Misbehaving Mechanic Caught On Dash Cam
by BlueOvalFitter. 04/18/19 02:38 PM
What oil for my newly acquired Samurai
by ad244. 04/18/19 02:37 PM
Check your Oil (SMA YouTube Video)
by javacontour. 04/18/19 02:37 PM
Wearing Hiking Shoes Full-Time
by oilpsi2high. 04/18/19 01:56 PM
Apply brakes, steering wheel shakes
by grampi. 04/18/19 01:35 PM
F150 Exhaust whistle
by Redright9. 04/18/19 01:20 PM
Boy, what a marketing win!
by SubieRubyRoo. 04/18/19 12:06 PM
auto shipping question for a friend
by earlyre. 04/18/19 11:02 AM
O Reilly motor oil
by porvdub. 04/18/19 10:59 AM
GM & JEEP O/S OIL FILTERS
by adrenalin89. 04/18/19 10:56 AM
Accord AC Issue
by maverickfhs. 04/18/19 10:54 AM
Transatlantic Communication Lines and the story
by StevieC. 04/18/19 10:41 AM
Crazy Neighbor....part deux
by Schmoe. 04/18/19 10:15 AM
Troubles with Mint Mobile formerly Miny Sim
by daves66nova. 04/18/19 09:40 AM
Marine Engine Oil
by Brian553. 04/18/19 09:35 AM
Steering gear rattle video
by LeakySeals. 04/18/19 08:52 AM
Ran out of 50:1 fuel mix
by StillLearning. 04/18/19 08:42 AM
Kenzitoz, White12Boss302, terryj, Hadryk, djcavein
67844 Registered Users
123 registered members (55hambone, 1978elcamino, aquariuscsm, addyguy, ad244, 11 invisible), 2,165 guests, and 30 spiders.
Topics287,700
Posts4,932,598
Members67,844
Most Online2,967
Mar 10th, 2019
Open Brake Fluid #4634825
01/14/18 04:57 PM
01/14/18 04:57 PM
Scituate MA
coopns Offline OP
coopns  Offline OP
Scituate MA
I opened and used brake fluid container (removed fluid and filled).
Can I use again? I thought I remember someone saying it is (yeah, big word of the day...had to look it up) hygroscopic - absorbs moisture but would that apply even with cap on?
Coop
Re: Open Brake Fluid [Re: coopns] #4634849
01/14/18 05:22 PM
01/14/18 05:22 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Sure you can, put the cap on tight and keep it in a dry cool place, putting it in a ziplock bag is not a bad idea if its going to be longer than a few months.
Unless you live in a very dry climate like southern CA, NM or AZ, etc I would toss it at the 2 year mark.
Re: Open Brake Fluid [Re: coopns] #4634865
01/14/18 05:40 PM
01/14/18 05:40 PM
DFW
DBMaster Online content
DBMaster  Online Content
DFW
I don't know how accurate the electronic brake fluid moisture detectors are but I tested the fluid in a plastic bottle that had been opened and re-capped for over four years and it still tested as being fine. I've never even thought about it in the past (my pre-BITOG days) and haven't had issues yet.
Re: Open Brake Fluid [Re: coopns] #4634962
01/14/18 07:06 PM
01/14/18 07:06 PM
USA
slacktide_bitog Offline
USA
chuck it, especially if it's a plastic bottle.
If it's a metal can, it will probably be OK.
If you're just using cheap DOT 3, you can get a new bottle of that anywhere. Now if iot was something more premium and expensive, then I could see the point of using the remainder.
Re: Open Brake Fluid [Re: coopns] #4634975
01/14/18 07:20 PM
01/14/18 07:20 PM
NJ
JLawrence08648 Offline
NJ
Once the cap is off, it pulls moisture from the open space in the bottle. I wouldn't worry about it, it's more important to change your fluid then worry about a little bit of moisture in the air in the bottle.
Re: Open Brake Fluid [Re: coopns] #4634977
01/14/18 07:22 PM
01/14/18 07:22 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Even in a low humidity environment unless we are talking a bottle of Castrol SRF, brake fluid is so cheap it isn't worth saving opened bottles.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Open Brake Fluid [Re: coopns] #4635122
01/14/18 09:25 PM
01/14/18 09:25 PM
ME
eljefino Offline
eljefino  Offline
ME
A half full bottle in a garage is better than a vented master cylinder in a car driving in weather and seeing heat cycles.
If the fluid's still clear/ amber, run it. At worst use it as a pre-flush when bleeding then finish with something new.
Re: Open Brake Fluid [Re: coopns] #4635243
01/15/18 12:01 AM
01/15/18 12:01 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Wet brake fluid is better than no BF in a pinch, As long as it didn't freeze, it would be fine in a Hydraulic clutch. Also you could squish the bottle until the level was up even and put the top on. I use left over BF to set up airlocks when I bleed.
Thick oil is better grin2
Re: Open Brake Fluid [Re: coopns] #4635351
01/15/18 05:17 AM
01/15/18 05:17 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I have used previously opened (2-3 years) bottles of brake fluid and never had a problem. As long as it is tightly sealed, I wouldn't worry.
The "thinking" man's friend.
Re: Open Brake Fluid [Re: coopns] #4635876
01/15/18 04:23 PM
01/15/18 04:23 PM
Cheshire, England
barryh Online content
barryh  Online Content
Cheshire, England
The way I look at it is the fluid in your car is vented to atmosphere via the reservoir cap. The fluid in your bottle or tin is sealed. Which is going to deteriorate quicker ?
The whole thing about throwing unused brake fluid away once opened is ridiculous. If it lasts 2 years in a car that regularly sees 99% relative humidity it's going to last more than 2 years in the tin on the shelf in my dry garage. I would and did choose a tin container over a plastic bottle.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (MB oil 229.5 5W40)
