Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
77 registered members (BeerCan, aquariuscsm, bfleeman, AndyB, 4WD, Best F100, 8 invisible), 1,307 guests, and 39 spiders.
Topics295,208
Posts4,929,961
Members66,711
Most Online2,553
Oct 27th, 2018
Electrical Outlet - Wiring Help #4613921
12/25/17 02:11 PM
12/25/17 02:11 PM
Scituate MA
coopns Offline OP
coopns  Offline OP
Scituate MA
I have done outlets before but not this one.
Tried to simply change outdated outlet. It is connected/powered by a wall switch...but I can't figure out how.
I have two black to brass, two white to silver. Didn't work. So I broke the tab and that didn't work either.
No power to outlet or the light switch. Previously switch worked outside light and I think it just powered the bottom outlet,
not top. I never used it but wife mentioned that.
Does the order of the wires matter (which white or black on top?) and do I just break the hot side or both? I tried on hot side.
Any advice (besides calling an electrician).
Outlet
Outlet 1
Coop
Re: Electrical Outlet - Wiring Help [Re: coopns] #4613928
12/25/17 02:21 PM
12/25/17 02:21 PM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
no power to outlet , check the breakers
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive185k miles
Last Change;
50/50 QSUD, QSHM. 5w30
Fram XG8A, Fram CA8141
Currently under the influence of oil shocked2
Re: Electrical Outlet - Wiring Help [Re: coopns] #4613949
12/25/17 02:44 PM
12/25/17 02:44 PM
central ga
urrlord Offline
urrlord  Offline
central ga
I hate electrical.My house was built in the early 70's.We recently had a mouse chew some of the wiring.Two electricians have came out and looked at it ,said they would have to get back with us.Have not heard back from either.
Re: Electrical Outlet - Wiring Help [Re: coopns] #4613952
12/25/17 02:46 PM
12/25/17 02:46 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
So you're saying that that there's a switch that switched and outside light in addition to the bottom outlet? Looking at your images, you have 4 wires, 2 white, 2 black. I think it should be connected like this:
Neutral (white) should be connected throughout, and the shorting tab should not be broken on that side of the outlet (one of your white wires is coming in, the other is going out to the next outlet/light). One of the black wires should come from the switch, and you should be able to measure it go hot when the switch is flipped. That wire should be connected to the bottom outlet, with the shorting tab broken. That wire should also be connected to the light outside (either at the outlet or somewhere else in the junction box, or even wired somewhere else). There should be another black wire that is always hot, you'll connect that to the top outlet.
Take a multimeter and start probing, figure out which lines are switched. Hard to describe in words. Obviously, if there's zero power, check your breaker.
Re: Electrical Outlet - Wiring Help [Re: rollinpete] #4613970
12/25/17 02:58 PM
12/25/17 02:58 PM
Tennessee
tvaughn0712 Offline
tvaughn0712  Offline
Tennessee
Did the original outlet have a tab broken? If broken only the hot side should be broken (gold side with black wires). If not you need to get a new outlet and replace since you already broke the tab. In this configuration it doesn't matter which wire goes where. If the original outlets tab was broken (and it should only be done on the hot side) then that means one of the outlets is powered all the time and the other is powered off a switch. In this configuration it still doesn't really matter which black wire is on top except for that the outlet that was previously switched and the one that was hot all the time may be switched. If you want to switch simply reverse the black wires. In both configurations it doesn't matter which white wire is on top (just keep white wires with silver screws and black wires with gold).
With that all said it sounds like nothing works so I agree check your breaker. It looks like you have a metal outlet so maybe one of the black wires were touching the side and tripped the breaker
Re: Electrical Outlet - Wiring Help [Re: tvaughn0712] #4613973
12/25/17 02:59 PM
12/25/17 02:59 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
Good call, that's a lot more clear than my explanation!
Re: Electrical Outlet - Wiring Help [Re: rollinpete] #4613980
12/25/17 03:11 PM
12/25/17 03:11 PM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
Just noticed it's feeding another outlet or light
Pete.
Last Change;
Re: Electrical Outlet - Wiring Help [Re: coopns] #4613989
12/25/17 03:22 PM
12/25/17 03:22 PM
ME
eljefino Offline
eljefino  Offline
ME
As you initially hooked it up the light should have come on, as you shorted switched to always-hot. So I think your issues are further upstream. Pull other outlets from that circuit that work and see if they have any "backstabbed" connections instead of to the screws. Those notoriously flake out and go bad. They are also a legal-but-lazy way of adding a 3rd wire to spur off in another direction, typically found in handyman additions.
I would look at the switch next to see if it's still hot somewhere.
Re: Electrical Outlet - Wiring Help [Re: coopns] #4614092
12/25/17 05:56 PM
12/25/17 05:56 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Did you put a meter on it? Should be able to find 120v between one of the sets.
Re: Electrical Outlet - Wiring Help [Re: coopns] #4614130
12/25/17 06:51 PM
12/25/17 06:51 PM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
You tube. I figured out my 3 pole switch issue. One switch has 120 constant. The other wires are travelers. Tie the two travelers together. Go to the other switch and ohm two wires to find the other two travelers. The other wire will be your common.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: Electrical Outlet - Wiring Help [Re: coopns] #4614400
12/26/17 07:13 AM
12/26/17 07:13 AM
South Central PA
Delta Online happy
Delta  Online Happy
South Central PA
First I would redo those connections to the outlet, especially the hot on the bottom in the second picture. They need to be cleanly under the screw. Second, the way you have the grounds in against code; needs to be wire-nutted.
Did the old outlet work before? If the outlet itself isn't switched, but power came off that outlet to a switch then the tab shouldn't be broken.
'17 VW GTI 2.0T - 6MT - 11K - Edge 0w40
'15 Camry SE - 2.5 - 22K - PP 0w20
'99 S10 - 2.2 5MT - 157K - PP 10w30
Re: Electrical Outlet - Wiring Help [Re: coopns] #4614414
12/26/17 07:37 AM
12/26/17 07:37 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Coops, does that wall switch control anything else along with this outlet?
I know in my previous home, I had some duplex outlets where the top was switched and the bottom was constant. Both tabs were broken on those IIRC. Been awhile.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Electrical Outlet - Wiring Help [Re: JTK] #4614786
12/26/17 02:54 PM
12/26/17 02:54 PM
Scituate MA
coopns Offline OP
coopns  Offline OP
Scituate MA
Thanks for all the replies...
Update: I tried the outlet with black tab side broken off, tried either wire on top, neither worked. The breaker is fine.
I opened up the wall switch which I replaced a few months ago and it has two black which are hooked up...one black to top screw
one black to bottom screw and both white capped...not going anywhere. This was the configuration that worked the outside light and gave power to the bottom outlet that worked before I tried the new outlet. Previous owner of house was electrician so we are finding a lot of different setups.
Coop
Re: Electrical Outlet - Wiring Help [Re: coopns] #4615548
12/27/17 09:15 AM
12/27/17 09:15 AM
USA
mk378 Online content
mk378  Online Content
USA
It is common for circuit breakers to fail open. They don't close the circuit even though the handle is in the on position. So after you turned it off to work on the wiring, it may not have come back on. That would be the first place to check with a voltmeter. Then go toward the outlet and find out where the electricity is being lost.
