Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
jefe_de_estado, CM613, Geardaddies, 01ws666, ariefnrst
66660 Registered Users
108 registered members (28oz, 97K15004WD, ad244, 64bawagon, 53' Stude, AdditiveOCD, 14 invisible), 1,865 guests, and 35 spiders.
Topics294,990
Posts4,925,554
Members66,660
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
Thoughts- 1991 Chevy Pickup C/K 1500 V8 4WD Xt Cab #4614752
12/26/17 02:08 PM
12/26/17 02:08 PM
Baltimore, Maryland
Spartuss Offline OP
Spartuss  Offline OP
Baltimore, Maryland
I am thinking of buying a 1991 Chevrolet Pickup 1500 C/K extended cab that I've been offered. It's through an estate. The owner has passed and the family is selling the truck.
Appears to be in good shape, it's a V8, most likely a 350 5.7L or a 5.0L. Can't get much useful info from the seller as she knows very little. It has approx. 122k miles on it. Appears to be the long bed with the extended cab.
If I were to buy it, I'd get historic plates and Insurance on it which would end up being $100-$150 per year. I would use it for Home Depot runs.
Any known problems with these? Advice?
Was once a BITOG addict!
Re: Thoughts- 1991 Chevy Pickup C/K 1500 V8 4WD Xt Cab [Re: Spartuss] #4614755
12/26/17 02:11 PM
12/26/17 02:11 PM
Baltimore, Maryland
Spartuss Offline OP
Spartuss  Offline OP
Baltimore, Maryland
Re: Thoughts- 1991 Chevy Pickup C/K 1500 V8 4WD Xt Cab [Re: Spartuss] #4614757
12/26/17 02:15 PM
12/26/17 02:15 PM
WI
HoosierJeeper Offline
WI
That's pretty cool, they're pretty dependable. I'd go for it, looks clean.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Thoughts- 1991 Chevy Pickup C/K 1500 V8 4WD Xt Cab [Re: Spartuss] #4614764
12/26/17 02:29 PM
12/26/17 02:29 PM
Virginia
cpayne5 Offline
cpayne5  Offline
Virginia
I'd love to find something like that. If the price is right, jump on it.
Re: Thoughts- 1991 Chevy Pickup C/K 1500 V8 4WD Xt Cab [Re: Spartuss] #4614771
12/26/17 02:39 PM
12/26/17 02:39 PM
Baltimore, Maryland
Spartuss Offline OP
Spartuss  Offline OP
Baltimore, Maryland
What would be considered a good price?
These have a timing chain, correct?
Any known problems or anything I should watch out for?
Re: Thoughts- 1991 Chevy Pickup C/K 1500 V8 4WD Xt Cab [Re: Spartuss] #4614772
12/26/17 02:39 PM
12/26/17 02:39 PM
NH
supton Offline
supton  Offline
NH
If the price is right.. I probably would. I mean, it's surpassed by today's trucks but then it wouldn't cost like today's trucks--and if it meets your needs, then why spend more? Benefits of EFI but with cheap parts. Classic looks. Ease of repair.
1991, should be throttle body, not a powerhouse but pretty darn reliable, if not a bit thirsty. 4 speed auto, some go early, some last long, but regardless it should be cheap enough to rebuild (GM only made 50 million of those 700R4's (4L60 by then?)). Part time 4WD, not sure if there are any vacuum actuated hubs or whatnot, but I wouldn't think those would be that problematic. Not sure that there is anything here that isn't supported by the aftermarket.
Only issue I would see is if you're not used to a long vehicle. And the part time 4WD system.
Edit: timing chain, yes.
2011 Toyota Camry, base, 2.5L/6MT, 170k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 144k, ours
1999 Toyota Camry LE, 2.2L/4AT, 195k, his
Re: Thoughts- 1991 Chevy Pickup C/K 1500 V8 4WD Xt Cab [Re: Spartuss] #4614787
12/26/17 02:55 PM
12/26/17 02:55 PM
Warner Robins, GA
nwjones18 Offline
nwjones18  Offline
Warner Robins, GA
That's a good looking pickup. If the A/C is working and its running/driving fine that's a $3500 truck minimum around here.
1988 F-150. 4.9 I6 247k. 10w-40 Castrol Syn-blend ACDelco UPF2.
2005 Cadillac STS N* 108k. 5w-30 Castrol Magnatec ACDelco Classic PF61
Re: Thoughts- 1991 Chevy Pickup C/K 1500 V8 4WD Xt Cab [Re: Spartuss] #4614812
12/26/17 03:26 PM
12/26/17 03:26 PM
San Rafael, CA
dogememe Online content
dogememe  Online Content
San Rafael, CA
gmt400 (88-98) are the best. i had a 92 a lot like that. 240k+ on the original engine and it ran perfect. tranny is the weak point but that goes for all trucks of any brand pretty much. i paid $2300 for mine, the body had no rust but plenty of dents, interior was perfect and everything worked perfectly except the radio. then again everything here in marin county is expensive.
2010 Ford Escape 2.5~91K Miles: AMSOIL SS 5W-30, AMSOIL SS FE ATF.
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30, AMSOIL OE MV ATF.
AMSOIL
Re: Thoughts- 1991 Chevy Pickup C/K 1500 V8 4WD Xt Cab [Re: Spartuss] #4614843
12/26/17 04:05 PM
12/26/17 04:05 PM
Long Island,nassau county NY
nickaluch Offline
nickaluch  Offline
From the looks of that's passenger side mirror attached to the door most likely pulled a trailer at some point in it's life.
2007 G6 beater.2012 E450 box truck. 2018 Chevy Traverse.2017 E450 box truck.2017 Chevy 3500 extend cargo van.
Re: Thoughts- 1991 Chevy Pickup C/K 1500 V8 4WD Xt Cab [Re: Spartuss] #4614868
12/26/17 04:21 PM
12/26/17 04:21 PM
PV Az
AZjeff Offline
AZjeff  Offline
PV Az
You have room inside for it? Bet it didn't stay in that condition sitting outside. The doors will droop but hinge kits are cheap and easy. That would be a highway champ with the loooong wheelbase, too bad you'll short trip it but if it works for you why not. She's a classic.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Thoughts- 1991 Chevy Pickup C/K 1500 V8 4WD Xt Cab [Re: supton] #4614886
12/26/17 04:33 PM
12/26/17 04:33 PM
South Carolina
eyeofthetiger Offline
South Carolina
I would go for it if the price is reasonable, but I could be biased.
The timing chain is very short and very reliable, and the whole drivetrain is reliable and easy to service. The TBI system can be a bit finicky to troubleshoot for driveability, but it almost never quits.
The 4wd system has one weak link, but it is an easy fix. The electro-thermal actuator for the front axle lock may stop working or be slow to engage. The permanent fix is a manual cable actuator, or a permanent lock. http://4x4posi-lok.com/app_chevy-k.html
I have the permanently locked version (although it only takes an allen key and and a couple of minutes to crawl under and unlock it for a highway trip), so the front driveshaft always spins with the wheels, even if the transfer case is in 2WD. I don't care about the slight fuel economy hit, or the increased wear on the front driveshaft.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: Thoughts- 1991 Chevy Pickup C/K 1500 V8 4WD Xt Cab [Re: Spartuss] #4614938
12/26/17 05:23 PM
12/26/17 05:23 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
That should be a flat tappet engine. Use an oil appropriate for that, although many of those trucks ran forever on the cheapest fill one could find. HDEO would not be a bad idea.
Where the transmission is concerned; it's a 700R4. Not a bad trans, but not a good one either. Plenty of info out there on its weak spots, but I think clinebarger will chime in with significantly more specific detail.
Keep the OCI'S short unless you know for certain through UOA that it isn't a fuel dilution monster.
Re: Thoughts- 1991 Chevy Pickup C/K 1500 V8 4WD Xt Cab [Re: Spartuss] #4614947
12/26/17 05:28 PM
12/26/17 05:28 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Pretty good trucks. The engine is bullet proof. The front suspension is the weak link on them. They dont hold an alignment long and eat tires.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Thoughts- 1991 Chevy Pickup C/K 1500 V8 4WD Xt Cab [Re: Spartuss] #4614971
12/26/17 05:45 PM
12/26/17 05:45 PM
USA
mk378 Offline
mk378  Offline
USA
These go through fuel pumps and ignition modules with some regularity. Definitely carry a spare module, they will just quit and leave you stone dead. The rest of the TBI system is quite reliable, though as noted it can get into weird driveability problems.
Re: Thoughts- 1991 Chevy Pickup C/K 1500 V8 4WD Xt Cab [Re: Spartuss] #4614978
12/26/17 05:52 PM
12/26/17 05:52 PM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
That truck screams old man! I like it.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Page 1 of 3 1 2 3
