 12/18/18 10:20 PM
UOA Motul 300V, 5w40, 2013 BMW S1000RR
by Sportbiker. 12/18/18 09:53 PM
Under valve cover pics
by barkingspider. 12/18/18 09:47 PM
Kubota Super UDT2? Anything better?
by Jmoney7269. 12/18/18 09:23 PM
Car Door Fabric Glue
by cb450sc. 12/18/18 08:57 PM
blkvzgo, AdamJames, Firefighter3244, Sportbiker, trollhattan
66721 Registered Users
86 registered members (beanoil, andyd, aquariuscsm, Alfred_B, 66Monza, 7 invisible), 1,777 guests, and 38 spiders.
Topics295,259
Posts4,931,082
Members66,721
Most Online2,553
Oct 27th, 2018
2016 JK transmission issue? #4635277
01/15/18 12:05 AM
01/15/18 12:05 AM
Rockies
Konstantine Offline OP
Rockies
My 2016 Jeep Sahara has a hard time shifting from second to third gear. I always have to briefly let off the gas for it to shift into third gear. I live up around 10,000 ft so that may be an issue. although It doesn't seem to bother my Escalade. The transmission is at the proper level and it only has 20k on it. She also has a 4" lift and 35's on her.
Re: 2016 JK transmission issue? [Re: Konstantine] #4635279
01/15/18 12:10 AM
01/15/18 12:10 AM
PR CA, USA
2strokeNorthstar Offline
PR CA, USA
Sounds like a programming issue to me. Has the speedo been re-calibrated for 35"s? They are usually a little less than 34" when mounted. With 35"s on my truck and no programmer the trans would hang in 4th and delay the shift back into overdrive after a grade for a bit. With the computer getting what it thinks is the correct speed inputs it's fine.
Re: 2016 JK transmission issue? [Re: Konstantine] #4635281
01/15/18 12:15 AM
01/15/18 12:15 AM
Rockies
Rockies
The speedometer has been re-calibrated. I notice it more on the inclines.
Re: 2016 JK transmission issue? [Re: Konstantine] #4635284
01/15/18 12:24 AM
01/15/18 12:24 AM
WI
HoosierJeeper Offline
WI
You need to regear it.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: 2016 JK transmission issue? [Re: HoosierJeeper] #4635285
01/15/18 12:31 AM
01/15/18 12:31 AM
Rockies
Rockies
I would have to say that you're balls on accurate there.
Re: 2016 JK transmission issue? [Re: Konstantine] #4635288
01/15/18 12:39 AM
01/15/18 12:39 AM
WI
WI
What's stock on those? 3:21? That's gotta be a dog up there spinning those tires. I noticed a decline with my Liberty going up 2" in tires, have 3:73s, 4:10s would be optimum. I'd think for that you'd want 4:56 or 5:38. Is your fuel economy pretty bad too?
Likely not the answer you wanted to hear, but that trans will be dead before 100k without a regear. It'll feel like a new Jeep!
Re: 2016 JK transmission issue? [Re: Konstantine] #4635302
01/15/18 01:09 AM
01/15/18 01:09 AM
NY
DdDd Offline
DdDd  Offline
NY
The 5spd likes to hang onto gears if you drive it sporty I've noticed. Nothing wrong with that, its better than the fuel saving "get into high and don't downshift ever" setup most trannys have
With the larger wheels, you need to reprogram or regear. It's trying to compensate and keep the engine in the power band.
Also mine was a little low from the factory. Try several readings on the dipstick. It's not consistent I've noticed. Low fluid shifts late and sluggish.
Re: 2016 JK transmission issue? [Re: Konstantine] #4635363
01/15/18 05:10 AM
01/15/18 05:10 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Big tires and tall gears are tranny killers.
Re: 2016 JK transmission issue? [Re: HoosierJeeper] #4635385
01/15/18 06:17 AM
01/15/18 06:17 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Exactly.
God Bless Our Troops
Re: 2016 JK transmission issue? [Re: demarpaint] #4635399
01/15/18 06:41 AM
01/15/18 06:41 AM
Rockies
Rockies
Thanks for the advice, I will be re-gearing. Thats no big problem as I wanted to change out both axles anyhow.
Re: 2016 JK transmission issue? [Re: Konstantine] #4635426
01/15/18 07:35 AM
01/15/18 07:35 AM
Onondaga County
Miller88 Offline
Miller88  Offline
Onondaga County
Go as low as you can. With your elevation, I would certainly want it. There's no reason that that engine can't sing along at 3000 or 3500 all day if you take it on a road trip.
18 Forester 2.5I 6M
00 Jeep Cherokee
01 Ford F-350 XL 4x4 5M
Re: 2016 JK transmission issue? [Re: Konstantine] #4635549
01/15/18 09:27 AM
01/15/18 09:27 AM
Rockies
Rockies
It has the stock 3.21 gears.
Re: 2016 JK transmission issue? [Re: Konstantine] #4635562
01/15/18 09:35 AM
01/15/18 09:35 AM
Fly-over country
zuluplus30 Offline
zuluplus30  Offline
Fly-over country
I have 3.73s on 35s and even that is borderline iffy. No way I'd be running 35s/3.21s. You need to regear period. 4.56/35s is a perfect combo for the 3.6 auto. Even 4.10s is a good setup but the 3.6 really comes alive north of 2500. I routinely drive down the highway in manual 4th instead of 5th when it's windy so it won't constantly hunt.
