I do some occasional maintenance on an old coworker's 2000 Jeep Grand Cherokee with the 4.7L (141k miles). I planned to change the oil in it today. When I picked it up at his place, I noticed the oil pressure was steady at only 20 psi. I was a little alarmed but limped it the 1.5 miles to my house, maxing it out at 1400 RPM.
Before I pulled the plug, I wanted to see how much oil was in it. It didn't register on the dipstick. Only after I'd added 2.5 qts. did it finally register. I ended up adding about 3.25 qts. and still didn't quite get it to the ADD mark. (This was some used oil I'd drained after a 1000 mile run last year. Caught it in a clean pan and stuck it on the shelf for potential top-off oil.) I started it again and the oil pressure was then normal.
I went ahead and drained it and changed the filter. I didn't notice any obvious signs of major leaks and his driveway is clean, too. The last oil change was about 5500 miles ago, in May 2017, at a Jiffy Lube. When I filled it back up with just under 6 qts. of Chevron Supreme, the oil pressure stayed right where it should be.
As best as I can tell, the Jeep was running with 40-45% of the sump capacity. I opened up the filter and found some metal flakes, though not as many as I expected. The one I picked out and felt had a consistency similar to that of tin foil.
I also figured out his oil warning light on the dash is burned out. That doesn't help, but the oil pressure gauge was still an obvious tell that he and his wife completely missed.
Anyway, I've never been around an engine neglected like this. So I've had a few questions rolling around in my head:
1. My best guess is that the Jiffy Lube didn't get enough oil in there and this family drove the car for 8 months with a low oil level. If Jiffy Lube DID get it filled, what is going on in this engine to burn more than 3 qts. over 5550 miles?
2. Given how little oil there was in the engine, what was the effect on the oil that was in there?
3. Any guesses as to what the flakes in the filter used to be?
4. How much life did they take out of this engine? (I know this can't be answered in specifics.)
5. How close was this thing to seizing?
