Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Winter finally arrived
by StevieC. 01/20/19 10:27 AM
Octane rating of UL94 avgas
by Altydoc. 01/20/19 09:55 AM
Any bowlers out there?
by 53' Stude. 01/20/19 08:10 AM
Future of subcompact cars?
by Char Baby. 01/20/19 07:15 AM
Are u a roller coaster fan?
by ZZman. 01/20/19 07:03 AM
DUST - a couple of short Sci Fi films
by Shannow. 01/20/19 05:46 AM
5W30 Synthetic Oils With HTHS of 3.5 ?
by ChrisD46. 01/20/19 04:02 AM
White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Rob_from_Madison, SubieSTI, ebersvc, junk1020, fairparts99
66987 Registered Users
100 registered members (02z, 97f150, 53' Stude, 16 invisible), 2,286 guests, and 35 spiders.
Topics296,880
Posts4,960,749
Members66,987
Most Online2,688
Jan 19th, 2019
Is the battery bad or is it something else ? #4619748
12/31/17 02:04 PM
12/31/17 02:04 PM
Canada
Broo Offline OP
Broo  Offline OP
Canada
Vehicle is a four wheel electric scooter for people with disabilities. There are two 12V deep cycle batteries the size of an automotive battery, probably marine type.
Batteries are 3 to 4 years old. 24V charger does its job and when full, it stops charging and lights up a LED. When full, each battery reads 13.x Volts.
Once charged, the status bar on the scooter reads FULL. When riding, the scooter will suddenly stop and flash the status bar as if the battery was empty. If you turn it off then on, you once again see a full battery bar. You then begin riding and within two minutes the same symptom appears.
Is that the sign of bad batteries ? Deep cycles are pretty expensive, so I'd like to have other opinions before replacing them.
Re: Is the battery bad or is it something else ? [Re: Broo] #4619751
12/31/17 02:08 PM
12/31/17 02:08 PM
New England
madRiver Offline
madRiver  Offline
New England
I doubt your issue is battery related given turning on/off makes it work. It is likely the controller on scooter.
Re: Is the battery bad or is it something else ? [Re: Broo] #4619753
12/31/17 02:09 PM
12/31/17 02:09 PM
Reunion Island
Superflan Offline
Superflan  Offline
Reunion Island
Seems the batteries are shot. Voltage drop from motor load causes the meter to flag empty and stops the scooter rolling to avoid over-discharging the batteries. When you switch it off and on again, the voltage test is back to normal because no load on the batteries.
Peugeot Partner 1.9 D, 5W40 C3, 245000 Km, running on WVO
Wife's Mitsubishi Outlander PHEV, dealerís overfilled, 16000 Km
Re: Is the battery bad or is it something else ? [Re: Broo] #4619757
12/31/17 02:14 PM
12/31/17 02:14 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
I agree with madRiver and think it may be a controller OR a sit-down safety switch. Ed
CX5 Touring 2.5L :-)
Re: Is the battery bad or is it something else ? [Re: Broo] #4619759
12/31/17 02:14 PM
12/31/17 02:14 PM
Cape Cod, MA
RF Overlord Offline
RF Overlord  Offline
Cape Cod, MA
A battery with a bad cell can read good on a no-load voltage test, but fail under load.
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
'04 Grand Marquis LS Limited Edition - daily driver
'00 Grand Marquis GS - bad frame/future to be determined
Re: Is the battery bad or is it something else ? [Re: Broo] #4619765
12/31/17 02:17 PM
12/31/17 02:17 PM
USA
mk378 Offline
mk378  Offline
USA
You need to read the battery voltage under load. Even running the motor with the drive wheels off the ground would be somewhat of a test.
Re: Is the battery bad or is it something else ? [Re: Broo] #4619766
12/31/17 02:17 PM
12/31/17 02:17 PM
Virginia
Dufus2 Offline
Dufus2  Offline
Virginia
Are these AGM batteries?
ASE Certified in Med/Heavy Truck Service including A9
Heavy Equipment Repair, Fleet Maintenance
Real Cars Rattle and Smoke a Little
Re: Is the battery bad or is it something else ? [Re: Broo] #4619768
12/31/17 02:17 PM
12/31/17 02:17 PM
California
VeryNoisyPoet Offline
California
Attach a separate voltmeter directly to the batteries and ride the scooter to watch what the voltage does. If it really sags down, could be the batteries failing. If voltage is normal at batteries but scooter still says dead batteries, look for loose, dirty, or corroded connections.
A voltage drop test along the main power wires while under load can help narrow down where the problem lies if there are no obviously bad connections.
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Is the battery bad or is it something else ? [Re: Eddie] #4619791
12/31/17 02:40 PM
12/31/17 02:40 PM
MIchigan
Warstud Online content
Warstud  Online Content
MIchigan
Yep....some safety feature. He says turning it off... then on... shows battery full. Some sort of short.
Re: Is the battery bad or is it something else ? [Re: Broo] #4619809
12/31/17 02:49 PM
12/31/17 02:49 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Have them load tested.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Is the battery bad or is it something else ? [Re: Broo] #4619836
12/31/17 03:13 PM
12/31/17 03:13 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Yeah, just load test the batteries. Any decent auto parts house can do that in a jiffy. If they fail you know. If they pass, then it's in the scooter ...
Re: Is the battery bad or is it something else ? [Re: Broo] #4619846
12/31/17 03:23 PM
12/31/17 03:23 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
Did this happen all of a sudden? If it had been sitting a while, I'd be inclined to think that it's a sign that the batteries are going bad. Measuring the battery voltages, especially under load, would be a good start.
Re: Is the battery bad or is it something else ? [Re: Broo] #4619922
12/31/17 04:34 PM
12/31/17 04:34 PM
MI
HorseThief Offline
HorseThief  Offline
MI
Sounds like bad batteries, especially at 3-4yrs old, but there could be another issue. Does the battery meter drop down to low under load? Most chairs don't have a seat safety switch. Otherwise, make sure the brake/clutch lever or levers (near the wheels) are fully seated nice and tight.
If you set the speed at max does it cut out sooner than at slow speed?
You can get the batteries tested at a battery store or medical supply store. Otherwise, a rudimentary 100 amp hand-held load tester should be sufficient to pinpoint a shot battery. The electronic conductance (cranking amp) testers used by most auto parts stores aren't good for testing deep cycle agm or gel batteries.
I saw a brown dog
Re: Is the battery bad or is it something else ? [Re: Broo] #4619929
12/31/17 04:47 PM
12/31/17 04:47 PM
East Mountains, NM
4wheeldog Offline
4wheeldog  Offline
East Mountains, NM
It could be as simple as a loose or corroded connection.
As someone else posted, getting a reading under load will tell you a lot.
Re: Is the battery bad or is it something else ? [Re: Broo] #4620048
12/31/17 06:57 PM
12/31/17 06:57 PM
Canada
Broo Offline OP
Broo  Offline OP
Canada
Thanks for the replies. When stores reopen I will get a 100A battery tester. I found one at a local store at decent price.
To my knowledge there are no safety switches as you can operate the scooter by walking beside it. I had to remove the seat and the hood under it to reach the batteries and I didn't have to unplug anything electrical other than the rear lights.
Are they AGM ? I have no idea. All stickers have been removed from them.
The problem started all of a sudden in late Fall. It's not used during winter so I left it in my heated garage and make sure to charge it every week until I figure out what is happening.
The problem happens whether you are riding full speed or lower.
One more thing I remember : with the status bar full, when you start riding it immediately loses a bar of charge. This bar is back when you "reboot" the scooter unless you've been really riding enough to get the battery to that level.
