ProMotive PH 2500 CUT OPEN
by car51
31 minutes 8 seconds ago
go green or Dexcool?
by umungus1122
35 minutes 18 seconds ago
Latest info on ExxonMobil synthetic base stocks
by Gokhan
36 minutes 40 seconds ago
Pennzoil Platinum 5w30 - $3.21/qt Amazon
by SnowmanCO
48 minutes 30 seconds ago
What Is Dexos Oil?
by mx5miata
58 minutes 42 seconds ago
Hail damage means newer vehicle time!
by ZZman
Today at 03:39 PM
Trouble with Grease Gun
by tc1446
Today at 02:30 PM
Toyota brand conventional (TGMO)
by Jaha24k
Today at 01:45 PM
Any synthetic oil rebates currently or soon?
by 07Piloteer
Today at 01:32 PM
2018 Hyundai elantra motor oil
by kapama
Today at 01:00 PM
SN Plus on shelves
by 03s
Today at 12:23 PM
Group 90 Battery - 45 vs 60aH rating
by The Critic
Today at 12:19 PM
Tire on Church 15 Passenger Van
by Gebo
Today at 11:58 AM
Battery Disconnect Switch?
by Pike51
Today at 11:35 AM
03 Maxima Cam sensor questions
by LeakySeals
Today at 11:09 AM
Wood Fairing?? Yes, and it's beautiful!
by webfors
Today at 11:08 AM
2006 Prius
by Kira
Today at 11:06 AM
Amsoil XL 5w30, 10K OCI, 2006 Expeditition
by meborder
Today at 10:18 AM
Mouse Visiting Car
by Ifixyawata
Today at 10:07 AM
Hit a shopping cart at 30mph
by LeakySeals
Today at 10:00 AM
Ilia, nmac9, Theraven, battleman13, Shassis
65278 Registered Users
87 registered (9050lx, 28oz, 92saturnsl2, 1JZ_E46, AndyB, 330indy, 6 invisible), 1627 Guests and 38 Spiders online.
65278 Members
67 Forums
285661 Topics
#4621765 - 01/02/18 01:16 PM Charging a Nexus 6
Donald Online   content
Loc: Upstate NY
This is an internal guts of the Nexus 6 question. I pulled the phone apart pealing layers to replace the battery.
The battery has a 3" coil of wire pressed against it. This coil goes to a connector with 4 contacts.
When I plug a mini USB cable into the phone to charge it does it use this induction coil to do the actual battery charging?
2015 Ford F250 w/Powerstroke
#4621769 - 01/02/18 01:20 PM Re: Charging a Nexus 6 [Re: Donald]
CharlieBauer Offline
Loc: CA
No. That coil only receives the wireless charging.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
#4621775 - 01/02/18 01:28 PM Re: Charging a Nexus 6 [Re: CharlieBauer]
Loc: Upstate NY
Ok. I guess that makes sense. The connector connected to the coil needs to be glued or taped to the battery so it touches the other half of the connector exactly right. You need to figure out the proper spot to glue the connector to the battery.
I gave up on wireless charging as it's too slow.
#4621922 - 01/02/18 03:59 PM Re: Charging a Nexus 6 [Re: Donald]
danez_yoda Offline
Loc: texas
It might also be the NFC (near field communication) antenna as well. These should be built into the battery. The parking metrs in Houston use this to communicate. Maybe the quick pay options as well.
I would check this functionality if that is somethin ng you use.
#4621982 - 01/02/18 05:07 PM Re: Charging a Nexus 6 [Re: Donald]
Loc: Upstate NY
I just tried wireless charging that I have not used in awhile. Does not work.
Not sure I will take the phone apart to fix wireless charging that I never use.
#4622294 - 01/02/18 10:13 PM Re: Charging a Nexus 6 [Re: Donald]
jimbrewer Offline
Loc: New Mexico, USA
Mine doesn't work as of a couple of weeks ago. Don't feel like springing for a new charger to figure if it's the phone or the charger.
I really like the wireless charging feature and I'm surprised it hasn't caught on more than it has. It's just great to plop down the phone on it's pad and have it topped up all the time.
#4622523 - 01/03/18 08:38 AM Re: Charging a Nexus 6 [Re: Donald]
KrisZ Offline
Loc: Toronto, Canada
With smartphones getting bigger screens and more powerful hardware, the batteries to power them are also getting bigger. Fast charging is becoming the norm with 9v to 12v and 5A outputs. Wireless charging cannot safely do this.
2015 Dodge Grand Caravan-21k miles.
2006 Mazda 3-155k miles
#4623123 - 01/03/18 08:08 PM Re: Charging a Nexus 6 [Re: KrisZ]
jimbrewer Offline
Who needs fast? If I can put it on it's cradle for an hour here and there where it would not be charged by conventional means and then overnight, I'm good. What do I care if the phone doesn't fully charge until 200 am instead of midnight?
#4624254 - 01/04/18 08:00 PM Re: Charging a Nexus 6 [Re: jimbrewer]
Loc: CA
You're actually extending your lithium ion battery's longevity that way.
Charging to 100% and discharging all the way drastically reduces the number of charge cycles the battery can go through before it's capacity drops significantly. Fast charging also generates more heat which is a further problem.
If the lifecycle of the phone is a year or two, then it's not a problem because the user has gotten maximum performance out of the battery for the time they've owned the phone. But if you want to keep the phone longer and not change the battery, and you don't need a full charge every day, then you'll want to charge it more like an electric car is charged (max charge of 80% of original capacity and range is "empty" at 30% of original capacity). On those occasions when you need the full capacity of the battery, then leaving the phone charging for a little longer and discharging the battery more is going to reduce the life of the battery but you're not doing it every day when you don't need to.
I now charge my phone to 70% max which is enough most of the time. My goal is to not discharge below 20%. I have a charger in the car which helps keep me in this range and I have an app that buzzes me when I reach 70%. It is also possible to switch off charging at a preset % (requires root).
