WoO driver Jason Johnson injured
by bdcardinal
06/24/18 01:08 AM
Plastic burning smell when WOT
by Jaha24k
06/24/18 12:57 AM
Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
06/24/18 12:00 AM
Ruger LCP .380
by PW01
06/23/18 11:24 PM
Launching boat with stick shift
by troutfisher
06/23/18 11:22 PM
Free oil
by Spitter
06/23/18 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
06/23/18 10:04 PM
RC cars
by red7404
06/23/18 09:36 PM
Any Good 4K Movies ?
by Warstud
06/23/18 09:06 PM
Gray on Oil Dipstick?
by chinee
06/23/18 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
06/23/18 08:15 PM
Parking wars show.
by Chris142
06/23/18 08:15 PM
set for years
by 93cruiser
06/23/18 08:07 PM
Looking to replace 2005 Sienna with SUV
by i6pwr
06/23/18 07:26 PM
Trying to fix chainsaw
by turtlevette
06/23/18 06:48 PM
tire rotation
by marine65
06/23/18 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
New belt squeal cause damage to belt?
by pda1122
06/23/18 05:33 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
25 registered (555, Chris B., CapriRacer, 1998CamryCE, 5 invisible), 796 Guests and 35 Spiders online.
65303 Members
67 Forums
285888 Topics
Page 1 of 2 1 2 >
#4630560 - 01/10/18 02:14 PM Oil Brew/Blend Calculator?
maverickfhs Offline
Loc: VA
I have seen many guys here make their own oil brew and mention, if 0W20 is mixed with 0W40 with 4/1 parts, it'll be close to 0W30 and what not terms of ratios...
Question is, how do you get that approximation of mixing blends?
Is there an online calculator for viscosity and all and for that what do I need?
Thanks for any advice and help thumbsup
2006 Civic EX 200K/AT
2006 Acura TSX 177K/AT
#4630566 - 01/10/18 02:18 PM Re: Oil Brew/Blend Calculator? [Re: maverickfhs]
oil_film_movies Offline
Loc: MN
http://www.widman.biz/English/Calculators/Calculators.html
What's interesting is that its not linear.
Example: Mix an 8 cSt oil 50% with an 11 cSt and you'd think you might get right in the middle, 9.5 cSt. You don't; its actually 9.36 cSt. (KV100 there).
Edited by oil_film_movies (01/10/18 02:23 PM)
#4630574 - 01/10/18 02:24 PM Re: Oil Brew/Blend Calculator? [Re: oil_film_movies]
wemay Offline
Loc: Southeast Florida
This^
2017 Hyundai Sonata Sport 2.4L
2013 Hyundai Santa Fe Sport 2.0T
Valvoline
#4630575 - 01/10/18 02:24 PM Re: Oil Brew/Blend Calculator? [Re: oil_film_movies]
Dallas69 Offline
Loc: Texas
That's close enough for me.
2009 Galant-ultra oil and filter
1987 Ford F-150 302
Smittys 5-30
Motorcraft filter
#4630577 - 01/10/18 02:24 PM Re: Oil Brew/Blend Calculator? [Re: maverickfhs]
SatinSilver Offline
Loc: OH
I'm coming up with a 24 wt.
4x20 and 1x40 = 120
Divide that by 5 = 24.
When doing a blend to keep things stable I would only mix in one part of a different oil ideally. And stick to the same manufacturer and type if possible.
#4630580 - 01/10/18 02:26 PM Re: Oil Brew/Blend Calculator? [Re: maverickfhs]
maverickfhs Offline
Loc: VA
Thanks, is there any place where actual weights can be plugged in directly?
Like 20% of 20W50, 40% of 10W30 and 40% of 0W40, I am just curious, nothing crazy here smile
#4630588 - 01/10/18 02:28 PM Re: Oil Brew/Blend Calculator? [Re: maverickfhs]
Loc: MN
maverickfhs, No, I haven't seen anything where you put the SAE grades in directly.
You have to work with the actual cSt at 100 deg C or 40 deg C on the Widman tool.
This is probably because the J300 SAE viscosity tables allows a range of viscosities within a particular grade.
#4630591 - 01/10/18 02:31 PM Re: Oil Brew/Blend Calculator? [Re: SatinSilver]
Quattro Pete Offline
Loc: Great Lakes
4x20 and 1x40 = 120
Since the grades are just ranges, it's not particularly useful to employ them to calculate blended viscosity. It's much better to use actual viscosities of both oils in these calculations.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (FF)
#4630595 - 01/10/18 02:35 PM Re: Oil Brew/Blend Calculator? [Re: maverickfhs]
Loc: MN
Take your example of mixing 4/1, mostly 0w20. That is 0w40 at 20%. Say both Mobil1.
Widman: plug in 8.7 cSt at 80% and 12.9 at 20% at 100 deg C. Result: 9.39 cSt.
Then notice its a "light" 0w30 since "30 weight SAE" is defined as 9.3 to 12.5 cSt.
The zeroW part is probably intact, as its a pumping requirement, and both 0w40 and 0w20 grades are typically made from light base oils (relative to their 5w cousins).
#4630596 - 01/10/18 02:36 PM Re: Oil Brew/Blend Calculator? [Re: maverickfhs]
Loc: Great Lakes
That would be kind of pointless because each grade represents a fairly wide range of possible viscosities.
#4630600 - 01/10/18 02:37 PM Re: Oil Brew/Blend Calculator? [Re: oil_film_movies]
maverickfhs Offline
Loc: VA
Thanks very much, makes sense!!
#4630605 - 01/10/18 02:40 PM Re: Oil Brew/Blend Calculator? [Re: maverickfhs]
Loc: MN
It gets tricky if you mix a 5w30 with a 0w30. I don't know if the result will be a 5w or a 0w when its cold. I assume linear proportional there.
#4630607 - 01/10/18 02:42 PM Re: Oil Brew/Blend Calculator? [Re: maverickfhs]
maverickfhs Offline
Loc: VA
So I have to know cST for each oil. Now, how can I find it for each specific oil type? Is it mentioned on the bottle or have to looks at the datasheet?
#4630609 - 01/10/18 02:42 PM Re: Oil Brew/Blend Calculator? [Re: maverickfhs]
rooflessVW Offline
Loc: North Carolina
I don't get it... What's wrong with just buying the oil your engine actually NEEDS, and just using that?
"Zed's dead baby, Zed's dead."
#4630610 - 01/10/18 02:46 PM Re: Oil Brew/Blend Calculator? [Re: rooflessVW]
maverickfhs Offline
Loc: VA
Sorry, just trying to learn it smile
I have enough oil in my stash to comfortably take care of all vehcile manufacturer recommended SAE grades for now.
Page 1 of 2 1 2 >
