1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
34 registered members (citationxeleven, billt460, Cornershop, c502cid, Ag76, 5 invisible), 951 guests, and 25 spiders.
Topics296,903
Posts4,961,303
Members66,997
Most Online2,688
Jan 19th, 2019
RockAuto OEM Toyota copy oilfilter cut open 4876mi #4627169
01/07/18 04:36 PM
01/07/18 04:36 PM
Jacksonville, FL
FlyNavyP3 Online content OP
FlyNavyP3  Online Content OP
Jacksonville, FL
This will be the last one of these filters that I post as it was the last one that I had left in my stash. This filter was in use for 4876 miles with API SL rated QS Defy 5w20 from last years AZ clearance. Another Rock Auto clearance filter replaced this filter but this time it was an Affina made Car Quest Red 85348. ADBV on this filter provided minimal ADBV function, second filter in a row that I noted this on, valve was stiff but still somewhat pliable.
I forgot to mention above, this came off of my 2004 Lexus ES330 with the 3MZ-FE engine. The car had 175,040 miles on it at the time of service and currently consumes no oil to speak of. Replacement oil was 3 remaining quarts of QS Defy 5w20 high zinc SL oil, 1 quart of (non GTL) Pennzoil Ultra Euro L 5w30 and 1 Quart of PYB 20w50. All were leftovers and odd quarts leftover from last year's AZ clearance. I know it seems like an odd mix but I figured I'd stick to all SOPUS to try and mitigate any add pack difference between brands. I'll service and sample again in 5,000 miles.
Luke
Re: RockAuto OEM Toyota copy oilfilter cut open 4876mi [Re: FlyNavyP3] #4627174
01/07/18 04:40 PM
01/07/18 04:40 PM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
Look's a decent filter
I've got a bunch of OEM Toyota units for my Camry, and I've had excellent success with the 910S, with it's silicone ADBV and base end bypass
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: RockAuto OEM Toyota copy oilfilter cut open 4876mi [Re: FlyNavyP3] #4627176
01/07/18 04:41 PM
01/07/18 04:41 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Looks good to me sir smile
Thanks for c&p
09' Camry LE
ST 5w30 and TG 4386(filter on for second 5k run)
Re: RockAuto OEM Toyota copy oilfilter cut open 4876mi [Re: FlyNavyP3] #4627179
01/07/18 04:43 PM
01/07/18 04:43 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
Do you mind measuring the filter's outside length from end cap to end cap? I'd appreciate it. Thank You.
Re: RockAuto OEM Toyota copy oilfilter cut open 4876mi [Re: das_peikko] #4627202
01/07/18 05:04 PM
01/07/18 05:04 PM
Jacksonville, FL
Jacksonville, FL
I can do that, but why? It's within about 1/8 of an inch of a MC FL-910S or a Fram PH-3614. If you require the information I'll grab a dial caliber and go measure it.
Luke
Re: RockAuto OEM Toyota copy oilfilter cut open 4876mi [Re: michaelluscher] #4627203
01/07/18 05:06 PM
01/07/18 05:06 PM
Jacksonville, FL
Jacksonville, FL
I have also had excellent luck with the FL-910S, I have an older stock one without louvers sitting on the shelf in the garage that I'll probably use on the next oil change in my 4Runner as it takes the same filter as the Lexus.
Luke
Re: RockAuto OEM Toyota copy oilfilter cut open 4876mi [Re: 53' Stude] #4627204
01/07/18 05:07 PM
01/07/18 05:07 PM
Jacksonville, FL
Jacksonville, FL
Thanks Car51, this has been sitting around for a week or so, just finally got around to cutting it today.
Luke
Re: RockAuto OEM Toyota copy oilfilter cut open 4876mi [Re: FlyNavyP3] #4627206
01/07/18 05:10 PM
01/07/18 05:10 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
I want to compare it to a WIX 51040XP that I cut open yesterday. That filter measures 2.250 inches from end cap to end cap. That is a tiny filter! How much filtering it that going to do? You don't need dial calipers; a tape measure is good enough for me. Much appreciated. Thanks.
Re: RockAuto OEM Toyota copy oilfilter cut open 4876mi [Re: das_peikko] #4627211
01/07/18 05:16 PM
01/07/18 05:16 PM
Jacksonville, FL
Jacksonville, FL
It's 3 3/8" tall from the base gasket to the highest point on the dome end of the can.
Luke
Re: RockAuto OEM Toyota copy oilfilter cut open 4876mi [Re: FlyNavyP3] #4627213
01/07/18 05:17 PM
01/07/18 05:17 PM
Jacksonville, FL
Jacksonville, FL
Or did you want the measurement of just the filter element cap to cap?
If so it's 2.5625" or 2 9/16"
Luke
Re: RockAuto OEM Toyota copy oilfilter cut open 4876mi [Re: FlyNavyP3] #4627216
01/07/18 05:19 PM
01/07/18 05:19 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
Just the filter element with the end caps in place. Top of metal end cap to Top of metal end cap. Thanks.
Re: RockAuto OEM Toyota copy oilfilter cut open 4876mi [Re: das_peikko] #4627218
01/07/18 05:21 PM
01/07/18 05:21 PM
Jacksonville, FL
Jacksonville, FL
2.5625"
Luke
Re: RockAuto OEM Toyota copy oilfilter cut open 4876mi [Re: FlyNavyP3] #4627224
01/07/18 05:25 PM
01/07/18 05:25 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
2.5625"
I knew it! Even a Toyota filter is longer! I don't know what GM was thinking when they specified an oil filter for the 3.8L V6. But if you buy a new car like a Camaro with the 3.6L V6, they give you a much longer filter.
Re: RockAuto OEM Toyota copy oilfilter cut open 4876mi [Re: FlyNavyP3] #4627440
01/07/18 08:21 PM
01/07/18 08:21 PM
Canada
i_hate_autofraud Offline
Canada
I wonder what a UOA report would be like for wear metals?
If you measured the outside diameter of the filter and selected a matching
FilterMag, the next time you cut open a filter you'll see all the wear metals
the media does not catch and you'll be better off for it!
I wish I could do it for my last new car from day-one, but dealers are awful!! been doing
on my out-of-warranty for last 4 yrs!
Re: RockAuto OEM Toyota copy oilfilter cut open 4876mi [Re: i_hate_autofraud] #4628446
01/08/18 05:22 PM
01/08/18 05:22 PM
Jacksonville, FL
Jacksonville, FL
I will have a UOA coming for this filter in the not too distant future as well as the previous run which also used this filter. The only data point I have on wear metals using one of these filters was using PYB SAE 30 and it posted single digit Fe numbers over 5,000 miles. This engine sheds almost no iron. I've even run past 10,000 miles with Fe still in the single digits. I won't bother with a filter magnet, this engine will far and away out live my need for this car or the body of the car. I'll post a UOA when it comes in. I'll find the UOA I have for the last oil change sample using one of these cheap filters.
Luke
