98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
61 registered members (BeerCan, 94astro, 69Torino, AndyB, askani79705, Astro_Guy, 8 invisible), 1,183 guests, and 30 spiders.
Topics295,009
Posts4,925,878
Members66,664
Most Online2,553
Oct 27th, 2018
Valvoline SynPower limited slip 75w140 #4625847
01/06/18 11:56 AM
01/06/18 11:56 AM
5600 feet elevation, Arizona
double vanos Offline OP
Ramping up to service the rear diff on my Ď11 FX4. Has factory fill in it, 111k miles so itís going to happen real soon. I have Valvoline SynPower LS 75w140 on hand for the job. Will this be high enough quality to replace the original fill Motorcraft stuff? For the price of the Motorcraft stuff it must be good!
I know, I know, I should have done this a long time ago but life keeps getting in the way, I hope I donít have to surrender my bitog card because of my negligence.
Thanks
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Valvoline SynPower limited slip 75w140 [Re: double vanos] #4625877
01/06/18 12:15 PM
01/06/18 12:15 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
From the 2011 Ford F-150 owners manual the recommended rear diff fluid is 70-140 synthetic fluid. However, your title of your posting says limited slip. The Synpower will be fine but you need to figure out if you need a friction modifier for the limited slip feature. A GM diff would need this. Any Ford experts out there?
SF
If you want the job done right......do it yourself.
Re: Valvoline SynPower limited slip 75w140 [Re: double vanos] #4625880
01/06/18 12:17 PM
01/06/18 12:17 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
I used 75W90 Synpower in the tiny rear end in a WRX I owned. Bought it new, sold with 136K on it. Always used that for the rear end with zero issues.
Used Supertech 75W90 semi synthetic for the five speed manual. The WRX sent 50% of the power to the rear, but also consider a stick is harder on a rear end than a slushbox.
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: Valvoline SynPower limited slip 75w140 [Re: Snagglefoot] #4625893
01/06/18 12:25 PM
01/06/18 12:25 PM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
SF
I believe some diff/gear oils exist where a friction modifier isn't required as there is enough of whatever that good stuff is already in their oil.
I think Mobil is one, but that may depend on what weight it is? I want to try Pennzoil in my diffs but may just use Mobil again if a a friction modifier is req'd?
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: Valvoline SynPower limited slip 75w140 [Re: double vanos] #4625972
01/06/18 01:15 PM
01/06/18 01:15 PM
Snagglefoot Offline
Snagglefoot  Offline
Just checked the Valvoline website. Both the 70-140 and the 70-90 have the limited slip additive. Check the Valvoline gear oil website to confirm. Iíd stick with your original plan for the 70-140 because itís what Ford recommends. They always use heavier gear oil than the others.
SF
Re: Valvoline SynPower limited slip 75w140 [Re: double vanos] #4625984
01/06/18 01:23 PM
01/06/18 01:23 PM
Thatís what I canít figure out. To lock the diff I have to pull out the knob on the 4WD selector, which makes me think itís just an open rear end until, somehow it gets locked at the pull of the switch. The SynPower bottles says it already has friction modifiers and no additives need to be added, presumably for a clutch pack type of diff. I just want to make sure this stuff will cover the lube requirements of the diff ie itís not a low quality product. It is cheaper than Mobil 1 diff oil.
Re: Valvoline SynPower limited slip 75w140 [Re: double vanos] #4626015
01/06/18 01:52 PM
01/06/18 01:52 PM
Snagglefoot Offline
Snagglefoot  Offline
Ok, you have the Ford locking differential. This is different from a limited slip differential. Probably need a little more advice on this before you commit.
SF
Re: Valvoline SynPower limited slip 75w140 [Re: double vanos] #4626057
01/06/18 02:41 PM
01/06/18 02:41 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
If you have the locking diff, no need for additional FM (unless it also has a LS in it as well?).
If you had a limited slip, you would need more FM than what comes in the bottles (the Ford stuff is a great FM, but stinks something horrible)
2012 xB: QSUD 0w-20/CQ Blue/5k
2010 Santa Fe: PP 0w-20/P1/8k
2007 Vue: VSP 5w-30/EcoGard/OLM
2004 F150: GTX HM 5w-20/TG2/4k
2002 F150: GTX HM 5w-20/EcoGard/1yr
1994 VT1100c: Peak 15w-40/PSL/5k
Re: Valvoline SynPower limited slip 75w140 [Re: double vanos] #4626068
01/06/18 02:52 PM
01/06/18 02:52 PM
Snagglefoot Offline
Snagglefoot  Offline
Try use your VIN to confirm your equipment. The Ford trade name of a limited slip differential for 2011 is Traction-lok or Trac Lok.
It requires 4 oz of Additive Friction Modifier XL-3. This is from page 418 of your owners manual.
What's not clear is if the locking diff is used with the Trac Lok or it it's an open diff when the locking diff is ordered.
Trak Lok and a locking diff are two different things.
Re: Valvoline SynPower limited slip 75w140 [Re: double vanos] #4626377
01/06/18 08:34 PM
01/06/18 08:34 PM
Indy
69Torino Online sleepy
69Torino  Online Sleepy
Indy
It's very unlikely for the differential to have both a locking mechanism and clutch packs for limited slip operation. Simply not enough room in the carrier. Nevertheless Valvoline SynPower 75-140 is, in my opinion, the very best you can get for a Ford axle. It has perfectly sufficient and effective amounts of friction modifier included, and if it has a mechanical locker, this doesn't even matter.
Ford originally spec'd 80-90 conventional for the diff in my '03 Marauder, and later published a TSB due to "soft axles" failing where the rear axle bearings ride, due to poor heat treating. Mine ate it's axles up at 105k, I put new aftermarket axles and bearings in it, and after a thorough cleaning and inspection replaced the fluid with SynPower 75-140, obeying the TSB. My 3.73 Traction-Lok has been quieter, chatter free and performs flawlessly ever since. I drag race the car a few times a year and beat the snot out of it when I drive it.
In conclusion, I highly recommend SynPower in any Ford axle. This car uses Valvoline Synthetic products exclusively. Not a Valvoline fanboy, just happy with my results. I use Mobil 1 products exclusively in my wife's cars, including gear lube. Her AWD Hyundai Santa Fe has 178k trouble free miles with Mobil 1 in the rear diff and X-fer case. Only because she is a Mobil 1 fan, and stubborn. She's a gear head too. I think her affinity for Mobil 1 comes from being a Mopar girl, and SRT cars are Mobil 1 factory filled. (She's had a couple of Challengers...)
1969 Ford Torino GT 390 Auto
2003 Mercury Marauder
1992 Mercury Capri Convertible
2005 Ford Freestyle
2008 Hyundai Santa Fe
2015 Kia Optima
1947 Ford 2N
1978 Honda XL75
Plus Other Stuff...
Re: Valvoline SynPower limited slip 75w140 [Re: double vanos] #4626523
01/06/18 11:43 PM
01/06/18 11:43 PM
Snagglefoot Offline
Snagglefoot  Offline
For what itís worth I looked at an owners manual for a 2018 Ford F-150 and both the locking diff and non locking diff took the same synthetic fluid. No mention of friction modifiers. Iíd go ahead with the Syntech 70-140 and not add any friction modifier. You already have some in the fluid and you could always add some if you get chatter.
SF
Re: Valvoline SynPower limited slip 75w140 [Re: double vanos] #4657402
02/05/18 08:17 PM
02/05/18 08:17 PM
Texas & Global
4WD Offline
4WD  Offline
Texas & Global
Went through this Ö had a quart of MC Ö needed two. It was ridiculous Ö
Mobil 1 was twice as much for 140 -vs- 90 Ö
Came home with Valvoline SynPower Ö(2013 Charger)
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: Valvoline SynPower limited slip 75w140 [Re: Snagglefoot] #4659237
02/07/18 04:03 PM
02/07/18 04:03 PM
Cajun Country, La.
BlueOvalFitter Offline
Cajun Country, La.
SF
YES! If it's a L/S add the required L/S additive.
How I do it is, add a little bit of the gear fluid then add the additive to said gear lube bottle. Shake it, add to differential. After adding the required lube, take the truck to an empty parking lot and do a series of figure 8's (about 8-10) to circulate the lube/additive.
I have been doing this for YEARS with no problems, YET!
Also, I ALWAYS use a gasket on my differential cover.
A lonnnnnnnnnnng time ago (1987), a tech at ALANS GEAR WORKS (http://www.agearworks.com) told me no matter how much a L/S gear lube bottle reads NO ADDITIVE NEEDED, add it anyway!
Re: Valvoline SynPower limited slip 75w140 [Re: BlueOvalFitter] #4659486
02/07/18 08:22 PM
02/07/18 08:22 PM
South Carolina (SC)
RyanY Offline
RyanY  Offline
South Carolina (SC)
This is a safe bet. However, I decided to go with the advice of the Royal Purple rep, who stated that additional LS additive is not required for MaxGear 75w90 in my limited slip cadillac. I was skeptical at first, and cautiously tested it by slowly making sharp turns in a parking lot. No issues then, or in the 2 yrs since.
2007 Cadillac CTS 3.6L >117k miles (Castrol Magnatec 5W-30 + AC Delco filter)
2012 Honda Odyssey EX-L >93k miles (Pennzoil Platinum 0W-20 + Fram Ultra filter)
