How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
104 registered members (AandPDan, aquariuscsm, advocate, aircooled, 2003f7, 53' Stude, 13 invisible), 2,283 guests, and 59 spiders.
Topics286,017
Posts4,900,823
Members67,548
Most Online2,967
Mar 10th, 2019
Lower the crank to remove rear main rope seal? #4631076
01/11/18 07:26 AM
01/11/18 07:26 AM
Germany
OlDirty Offline OP
OlDirty  Offline OP
Germany
Hello,
I'm currently partly rebuilding the engine from my 1969 Thunderbird. The upper rear main seal is making trouble.
Lower was easy, because I just had to remove the cap and than could peel it off. The upper half won't come out at the moment. Easiest way would be to remove the crankshaft, but I want to avoid that.
Can I loosen the bearing caps in order to lower the crankshaft by an inch or two? I guess that would make things a lot easier.
Is there also a pin in the upper half just like the one in the main bearing cap?
As we're already talking about the crankshaft...what should I bear in mind if I remove it completely?
Thank you!
1998 Grand Cherokee 5.9L
1969 Ford Thunderbird 429cui
2006 Audi A4 2.0TDI
Re: Lower the crank to remove rear main rope seal? [Re: OlDirty] #4631083
01/11/18 07:35 AM
01/11/18 07:35 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
We did them all the time years ago, you need whats called a Chinese finger. Google for it.
It looks like this..
https://www.ebay.com/i/230874687084?chn=ps
Re: Lower the crank to remove rear main rope seal? [Re: OlDirty] #4631087
01/11/18 07:36 AM
01/11/18 07:36 AM
Germany
OlDirty Offline OP
OlDirty  Offline OP
Germany
Or a sneaky pete, I know that tool, but I want to avoid buying something for that job.
2006 Audi A4 2.0TDI
Re: Lower the crank to remove rear main rope seal? [Re: OlDirty] #4631108
01/11/18 08:16 AM
01/11/18 08:16 AM
NH
supton Offline
supton  Offline
NH
I remember doing this once on a GM 2.8, well not very well I guess, as I don't remember how I did it. I don't recall using any special tool though. Maybe it was a metal shell and just the seal blew out...
I presume you can't just grab it with needle nose pliers? I wonder if you could make a tool out of an old half-seal, and push on one side, and grab on the other? Pop the spark plugs, and turn the crank by hand while pushing on the bad seal--maybe you can get lucky.
How does the bearing shell look in the main cap that you removed? If it's in lousy shape then I'd think to drop the crank and do the bottom end bearings. Maybe plastiguage at the moment, see what clearance you have.
2011 Toyota Camry, base, 2.5L/6MT, 179k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 146k, ours
1999 Toyota Camry LE, 2.2L/4AT, 202k, his
Re: Lower the crank to remove rear main rope seal? [Re: OlDirty] #4631109
01/11/18 08:17 AM
01/11/18 08:17 AM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
I always loosen all the mains. No other way to get it in there.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Lower the crank to remove rear main rope seal? [Re: Chris142] #4631167
01/11/18 09:30 AM
01/11/18 09:30 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I wonder how many times I have said that.
Yeah.... rope seals are **tight**. I don't see it happening without lowering the crank.
Re: Lower the crank to remove rear main rope seal? [Re: OlDirty] #4631184
01/11/18 09:46 AM
01/11/18 09:46 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
On my Jeep 4.0 which uses a rubber, not rope seal, I had to loosen up all 7 main bearings to be able to get the old seal out and new seal in.
Be prepared for nasty smelling oil when you loosen up the crank bearings!
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Lower the crank to remove rear main rope seal? [Re: Linctex] #4631186
01/11/18 09:46 AM
01/11/18 09:46 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
That gives you a change to see if the bearings are worn.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Lower the crank to remove rear main rope seal? [Re: CT8] #4631327
01/11/18 12:02 PM
01/11/18 12:02 PM
ky
jerryg Offline
jerryg  Offline
ky
Get a skinny screw, screw it into old seal so when you bump the starter over using a remote, pull gently on screw seal will come out, crankshaft rotation will help when pulling on seal. Have used this many times.
jerryg
Re: Lower the crank to remove rear main rope seal? [Re: OlDirty] #4631725
01/11/18 07:13 PM
01/11/18 07:13 PM
Rockies
Scdevon Offline
Scdevon  Offline
Rockies
After the rear main bearing cap is removed, just loosen the other cap bolts a couple of turns and pry the crankshaft down a fraction of an inch with a wooden dowel or something. Grab the upper part of the old rope seal with needle nose pliers and pull it out of the upper groove while a helper rotates the crankshaft in the direction it needs to go.
You need "Chinese Fingers" to get the upper rope in. Smear the new upper rope with petroleum jelly after the Chinese Finger contraption is fastened and pull it up and over the crank. Trimming and packing rope seals properly has almost become a lost art, but you have to get it right.
Are you rolling in new main bearings too with the crank in the car?
A two piece rubber replacement seal might be available too. You have to drive out the pointed pin in the lower cap to use them.
2003 Mustang Mach 1. 32V 4.6 Liter. Motorcraft Syn Blend 5W30
1970 Mustang Convertible 302-2V Auto (Stock) M/C 10W30
1970 VW Beetle 1600 DP
