Valvoline DOT 3/4?
by DJ. 09/19/18 08:22 PM
Best grease for AWD actuator disconnect?
by Bman90. 09/19/18 08:14 PM
Reconditioning a 2-Stroke Snow Blower
by Finz. 09/19/18 07:55 PM
Liquimoly Anti Friction - $6.83 Shipped/ Can
by ad244. 09/19/18 06:57 PM
ACEA spec for old Toyota??
by alexmarjanovic98. 09/19/18 06:54 PM
3.5EB Gen II: Oil & Interval
by Gene K. 09/19/18 06:09 PM
Are there any cable techs here?
by Reddy45. 09/19/18 06:02 PM
VIRGIN ST2 STP FILTER CUT OPEN
by 53' Stude. 09/19/18 05:08 PM
Chrysler HOAT at 9 years...
by burla. 09/19/18 04:34 PM
Septic Tank pumping question
by wormwood1978. 09/19/18 03:46 PM
A5/B5 or A3/B3
by ka9mnx. 09/19/18 03:27 PM
LingLong
by sloinker. 09/19/18 02:42 PM
2018 Grand Caravan review
by tiger862. 09/19/18 02:39 PM
Diagnosing gas furnace
by Oro_O. 09/19/18 01:16 PM
Let's talk dipsticks and oil capacity
by csandste. 09/19/18 12:32 PM
Here's my fram filter at least 18 thousand miles
by Ablebody. 09/19/18 11:31 AM
How much is my truck worth?
by wallyuwl. 09/19/18 09:56 AM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
113 registered members (10WSmuckers, 16HC, 77GrandPrix, ABomb369, 07hemi, 17 invisible), 1,740 guests, and 30 spiders.
Topics290,683
Posts4,848,300
Members66,021
Most Online3,590
Jan 24th, 2017
Looking for Group 48 Battery with 74aH rating #4620966
01/01/18 07:13 PM
01/01/18 07:13 PM
CA
The Critic Online crying OP
The Critic  Online Crying OP
CA
Application is a 2012 MB C250.
Most C-Classes of this generation use a 94r battery, but this particular vehicle uses a group 48. However, all of the group 48s I can find carry a 70aH rating, not 74.
This is the original battery from the vehicle:
Upgrading to a 94r battery would require new hold down hardware and I would like to avoid this if possible.
Any ideas?
2011 Toyota Prius - 173k - Various 0W-20 (Brew)
2007 Honda Accord 2.4 - 131K - Mobil 1 EP HM 5W-30
Re: Looking for Group 48 Battery with 74aH rating [Re: The Critic] #4620995
01/01/18 07:34 PM
01/01/18 07:34 PM
Cincinnati
donnyj08 Offline
donnyj08  Offline
Cincinnati
Can you get the correct unit from a Mercedes Dealer?
2008 Silverado Z71 LT 90k Maxlife FS 5w30
2010 Ford Escape 172k QSUD 5w20
2016 Yamaha XSR900 12k, Rotella 15w40 Yamaha Filter.
Re: Looking for Group 48 Battery with 74aH rating [Re: The Critic] #4621017
01/01/18 07:53 PM
01/01/18 07:53 PM
Massachusetts
VeryNoisyPoet Offline
Massachusetts
Is it a listed requirement from MB to have 74 aH?
Unless there's a special case, the aH rating of a starting battery is not super important. The aH rating of lead-acid batteries is measured at a slow discharge rate, usually over 20 hours for deep cycle and 10 hours for starting batteries. This may be useful for running light to medium loads over a long time, but not for running an engine and accessories in case the charging system suddenly fails.
The faster a battery is drained, the lower the efficiency and the less apparent capacity it will have (the Peukert Effect). The reserve capacity (RC) is a better measurement for a battery in automobile service, as it is how many minutes the battery can sustain a 25 amp load before it discharges below 10.5 volts when at a temperature of 80 degrees F (26.7 degrees C). 25 amps is a pretty typical load of a car with engine running and headlights on, and below 10.5 volts many systems like engine management and transmission controls will begin to malfunction. RC is a good test of how far a car with no charging system can be limped along at night before becoming inoperable.
My guess is any quality brand group size 48 or H6 battery will fit your application. If the car was ever using anywhere near the full aH capacity of the battery, it would be destroying them in a matter of months since lead-acid chemistry does not tolerate repeated deep cycling like that.
1998 V70 GLT / 192k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Looking for Group 48 Battery with 74aH rating [Re: The Critic] #4621035
01/01/18 08:07 PM
01/01/18 08:07 PM
SF BAY AREA, CA
dogememe Online content
dogememe  Online Content
SF BAY AREA, CA
it doesn't matter. be sure to get an agm battery
2007 Crown Vic P71 4.6 ~126K Miles, Royal Purple HPS 5W-30, Royal Purple Filter, Daily Driver, 5K OCIs.
2010 Escape FWD 2.5 ~84K Miles, Castrol Edge EP 5W-30, Wix Filter, Rented on Turo, 10-15K OCIs.
Re: Looking for Group 48 Battery with 74aH rating [Re: The Critic] #4621041
01/01/18 08:11 PM
01/01/18 08:11 PM
North Carolina
spasm3 Offline
spasm3  Offline
North Carolina
I wonder if that spec is fudged so that you buy it from MB? All the group 48 batts i see are 70ah. I'd just go with a reputable brand that has enough cca.
13 elantra 70k 5w30 QSUD
03 chevy avalanche79k synpwr 10w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 5600 miles m1 0w30
Re: Looking for Group 48 Battery with 74aH rating [Re: The Critic] #4621086
01/01/18 08:43 PM
01/01/18 08:43 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
You could contact Exide, who has links to First National Battery in South Africa, shown on your pic of the battery, and see what Exide recommends.
http://www.exide.co.za/what-we-do/
There appears to be only one 74aH 20 hour capacity battery listed in their Products section.
http://www.battery.co.za/products/automotive/passenger-vehicles/?rangeID=3&batID=66
Personally for only 5.4% difference, I'd just get the Bosch Group 48 (H6) AGM at Pep Boys while it's 30% off instead of chasing something from another continent. I put one of these in my wife's Mustang as an upgrade to the factory Group 96R and it's working great.
Pep Boys Link
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Looking for Group 48 Battery with 74aH rating [Re: The Critic] #4621093
01/01/18 08:49 PM
01/01/18 08:49 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
A decrease in Amperhours of 5.4% (4/74) will never be noticed, ever.
Just get the 70 Amperhour battery and forget about it.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Looking for Group 48 Battery with 74aH rating [Re: The Critic] #4621094
01/01/18 08:50 PM
01/01/18 08:50 PM
ME
eljefino Online content
eljefino  Online Content
ME
74 aH until what happens? The battery reads 11.5 volts? Car fails to start? At what temperature? After what charging voltage? At what discharge rate?
As specs go Mercedes may be playing a different game than the aftermarket.
Re: Looking for Group 48 Battery with 74aH rating [Re: The Critic] #4621214
01/01/18 10:44 PM
01/01/18 10:44 PM
MO
wkcars Offline
wkcars  Offline
MO
Re: Looking for Group 48 Battery with 74aH rating [Re: The Critic] #4621235
01/01/18 11:14 PM
01/01/18 11:14 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
^^^^ WHOA!
$356.99 for a 1 year free replacement plus one year prorated warranty AGM!
Plus shipping?
Re: Looking for Group 48 Battery with 74aH rating [Re: The Critic] #4621603
01/02/18 11:47 AM
01/02/18 11:47 AM
CA
CA
Thanks everyone.
You folks are probably correct that 70 aH vs 74 aH does not make a difference in the real-world. However, Euro cars have very finicky charging systems which use the battery's aH rating to determine the correct charge rate. For instance, BMW requires re-coding of the vehicle if you change from a standard battery to AGM (or vice-versa) and/or if you install a battery with a different aH rating. I scanned this car with my Autel and did not see an option to re-code the car for a different battery type or aH rating, so it is possible that MB's charging system is not as picky.
Based on the car's VIN it looks like there are 3 possible hold-down brackets depending on the battery size. Unfortunately there is no way to tell which hold-down applies to a particular battery size - that is just the nature of MB. MB only lists battery part numbers in their database, not group sizes. I think I need hold-down #204-628-01-41 but I am not entirely sure. The hold-down bracket is a few days away.
However they did have plenty of the unicorn 74aH rating batteries in-stock for $162 msrp.
Re: Looking for Group 48 Battery with 74aH rating [Re: The Critic] #4621827
01/02/18 03:21 PM
01/02/18 03:21 PM
California
nthach Offline
nthach  Offline
California
What does the customer want? More Ah is a good thing in moderation - but if the goal is to get a bigger battery for easier availability and if the customer agrees with it, I'd swap in the new bracket.
Otherwise, I'd install the 74Ah MB battery. The good thing about German cars for the most part that the battery lives in the trunk or under the back/front seat and it's decently protected from temperature swings. Now if Mercedes is using a "micro-hybrid" charge on deceleration system like BMW and Hyundai does, well the battery will still be punished.
Re: Looking for Group 48 Battery with 74aH rating [Re: The Critic] #4622026
01/02/18 06:47 PM
01/02/18 06:47 PM
CA
CA
This one lives under the hood.
Owner decided to go with the MB battery. Not sure who makes it- there are no telltale markings on the battery. There isnít even a date code. The parts guy said Interstate is the distributor, so maybe it is a Johnson Controls battery?
Re: Looking for Group 48 Battery with 74aH rating [Re: The Critic] #4622195
01/02/18 09:34 PM
01/02/18 09:34 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
How about under that MB sticker in the upper left area? Looks like another sticker underneath that might have some info.
What kind of warranty does that battery come with? Interesting no date code.
Re: Looking for Group 48 Battery with 74aH rating [Re: Nyogtha] #4622235
01/02/18 10:22 PM
01/02/18 10:22 PM
CA
CA
If the battery was for my own car I would have peeled off the sticker to check, but it is for someone else's car.
MB policy is 2 yrs/unlimited mileage, no pro-rate.
"2.2 Any replacement battery purchased on or after August 1, 2000 at total customer expense is covered for a warranty period of 24 months, unlimited mileage from the date of purchase. Warrantable repairs will be made at no charge for parts and labor when performed at an authorized Mercedes-Benz Center (Passenger Car or Light Truck, as applicable). "
https://www.mbwholesaleparts.com/warranty.aspx
