Hey guys, I’ve got a 2012 Nissan Titan that’s running Mobil 1 5w30 with a fram ultra filter. I’m due for an oil change. I’ve always changed my oil at every 3,750 miles as it instructs in the manual and the 3 samples I’ve sent to Blackstone have been very low wear. This time I stretched it out to a more reasonable 5,200 miles. I put the fram ultra on with the intentions of running it for 2 changes (10,000 miles) but I have a couple concerns. People say you don’t get all the old oil out unless you remove the filter as well. Is that something I should be concerned with? Would it be a good idea to take the filter off to drain the oil and then reinstall it or is it bad for the gasket to remove an reinstall? Should I just replace the filter or is that a waste after only 5,000 miles?
Thank you very much,
Aaron
Aaron
