New car wax score
by Marco620. 01/16/19 02:42 PM
Bought a used Cherokee Trailhawk
by Sunnyinhollister. 01/16/19 02:34 PM
Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
114 registered members (4WD, 2004tdigls, 28oz, advocate, 2002 Maxima SE, 9 invisible), 2,206 guests, and 35 spiders.
Topics296,645
Posts4,956,535
Members66,950
Most Online2,577
Jan 14th, 2019
Crystal ball prediction for a GM 4L60E #4625735
01/06/18 10:12 AM
01/06/18 10:12 AM
Western usa
Ammofirst Offline OP
Western usa
Iím debating what to do about my 2006 buick Rainier awd 4.2 with the 4L60E transmission. Truck has 192k original eng. & Trans. Both eng. & trans. Are running well and I feel like the engine could go another 190k. Iíve seen a few of these trannyís go 160 to 190k then need a rebuild. I installed an oversized pan with drain plug around 50k & have changed out 5-6 quarts max life atf every 25k or so. Probably 80% hwy miles since new. Anyone seen these units go 250k+
Re: Crystal ball prediction for a GM 4L60E [Re: Ammofirst] #4625749
01/06/18 10:22 AM
01/06/18 10:22 AM
Texas
JBinTX30 Offline
JBinTX30  Offline
Texas
If it runs good, just keep doing what you been doing. A used one if something does go wrong is easy and fairly cheaper.
Both my cars have a 4L60E, one has 120k on it one has almost 180k, no issues.
Then again the ones after 2002(?) I think are much better than the older ones.
05 GMC Yukon XL SLT 5.3 CE 5w30 51042
06 Chevy Trailblazer LS 4.2 PP 5w30 XG9837
Re: Crystal ball prediction for a GM 4L60E [Re: Ammofirst] #4625761
01/06/18 10:32 AM
01/06/18 10:32 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
If you don't tow or haul heavy loads with one, they seem like the newer ones aren't bad (and a Rainier isn't that heavy)-but they're really not meant for trucks, vans, or SUVs that haul a lot of weight. Keep doing what you're doing, at 192K you already have beaten the maximum mileage that any of mine made it!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Crystal ball prediction for a GM 4L60E [Re: Ammofirst] #4625763
01/06/18 10:34 AM
01/06/18 10:34 AM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Sounds like you are doing the right thing. Is there a filter that can be replaced as well? I would do that every 50-75K is possible and clean out the crud at the bottom of the pan as well.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Crystal ball prediction for a GM 4L60E [Re: JC1] #4625769
01/06/18 10:45 AM
01/06/18 10:45 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
You're in a good place.
1) You maintain your trannie.
2) Even the old ones were not too bad(?). As mentioned, you have a newer one.
3) If ever it does die, there are soooo many out there any trannie shop can order a rebuild and swap your out in a jiffy.
Re: Crystal ball prediction for a GM 4L60E [Re: Ammofirst] #4625775
01/06/18 10:52 AM
01/06/18 10:52 AM
North Carolina
4ever4d Offline
4ever4d  Offline
North Carolina
Mine has right at 160k on it with no issues. A friend of mine has the 4L60E in a Trailblazer with 198k with no issues. They are a good tranny, i wouldn't worry if i were you just keep on going until something goes wrong then R/R.
04 Chevy Colorado 3.5 I5 5w-30
10 Nissan Rogue 2.5 I4 5w-30
Quaker State AD and Fram
5k OCI on both
Re: Crystal ball prediction for a GM 4L60E [Re: Ammofirst] #4625785
01/06/18 10:59 AM
01/06/18 10:59 AM
Virginia
cpayne5 Offline
cpayne5  Offline
Virginia
I have a buddy with a 2003 Suburban. He bought it brand new and has done drain and fills on the transmission every 60-75k. It has 260k on it and still going strong.
Re: Crystal ball prediction for a GM 4L60E [Re: Ammofirst] #4625793
01/06/18 11:04 AM
01/06/18 11:04 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
170 on my wifes tahoe.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
And another thing..... [Re: cpayne5] #4625798
01/06/18 11:08 AM
01/06/18 11:08 AM
Kira Offline
Kira  Offline
I believe that trans was used in 3/4 ton trucks so it has to be good and strong, no?
I remember tending to a neighbor's 2001 Camaro. He let it get >1 qt. low and in a particular configuration (the position I first saw it in) it didn't go into gear for a full minute. That's when I checked the fluid.
I was amazed and angry (as I had no way to beat the owner-and get away with it).
It ran perfect with a full belly. They sold it
Re: Crystal ball prediction for a GM 4L60E [Re: Ammofirst] #4625803
01/06/18 11:14 AM
01/06/18 11:14 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
My experience is based on my transmission guy stating that literally every light duty 3/4 ton Chevy or GMC work van he maintained smoked the 4L60E by 150K, and my departed C1500 Suburban ('94, TBI 350) had a rebuild with the 7 clutch update due to the previous owner killing it pulling a 22 foot cuddy cabin boat regularly, even with the factory tow package, cooler, etc. In LIGHT duty non-commercial applications, I would think 250K would be possible-but a supplemental cooler and temperature gauge would be a VERY good idea.
Re: Crystal ball prediction for a GM 4L60E [Re: Ammofirst] #4625825
01/06/18 11:35 AM
01/06/18 11:35 AM
n.c.
gman2304 Online content
gman2304  Online Content
n.c.
My 2005 1500 Avalanche just rolled over 193,000 this week. Siphon and fill about 4 qts a couple times a year with Supertech High Mileage Dexron. Pan has never been off. Never towed. No problems yet.
Re: Crystal ball prediction for a GM 4L60E [Re: Ammofirst] #4625827
01/06/18 11:37 AM
01/06/18 11:37 AM
California, USA
cdm1993 Offline
cdm1993  Offline
California, USA
I think you are in good shape. My 1997 GMC 1500 has 245000 on original engine and tranny and it has no problems at all. I did add a deep pan, spin on transmission filter, and a tru-cool 40k transmission cooler behind the condenser. I have towed a boat and camping gear (about 5,000 lbs) in 100* F temps up mountains and it ran great (always tow in 3rd). I also took it from CA to VA with no issues.
I have found if you keep it maintained and cool, it should last a long time.
Re: Crystal ball prediction for a GM 4L60E [Re: Ammofirst] #4625886
01/06/18 12:21 PM
01/06/18 12:21 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
They have been known to go 250K with no service at all under light duty use....Especially the 2005 & up with better (Dex VI) ATF.
Being behind a 6 cylinder & your taking care of it.....It could last a long time!!!
2001 Chevy Camaro L92/4L80E
Re: Crystal ball prediction for a GM 4L60E [Re: Ammofirst] #4625943
01/06/18 12:54 PM
01/06/18 12:54 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Debating what to do in terms of what, replacing the vehicle or trans?
I wouldn't do either until problems actually arise. You've done all the right stuff. From what I've experienced, if you do *some* type of trans service at that 30-50K mile mark and then KEEP maintaining them, a higher than typical lifespan will result.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Crystal ball prediction for a GM 4L60E [Re: Ammofirst] #4626063
01/06/18 02:45 PM
01/06/18 02:45 PM
Birmingham, AL
01rangerxl Offline
01rangerxl  Offline
Birmingham, AL
We have a 2004 5.3 Silverado at work that got close to 400K on the original trans. Lots of highway miles, stingy maintenance. A 2004 Sierra 5.3 at work got about 300K and probably would have been usable for a while longer, but the trans was replaced before it got really bad.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 224K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 200K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 246K miles
