- Joined
- Apr 13, 2013
- Messages
- 3,221
Due to the good reviews, I bought General Altimax RT43 tires for the Accord. The old Kumho tires were at 3/32" tread and unfit for the winter. The Generals were available in H or T ratings and I ordered H since that's what my car specs. Just checked my tires today and the shop installed T's
How big of a deal is this? H tires are rated for 130 mph while T's are 118 mph. This car isn't going to see any speeds remotely close to those. I read H tires have better cornering performance but I think that's more important for a sports car, not a 16 yr old beater. The H's also have a shorter warranty -- 65 vs 75k.
Another issue is the alignment I had done. As a note, only toe is adjustable on this car (camber requires special aftermarket bolts). The back right tire's camber actually went OUT of spec after the alignment. I talked to the tech and he said sometimes when fixing the toe, the camber can get out of wack. He said he had to bring the toe into spec as to not prematurely wear the tire and slightly off camber isn't a big deal. Does this make sense to you guys?
