Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
111 registered members (1978elcamino, 2015_PSD, aquariuscsm, 77GrandPrix, Audios, Alfred_B, 9 invisible), 2,082 guests, and 60 spiders.
Topics286,237
Posts4,904,952
Members67,582
Most Online2,967
Mar 10th, 2019
Why does most fuel have to be atomized to burn? #4628635
01/08/18 08:47 PM
01/08/18 08:47 PM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
Is it because it creates more fumes?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Why does most fuel have to be atomized to burn? [Re: motor_oil_madman] #4628638
01/08/18 08:52 PM
01/08/18 08:52 PM
out there
spasm3 Offline
spasm3  Offline
out there
To get more surface area of the fuel exposed to oxygen.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Why does most fuel have to be atomized to burn? [Re: motor_oil_madman] #4628659
01/08/18 09:05 PM
01/08/18 09:05 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Liquid Gasoline is NOT flammable....LOL.
2001 Chevy Camaro L92/4L80E
Re: Why does most fuel have to be atomized to burn? [Re: clinebarger] #4628663
01/08/18 09:10 PM
01/08/18 09:10 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
we were taught this in hiskool autoshop!
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Why does most fuel have to be atomized to burn? [Re: motor_oil_madman] #4628693
01/08/18 09:28 PM
01/08/18 09:28 PM
USA
mk378 Offline
mk378  Offline
USA
Chemical reactions such as combustion must happen molecule by molecule. A gas has the molecules already separated for quick reaction. When a quantity of liquid gasoline is on fire, it is actually the layer of vaporized gas rising from the surface burning, not the bulk liquid itself.
Re: Why does most fuel have to be atomized to burn? [Re: motor_oil_madman] #4628720
01/08/18 09:58 PM
01/08/18 09:58 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Add to this the short time available to ignite the fuel. At 3000 RPM the spark plug if firing 1500 times per minute which is 25 times per second.
SF
If you want the job done right......do it yourself.
Re: Why does most fuel have to be atomized to burn? [Re: motor_oil_madman] #4628749
01/08/18 10:25 PM
01/08/18 10:25 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Surface of the fuel has to evaporate and reach an air/fuel mixture suitable for combustion. smaller drop sizes, more surface to volume ratio, the more homogenous the charge is. Less large particles to impinge on walls and dilute oil as well.
Diesels work similarly, that's what the "knock" is, when enough diesel has evaporated to ignite with a bang. Too big a droplet, and it turns to soot.
Coal does the same thing. Ground to a powder, the volatiles boil off and commence combustion. The air can then get into the coal particle, and start the "char burnout" phase, leaving molten ash particles behind (some of which form tiny hollow bubbles that end up in cosmetics, packaging, and toothpaste).
Re: Why does most fuel have to be atomized to burn? [Re: motor_oil_madman] #4628770
01/08/18 10:56 PM
01/08/18 10:56 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
The fuel needs to atomise, then to vapourise. In a carburettored engine, it was atomised leaving the discharge tube, and then vapourised in the manifold by lower pressure and heat. fuel injection moves the fuel closer to the valve, but is atomised better by the injector...it still needs the vapourisation stage to be combustable.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Why does most fuel have to be atomized to burn? [Re: motor_oil_madman] #4628817
01/09/18 12:19 AM
01/09/18 12:19 AM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
fumes???
Look up fuel/air ratio....and chemistry of combustion.
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Why does most fuel have to be atomized to burn? [Re: spasm3] #4628870
01/09/18 04:26 AM
01/09/18 04:26 AM
Southeastern, PA
Rick in PA Offline
Rick in PA  Offline
Southeastern, PA
Surface area is basically it. The ability of a fuel to absorb heat, leading to combustion, depends on the surface area to volume ratio. Something small has a lot of surface area for it's volume (or weight). It heats up quickly, reaching combustion temperature.
This is the main factor in dust explosions. A flour mill, or sugar plant explosion, depends on a lot of dust being suspended in the air. A flame starts somewhere and it propagates quickly through the cloud of dust, because each particle of dust virtually instantaneously absorbs the heat and rises to combustion temperature.
In the case of liquid fuels, once atomized, much vaporizes. You can't get a smaller particle than a vaporized molecule of fuel. It's all ready to absorb heat and combust. The small droplets that remain, rapidly absorb heat (due to their high surface area to volume ratio), vaporize and combust with an explosion-like quality.
At least that's my take on it.
A wise man told me:
"Heat is your friend." and "Any oil is better than no oil."
Re: Why does most fuel have to be atomized to burn? [Re: motor_oil_madman] #4628912
01/09/18 07:17 AM
01/09/18 07:17 AM
New England
madRiver Offline
madRiver  Offline
New England
This is why it is really safe to have 250 gallons of home heating fuel sitting in Your basement.
Re: Why does most fuel have to be atomized to burn? [Re: madRiver] #4629033
01/09/18 10:17 AM
01/09/18 10:17 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
If home heating oil is like diesel , it is not anywhere as easily ignited as gasoline .
A fuel like natural gas is already a gas and all it needs to do is mix with air / oxygen . Almost the same with propane / butane .
As has been said , gasoline must be atomized and hopefully vaporized .
Wyr
God bless
Re: Why does most fuel have to be atomized to burn? [Re: motor_oil_madman] #4629114
01/09/18 11:41 AM
01/09/18 11:41 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
It's the Oxygen that burns, the fuel is just a catalyst to that process. Gasoline is actually classified as a "reluctant combustor" which doesn't mean it's safe to throw around but does mean it requires a very specific range of mixture with air to burn; if that ratio is too high or too low, it just wets the chamber, basically.
So both air and fuel need to be well mixed for proper complete combustion.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Why does most fuel have to be atomized to burn? [Re: Johnny2Bad] #4629118
01/09/18 11:44 AM
01/09/18 11:44 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
What? Where did you learn your chemistry? Oxidizers don't oxidize, the fuel does. Oxygen will not burn unless it is being oxidized by fluorine.
You must have slept through high school chemistry is all I can guess.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Why does most fuel have to be atomized to burn? [Re: WyrTwister] #4629129
01/09/18 11:52 AM
01/09/18 11:52 AM
Johnny2Bad Offline
Johnny2Bad  Offline
No quibble with your facts, just an addition:
Natural Gas is safer than Propane because it is lighter than air; it dissipates rapidly and completely into the atmosphere and can reach a non-cumbustive ratio quite quickly. If there is a continuous source of gas, then you have a problem, because there will be a variety of mixture ratios available, only one has to light to create combustion, but if the source of the leak is stopped quickly, or the escaping gas is small volume (like with a Natural Gas stove) not a problem, really (you need a pretty continuous leak in an enclosed area to create an explosion risk with NG).
With Propane, which is heavier than air, it tends to pool at the lower level of an enclosed or open space; think of an low lying fog of explosive gas around your feet and legs. This layer of combustible material will mix with air above it, there will always be a combustible ratio available.
For a real-world example, think of a propane bar-b-q that lights up explosively if you are having problems lighting the thing but eventually introduce a working spark. With a natural gas bar-b-q or stove, the gas being on isn't going to cause that kind of reaction, the thing just lights when the working spark is introduced. Naturally there is always a danger when dealing with any explosive gas and enclosed spaces, but outdoors the risk or a reaction like the propane bar-b-q is near zero; the lid being open insures rapid dilution of the gas (versus it hanging around in the bottom of the grill with propane).
Butane, MAP Gas, etc are similar to Natural Gas in that respect. It's also why some Parkades ban Propane powered vehicles.
