Hey guys, I made a thread in the engine lubes section for the motor, but I want to change the trans fluid as well. What I have is a 2WD 4l60e out of an '04 Buick Raineer thats being swapped into my Volvo 960 wagon (along with the matching aluminum block 5.3 from that same Raineer). They're currently sitting on the floor of my garage. Junkyard claimed 77k miles on both, and the fluid in the trans when I pulled the dipstick looks good, fairly clean, still very red.
First off, what is the recommended fluid for this transmission, and what is the pan capacity? I got the trans with the factory trans cooler lines. Is there a thermostat in-line somewhere in the trans for the cooler lines, or does it rely on the stock cooler ebing part of the radiator to help bring the trans up to temp as well? Reason I ask is that I'm planning on running an aftermarket cooler, but curious if I should be running thru the stock radiator cooler as well? Perhaps come out of the trans, cool thru the aftermarket, then 'temp condition' thru the radiator cooler before going back into the transmission?
